The battery on my daughter's calculator died so when she connected it to the charger, the orange charging light comes on. The screen is now flashing on and off. When I hold the del 2nd and reset buttons at the same time, the screen is blank and white. I tried connecting to computer and it is not connecting. Is there anything else I can do to try to get it to work.
I think that you just gotta wait
The same thing happened to me, or maybe not exactly, but it was stuck on a white screen for like 10 hours, an then it went to the Install OS screen. Then, you'll want to clear storage like 50 times before sending the OS.
No.
mr womp womp, in a two year-old thread wrote:
...unfortunately, you will need to reinstall the OS. Fortunately, this is pretty easy. you press 2nd and del while pressing the reset key in the back (a little hard to do but that's good because that means you won't do it by mistake) then connect it to a computer equipped with ti-connect CE with a mini-usb cable and send over the new OS. You can get the OS here. Good luck! and if you have any questions, ask away
This should work
Note: you can get ti-connect CE here.
- jcgter777
- Super-Expert (Posts: 927)
- Re: TI 84 CE PLUS Screen is white and blank
- 15 Nov 2017 07:16:12 pm
@_iPhoenix_
verdaryl already tried that, and that didn't work...
Have you tried removing the battery, and replacing it after ~5 min? Also, try [2nd][del], but put the battery in while holding the keys down... this could just be me trying to help, but test that out, it should hopefully give an OS send screen. Also, a video of the screen would (might) help -- is the screen fully white, or is (was) there a status bar on it?
- verdaryl
- Newbie (Posts: 7)
- 15 Nov 2017 09:56:43 pm
- Last edited by verdaryl on 15 Nov 2017 10:00:54 pm; edited 1 time in total
I tried putting in a new battery but did not push the [2nd] [del] while putting it in. I will try it and see what happens. How do I add video of the screen
- Botboy3000
- Power User (Posts: 496)
- 15 Nov 2017 09:59:14 pm
- Last edited by Botboy3000 on 15 Nov 2017 10:02:24 pm; edited 1 time in total
you'll have to use a real camera or a phone camera to record the screen of a physical calculator.
EDIT: to add a video, you'll have to upload it to youtube as unlisted and use the youtube bbcode tag to embed it in the post (which looks like [youtube]*your unshortened youtube link here*[/youtube])
- verdaryl
- Newbie (Posts: 7)
- 15 Nov 2017 10:05:09 pm
- Last edited by verdaryl on 15 Nov 2017 10:11:16 pm; edited 1 time in total
I think that you need to get a shareable link from a folder you create with the video. Right now, I have to request access to see it. (I can't see it)
If the 2nd del reset combo doesn't work, I think I recall some people having success by removing the battery and putting it back in, which should either clear the ram, or bring up the install OS screen, at which point you can keep using your calc, or reinstall the OS with ti-connect as mentioned above. To take out the battery, you just have to unscrew the little back panel, and unlike older models like the CSE, the battery should be very easy to remove (like most android phones)
techpoweredmath.com
CE to the right, CSE to the left
techpoweredmath.com
@mr. womp womp
ummmmmm.....
ummmmmm.....
Can you try these links now should share now.
One is video of flashing screen and picture of what happens when I press [del] [2nd]
https://drive.google.com/file/d/10zHBpCwrwjIC-sn4-c7rcSK34EYnBcjw/view?usp=drivesdk
https://drive.google.com/file/d/1_-eueRBtmJPkhL43xsat_O06NAoovTU0/view?usp=drivesdk
It's weird because the screen is blinking as fast as the cursor blinks on an unbroken calc. Was the calculator dropped hard, or maybe it could have been put under a lot of stress in a backpack with lots of books? Is there any way it could be physical damage?
Simply put, the calculator has run out of charge. When attempting to plug it into a computer, the usb attempts to establish a connection, but cannot because it is out of charge
To fix this, find a wall outlet and use that to charge the device. In order to execute the [2nd][del]+[reset] sequence, be sure to *remove* the USB cable beforehand, otherwise it will still assume a device is connected. Once you reach the OS install screen, replug in the calculator to the computer. Hope this helps.
» Goto page 1, 2 Next
