Lol. Mimas also uses uppercase mnemonics...
Edit: Also, I found a routine for clipping large sprites....
;Clip Big Sprite
;by James Montelongo
;MAX SIZE: 64x64
;ix - Sprite
;b - height
;c - width in bytes
;d - x
;e - y
ClipBigSprite:
; Early out, Check if its even remotely on screen
ld a,e
cp 64
ret p
add a,b
ret m
ret z
ld a,d
cp 96
ret p
ld a,c
add a,a
add a,a
add a,a
add a,d
ret m
ret z
ld a,e
or a
jp p,Check_clip_bottom
neg
push de
ld hl,0
ld d,l
ld e,a
bit 2,c
jr z,$+2+1
add hl,de
add hl,hl
bit 1,c
jr z,$+2+1
add hl,de
add hl,hl
bit 0,c
jr z,$+2+1
add hl,de
pop de
ex de,hl
add ix,de ;Here you can save the top offset
ex de,hl
ld e,0
neg
add a,b
ld b,a
Check_clip_bottom:
ld a,e
add a,b
sub 64
jp m,Check_clip_Left
neg
add a,b
ld b,a
Check_clip_Left: ; at this point you may want to save b
xor a
ld (bigskip),a
ld a,Clipleftsize
ld (Do_Clipleft),a
ld a,d
or a
jp p,Check_clip_right
cpl
and $F8
rra
rra
rra
ex de,hl ;save the clipped left offset
ld e,a
ld d,0
add ix,de
ld (bigskip),a
ex de,hl
inc a
neg
add a,c
ld c,a
xor a
ld (Do_Clipleft),a
ld a,d
and $07
ld d,a
Check_clip_right:
ld a,Cliprightsize
ld (Do_Clipright),a
ld a,c
add a,a
add a,a
add a,a
add a,d
sub 96
jp m,Check_clip_middle
and $F8
rra
rra
rra
ld l,a
ld a,(bigskip)
add a,l
inc a
ld (bigskip),a
neg
add a,c
ld c,a
xor a
ld (Do_Clipright),a
Check_clip_middle: ; This is where C should be saved.
xor a
ld (Do_ClipMiddle),a
ld a,c
or a
jp nz,dontskipmiddle
ld a,ClipMiddlesize
dontskipmiddle:
ld l,e
ld a,d
ld h,0
ld d,h
add hl,hl
add hl,de
add hl,hl
add hl,hl
ld e,a
and $07
xor 7
ld (BigRot1),a
ld (BigRot2),a
ld (BigRot3),a
add a,a
ld (clipbigrot1),a
ld a,$ff
clipbigrot1 = $+1
jr $
srl a
srl a
srl a
srl a
srl a
srl a
srl a
srl e
srl e
srl e
add hl,de
ld de,gbuf
add hl,de ; This is where gbuf offset should be saved.
ld d,a
cpl
ld e,a ;masks should be saved to
BigSpriteRow:
push bc
push hl
ld b,c
Do_Clipleft = $+1
jr Clipleft
ld a,(ix)
inc ix
BigRot1 = $+1
jr $
rrca
rrca
rrca
rrca
rrca
rrca
rrca
BigMask0:
and e
or (hl)
ld (hl),a
Clipleft:
Clipleftsize = Clipleft-(Do_Clipleft+1)
Do_ClipMiddle = $+1
jr $+2
BigSpriteloop:
ld a,(ix)
inc ix
BigRot2 = $+1
jr $
rrca
rrca
rrca
rrca
rrca
rrca
rrca
ld c,a
BigMask1:
and d
or (hl)
ld (hl),a
inc hl
ld a,c
BigMask2:
and e
or (hl)
ld (hl),a
djnz BigSpriteloop
ClipMiddle:
ClipMiddlesize = ClipMiddle-(Do_ClipMiddle+1)
Do_ClipRight = $+1
jr ClipRight
ld a,(ix)
BigRot3 = $+1
jr $
rrca
rrca
rrca
rrca
rrca
rrca
rrca
BigMask3:
and d
or (hl)
ld (hl),a
ClipRight:
Cliprightsize = ClipRight-(Do_ClipRight+1)
pop hl
ld bc,12 ;width of the screen
add hl,bc
bigskip = $+1
ld bc,0
add ix,bc
pop bc
djnz BigSpriteRow
ret
