So I'm trying to make a little shooter game for my own pleasure and I wanted to use the asm program COLOR for a text color change but this code wasn't working:
ORANGE i + BLUE
Asm(prgmCOLOR
Output(1,1,"X
instead, it gave me a syntax error between the orange and the i.
can someone help, please?
I have no clue what program that is or where you got it.
If you are talking about this program:
https://www.cemetech.net/forum/viewtopic.php?p=235013#235013 , then read the post on how to use it. It literally tells you right there. You are supposed to use the imaginary
i, located as the blue key above the 0.
Also that program doesn't even work on the TI84+CE, so who even knows what you are trying to do. You should really just be using TextLib:
https://www.cemetech.net/programs/index.php?mode=file&id=1340
MateoConLechuga wrote:
yes, it was and thank you, I'm still quite new to this. Thanks!
