String to Byte
Takes the first 3 (non 0) chars of a string and converts to byte.
Notes:
Leading letters are treated as zeros.
Following letters are treated as null.
If string has a value > 255, a is overflowed.
Inputs:
HL: Null terminated string location in memory
Outputs:
A: Byte
strtob:
 push bc
  push de
   ld c, 0
strtobNumFind:
   ld a, (hl)
   cp $00
   jp z, strtobEXIT
   ld c, 0
   sub '1'
   cp '9' + 1
   jr c, strtobNumWhile
   inc hl
   jr strtobNumFind
strtobNumWhile:
   push hl
strtobNumWhileLoop:
    ld a, c
    cp 3
    jp nc, strtobConvert
    ld a, (hl)
    sub '0' - 1
    jr c, strtobConvert
    cp '9' + 1
    jr nc, strtobConvert
    inc hl
    inc c
    jr strtobNumWhileLoop
strtobConvert:
    dec hl
    ld a, (hl)
    sub '0'
    ld c, a
    dec hl
   pop de
    call cpHLDE
    jp c, strtobExit
    ld a, (hl)
    sub '0'
    ld b, 10
    call mulAbyB
    add a, c
    ld c, a
    dec hl
    call cpHLDE
    jp c, strtobExit
    ld a, (hl)
    sub '0'
    ld b, 100
    call mulAbyB
    add a, c
    ld c, a
strtobExit:
   ld a, c
  pop de
 pop bc
 ret
cpHLDE:
 or a
 sbc hl, de
 add hl,de
 ret
mulAbyB:
 push bc
  ld c, a
mulAbyBLoop:
  add a, c
  djnz mulAbyBLoop
  sub c
 pop bc
 ret
Example:
ld hl, testStr
call strtob
testStr: .db "0244", 0
A now contains $F4, or '244' in decimal.
Related to the previous post, here's a heavily optimized string to byte, at 14 bytes. Same inputs, but output is in C instead of A. eZ80 only. Will give garbage results if a non-digit character is encountered or if the number is greater than 255.
strtob:
        xor     a,a
strtob_loop:
        ld      c,a
        ld      a,(hl)
        inc     hl
        sub     a,'0'
        ret     c
        ld      b,10
        mlt     bc
        add     a,c
        jr      strtob_loop
And for one byte more, here's a version that will return when encountering any non-digit character, leaving HL pointing to that character.
strtob:
        xor     a,a
strtob_loop:
        ld      c,a
        ld      a,(hl)
        sub     a,'0'
        ld      b,10
        cp      a,b
        ret     nc
        inc     hl
        mlt     bc
        add     a,c
        jr      strtob_loop
For a Z80 compatible alternative (15 bytes):
strtob:
;Input:
;   HL is a 0-terminated decimal string
;Output:
;   A has the 8-bit value
    xor a       ;A trick to reset our accumulator to zero
loop:
    inc (hl)    ;increment our byte...
    dec (hl)    ;then decrement. If originally zero, this will now set the z flag
    ret z
    ld d,a      ;save our current acumulator so we can multiply by 10
    add a,a     ;double our accumulator
    add a,a     ;double again (now x4)
    add a,d     ;add the original (now x5)
    add a,a     ;double again (now x10)
    add a,(hl)  ;add in the incoming byte
    sub '0'     ;adjust by subtracting '0' (could use 48, 0x30, $30, 30h)
    inc hl      ;increment the pointer
    jr loop
EDIT:
If you want to stop on a non-digit input (so not just a zero-terminated string):
strtob:
    xor a
    call loop
    ld a,d
    ret
loop:
    ld d,a
    ld a,(hl)
    inc hl
    sub '9'+1
    add 10
    ret nc
    ld e,a
    ld a,d
    add a,e     ;add in the incoming digit
    jr loop
Mod HL
returns the remainder after division of H and L and puts it in H
NOTE: actually doesn't divide, but simulates modulus.
;;modHL
;;H % L => H
;;Inputs:
;; H:
;; L:
modHL:
 push bc
 ld b, h
 ld a, 0
modHLLoop:
 inc a
 cp a, l
 jr nz, modHLLoopEnd
 ld a, 0
modHLLoopEnd:
 djnz modHLLoop
 ld h, a
 pop bc
 ret
Optimizing for size, I would personally suggest A mod L -> A
modloop:
    sub l
    jr nc,modloop
    add a,l
It get the job done a lot faster, destroys no variables, and it is 4 bytes. To modify it so that it uses H instead of A, simply wrap the code with a ld a,h \ ... \ ld h,a
    ld a,h
modloop:
    sub l
    jr nc,modloop
    add a,l
    ld h,a
EDIT: As Runer pointed out, this will cause an infinite loop if L=0. If you can't guarantee this won't happen, then use this H mod L -> H routine:
;H mod L -> H
;returns carry reset if undefined (when L=0)
    ld a,l
    or a
    ret z
    ld a,h
modloop:
    sub l
    jr nc,modloop
    add a,l
    ld h,a
    ret
I have two neat routines, pushpop and diRestore. If you want to preserve HL,DE,BC, and AF, then you can just put a call to pushpop at the start of your routine. If you want interrupts to be restored on exiting your routine, you can call diRestore at the top of your code.
They both mess with the stack to insert a return routine on the stack. For example, when your code calls diRestore, then an ret will first return to the code to restore the interrupt status, and then back to the calling routine.
pushpop:
;26 bytes, adds 229cc to the calling routine
  ex (sp),hl
  push de
  push bc
  push af
  push hl
  ld hl,pushpopret
  ex (sp),hl
  push hl
  push af
  ld hl,12
  add hl,sp
  ld a,(hl)
  inc hl
  ld h,(hl)
  ld l,a
  pop af
  ret
pushpopret:
  pop af
  pop bc
  pop de
  pop hl
  ret
diRestore:
    ex (sp),hl
    push hl
    push af
    ld hl,restoreei
    ld a,r
    jp pe,+_
    dec hl
    dec hl
_:
    di
    inc sp
    inc sp
    inc sp
    inc sp
    ex (sp),hl
    dec sp
    dec sp
    dec sp
    dec sp
    pop af
    ret
restoredi:
    di
    ret
restoreei:
    ei
    ret
EDIT: calc84maniac pointed out that 'inc sp' can be dangerous without first disabling interrupts. I've reorganized the diRestore accordingly.
32-Bit Endian Swap (eZ80)
Swaps the byte order of a 32-bit value stored in EUHL. Can be adapted to work with other register combinations as well.
endianswap32:
    push hl
    ld h,e
    ld e,l
    inc sp
    push hl
    inc sp
    pop hl
    inc sp
    ret
The ClearHorizLine routine here never got updated, so I took a stab at it, writing a routine for black, white, and inverted horizontal lines. In mine, they all use a common subroutine, but if you take just the white+subroutine, it is 32 bytes smaller (25%), and all combined take 25 bytes over the original.
(NOTE: I edited the original routine to use `rla` instead of `rl a` to get these results.)
;Contains 3 routines and 1 subroutine.
;horizontalline_black
;    Draws a black horizontal line
;horizontalline_white
;    Draws a white horizontal line
;horizontalline_invert
;    Draws an inverted horizontal line
;horizontalline_sub
;    A routine common to the others that calculates masks and pointers.
horizontalline_black:
;Input:
;   A is y0
;   D is the width
;   C is x0
;Output:
;   Black horizontal line from (A,C) to (A,C+D-1)
;NOTE: This does not do any clipping. You can frick stuff up.
  call horizontalline_sub
  jr z,horizontalline_black_small
  ld d,b
  ld b,a
  ld a,(hl)
  or c
  ld (hl),a
  inc hl
  dec b
  jr z,horizontalline_black_last
_:
  ld (hl),$FF
  inc hl
  djnz -_
horizontalline_black_last:
  ld a,(hl)
  or d
  ld (hl),a
  ret
horizontalline_black_small:
  ld a,c
  and b
  or (hl)
  ld (hl),a
  ret
horizontalline_white:
;Input:
;   A is y0
;   D is the width
;   C is x0
;Output:
;   white horizontal line from (A,C) to (A,C+D-1)
  jr z,horizontalline_white_small
  ld d,b
  ld b,a
  ld a,c
  cpl
  and (hl)
  ld (hl),a
  inc hl
  dec b
  jr z,horizontalline_white_last
_:
  ld (hl),0
  inc hl
  djnz -_
horizontalline_white_last:
  ld a,d
  cpl
  and (hl)
  ld (hl),a
  ret
horizontalline_white_small:
  ld a,c
  and b
  cpl
  and (hl)
  ld (hl),a
  ret
horizontalline_invert:
;Input:
;   A is y0
;   D is the width
;   C is x0
;Output:
;   invert horizontal line from (A,C) to (A,C+D-1)
  jr z,horizontalline_invert_small
  ld d,b
  ld b,a
  ld a,(hl)
  xor c
  ld (hl),a
  inc hl
  dec b
  jr z,horizontalline_invert_last
_:
  ld a,(hl)
  cpl
  ld (hl),a
  inc hl
  djnz -_
horizontalline_invert_last:
  ld a,(hl)
  xor d
  ld (hl),a
  ret
horizontalline_invert_small:
  ld a,c
  and b
  xor (hl)
  ld (hl),a
  ret
horizontalline_sub:
;Input:
;   A is y0
;   D is the width
;   C is x0
;Output:
;   A is the width in bytes of the line
;   C is the left mask
;   B is the right mask
;   HL points to where to begin drawing.
;   z flag is set if the line starts and ends on the same byte.
;First compute the address of the byte to start drawing at.
  ld h,0
  ld b,h
  ld l,a
  add a,a
  add a,l
  ld l,a
  add hl,hl
  add hl,hl
  ld a,c
  ld e,c    ;for safe keeping
  srl c
  srl c
  srl c
  add hl,bc
  ld bc,plotSScreen
  add hl,bc
;Now compute the left mask
  and 7
  ld b,a
  ld a,$FF
  jr z,+_
  rra
  djnz $-1
_:
;Increment A and invert
  inc a
  cpl
  ld c,a    ;C is the left mask
;now compute the right mask at E+D-1
  ld a,d
  add a,e
  dec a
  ld d,a
  and 7
  ld b,a
  ld a,$7F
  jr z,+_
  rrca
  djnz $-1
_:
  inc a
  ld b,a    ;B is the right mask
;Now compute the width in bytes of the line
;(D>>3)-(E>>3)
  ld a,d
  and %11111000
  rrca
  rrca
  rrca
  srl e
  srl e
  srl e
  sub e
  ret
I am going to continue editing this post if I come across other optimizations.
EDIT: Here is an optimized version of Ashbad's itoa_8 routine. It's much faster and less than half the size:
;Converts an 8-bit signed integer to a string
itoa_8:
;Input:
;   A is a signed integer
;   HL points to where the null-terminated ASCII string is stored (needs at most 5 bytes)
;Output:
;   The number is converted to a null-terminated string at HL
;Destroys:
;   Up to five bytes at HL
;   All registers preserved.
;on 0 to 9:       252       D=0
;on 10 to 99:     258+20D   D=0 to 9
;on 100 to 127:   277+20D   D=0 to 2
;on -1 to -9:     276       D=0
;on -10 to -99:   282+20D   D=0 to 9
;on -100 to -128: 301+20D   D=0 to 2
;min: 252cc  (+23cc over original)
;max: 462cc  (-49cc over original)
;avg: 343.74609375cc = 87999/256
;54 bytes
  push hl
  push de
  push bc
  push af
  or a
  jp p,itoa_pos
  neg
  ld (hl),$1A  ;start if neg char on TI-OS
  inc hl
itoa_pos:
;A is on [0,128]
;calculate 100s place, plus 1 for a future calculation
  ld b,'0'
  cp 100 \ jr c,$+5 \ sub 100 \ inc b
;calculate 10s place digit, +1 for future calculation
  ld de,$0A2F
  inc e \ sub d \ jr nc,$-2
  ld c,a
;Digits are now in D, C, A
; strip leading zeros!
  ld a,'0'
  cp b \ jr z,$+5 \ ld (hl),b \ inc hl \ .db $FE  ; start of `cp *` to skip the next byte, turns into `cp $BB` which will always return nz and nc
  cp e \ jr z,$+4 \ ld (hl),e \ inc hl
  add a,c
  add a,d
  ld (hl),a
  inc hl
  ld (hl),0
  pop af
  pop bc
  pop de
  pop hl
  ret
EDIT: Optimized the above itoa_8 routine more. Here are some more number-to-string routines:
uitoa_8
Converts an 8-bit unsigned integer to an ASCII string.
;Converts an 8-bit unsigned integer to a string
uitoa_8:
;Input:
;Output:
;Destroys:
;   Up to four bytes at HL
;on 0 to 9:     238              D=0
;on 10 to 99:   244+20D          D=0 to 9
;on 100 to 255: 257+2{0,6}+20D   D=0 to 5
;min: 238cc
;max: 424cc
;avg: 317.453125cc = 81268/256 = (238*10 + 334*90+313*156)/256
;52 bytes
  push hl
  push de
  push bc
  push af
;A is on [0,255]
  ld b,'0'
  ld de,$0A2F
  ld c,a
  ld a,'0'
  add a,c
  add a,d
  ld (hl),a
  inc hl
  ld (hl),0
  pop af
  pop bc
  pop de
  pop hl
  ret
itoa_16
Converts a 16-bit signed integer to an ASCII string.
;Converts a 16-bit signed integer to an ASCII string.
itoa_16:
;Input:
;   DE is the number to convert
;   HL points to where to write the ASCII string (up to 7 bytes needed).
;Output:
;   HL points to the null-terminated ASCII string
;      NOTE: This isn't necessarily the same as the input HL.
  push de
  push bc
  push af
  push hl
  bit 7,d
  jr z,+_
  xor a
  sub e
  ld e,a
  sbc a,a
  sub d
  ld d,a
  ld (hl),$1A     ;negative char on TI-OS
  inc hl
_:
  ex de,hl
  ld bc,-10000
  ld a,'0'-1
  inc a \ add hl,bc \ jr c,$-2
  ld (de),a
  inc de
  ld bc,1000
  ld a,'9'+1
  dec a \ add hl,bc \ jr nc,$-2
  ld (de),a
  inc de
  ld bc,-100
  ld a,'0'-1
  ld (de),a
  inc de
  ld a,l
  ld h,'9'+1
  dec h \ add a,10 \ jr nc,$-3
  add a,'0'
  ex de,hl
  ld (hl),d
  inc hl
  ld (hl),a
  inc hl
  ld (hl),0
;No strip the leading zeros
  pop hl
;If the first char is a negative sign, skip it
  ld a,(hl)
  cp $1A
  push af
  ld a,'0'
  jr nz,$+3
  inc hl
  cp (hl)
  jr z,$-2
;Check if we need to re-write the negative sign
  pop af
  jr nz,+_
  dec hl
  ld (hl),a
_:
  pop af
  pop bc
  pop de
  ret
uitoa_16
Converts a 16-bit unsigned integer to an ASCII string.
;Converts a 16-bit unsigned integer to an ASCII string.
uitoa_16:
;Input:
;   HL points to where to write the ASCII string (up to 6 bytes needed).
;Output:
  push de
  push bc
  push af
  ex de,hl
  ld bc,-10000
  ld a,'0'-1
  ld (de),a
  inc de
  ld bc,1000
  ld a,'9'+1
  ld (de),a
  inc de
  ld bc,-100
  ld a,'0'-1
  ld (de),a
  inc de
  ld a,l
  ld h,'9'+1
  add a,'0'
  ex de,hl
  ld (hl),d
  inc hl
  ld (hl),a
  inc hl
  ld (hl),0
  ld c,-6
  add hl,bc
  ld a,'0'
  inc hl \ cp (hl) \ jr z,$-2
  pop af
  pop bc
  pop de
  ret
Here are some routines that I've added to the repository:
fixed88_to_string
Uses the itoa_8 routine in the previous post to convert an 8.8 fixed-point number to a string.
;This converts a fixed-point number to a string.
;It displays up to 3 digits after the decimal.
fixed88_to_str:
;Inputs:
;   D.E is the fixed-point number
;   HL points to where the string gets output.
;      Needs at most 9 bytes.
;Outputs:
;   HL is preserved
;Destroys:
;   AF,DE,BC
;First check if the input is negative.
;If so, write a negative sign and negate
  push hl
  ld a,d
  or a
  jp p,+_
  ld (hl),$1A      ;negative sign on TI-OS
  inc hl
  xor a
  sub e
  ld e,a
  sbc a,a
  sub d
_:
;Our adjusted number is in A.E
;Now we can print the integer part
  call itoa_8
;Check if we need to print the fractional part
  xor a
  cp e
  jr z,fixed88_to_str_end
;We need to write the fractional part, so seek the end of the string
;Search for the null byte. A is already 0
  cpir
;Write a decimal
  dec hl
  ld (hl),'.'
  ld b,3
_:
;Multiply E by 10, converting overflow to an ASCII digit
  call fixed88_to_str_e_times_10
  inc hl
  ld (hl),a
  djnz -_
;Strip the ending zeros
  ld a,'0'
_:
  cp (hl)
  dec hl
  jr z,-_
;write a null byte
  inc hl
  inc hl
  ld (hl),0
fixed88_to_str_end:
;restore HL
  pop hl
  ret
fixed88_to_str_e_times_10:
  ld a,e
  ld d,0
  add a,a \ rl d
  add a,a \ rl d
  add a,e \ jr nc,$+3 \ inc d
  add a,a
  ld e,a
  ld a,d
  rla
  add a,'0'
  ret
sqrtA
This is a very fast, unrolled routine to compute the square root of A.
sqrtA:
;Input: A
;Output: D is the square root, A is the remainder (input-D^2)
;Destroys: BC
;speed: 161+{0,6}+{0,1}+{0,1}+{0,3}
;min: 161cc
;max: 172cc
;avg: 166.5cc
;45 bytes
  ld d,$40
  sub d
  jr nc,+_
  add a,d
  ld d,0
_:
  set 4,d
  sub d
  jr nc,+_
  add a,d
  .db $01   ;start of ld bc,** which is 10cc to skip the next two bytes.
_:
  set 5,d
  res 4,d
  srl d
  set 2,d
  sub d
  jr nc,+_
  add a,d
_:
  set 3,d
  res 2,d
  srl d
  inc d
  sub d
  jr nc,+_
  add a,d
  dec d
_:
  inc d
  srl d
  ret
sqrtfixed_88
An unrolled, fast 8.8 fixed-point square root routine. Uses the above sqrtA routine.
sqrtfixed_88:
;Input: A.E ==> D.E
;Output: DE is the sqrt, AHL is the remainder
;Speed: 690+6{0,13}+{0,3+{0,18}}+{0,38}+sqrtA
;min: 855cc
;max: 1003cc
;avg: 924.5cc
;152 bytes
  call sqrtA
  ld l,a
  ld a,e
  ld h,0
  ld e,d
  ld d,h
  sla e
  rl d
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
  .db $FE     ;start of `cp *`
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
;Now we have four more iterations
;The first two are no problem
  sll e \ rl d
  add hl,hl
  add hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add hl,hl
  add hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
sqrtfixed_88_iter11:
;On the next iteration, HL might temporarily overflow by 1 bit
  sll e \ rl d      ;sla e \ rl d \ inc e
  add hl,hl
  add hl,hl
  jr c,sqrtfixed_88_iter11_br0
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
  jr sqrtfixed_88_iter12
sqrtfixed_88_iter11_br0:
  or a
  sbc hl,de
_:
  inc e
;On the next iteration, HL is allowed to overflow, DE could overflow with our current routine, but it needs to be shifted right at the end, anyways
sqrtfixed_88_iter12:
  ld b,a      ;A is 0, so B is 0
  add hl,hl
  add hl,hl
  rla
;AHL - (DE+DE+1)
  sbc hl,de \ sbc a,b
  inc e
  or a
  sbc hl,de \ sbc a,b
  ret p
  add hl,de
  adc a,b
  dec e
  add hl,de
  adc a,b
  ret
ncr_HL_DE
Computes 'HL choose DE' in such a way so that overflow only occurs if the final result overflows 16 bits.
; Requires
;    mul16          ;BC*DE ==> DEHL
;    DEHL_Div_BC    ;DEHL/BC ==> DEHL
ncr_HL_DE:
;"n choose r", defined as n!/(r!(n-r)!)
;Computes "HL choose DE"
;Inputs: HL,DE
;Outputs:
;   HL is the result
;       "HL choose DE"
;   carry flag reset means overflow
;Destroys:
;   A,BC,DE,IX
;Notes:
;   Overflow is returned as 0
;   Overflow happens if HL choose DE exceeds 65535
;   This algorithm is constructed in such a way that intermediate
;   operations won't erroneously trigger overflow.
;66 bytes
  ld bc,1
  or a
  sbc hl,de
  jr c,ncr_oob
  jr z,ncr_exit
  sbc hl,de
  add hl,de
  jr c,$+3
  ex de,hl
  ld a,h
  or l
  push hl
  pop ix
ncr_exit:
  ld h,b
  ld l,c
  scf
  ret z
ncr_loop:
  push bc \ push de
  push hl \ push bc
  ld b,h
  ld c,l
  call mul16          ;BC*DE ==> DEHL
  pop bc
  call DEHL_Div_BC    ;result in DEHL
  ld a,d
  or e
  pop bc
  pop de
  jr nz,ncr_overflow
  add hl,bc
  jr c,ncr_overflow
  pop bc
  inc bc
  ld a,b
  cp ixh
  jr c,ncr_loop
  ld a,ixl
  cp c
  jr nc,ncr_loop
  ret
ncr_overflow:
  pop bc
  xor a
  ld b,a
ncr_oob:
  ld h,b
  ld l,b
  ret
Masked Sprite
Earlier in the thread, Kerm offered a masked sprite routine. Fallen Ghost made some improvements, making it a smaller and faster and taking care of a minor bug, but at the cost of using the shadow registers (which needs interrupts off in many cases).
I optimized Fallen Ghost's routine, saving another 4 bytes and making it a little faster:
;Masked Sprite routine
;This is optimized by Zeda from a routine by Fallen Ghost, as a response to Kerm's routine.
;NOTE: Uses shadow registers!
PutMask:
;Inputs:
;   a = X coordinate
;   l = Y coordinate
;   b= height of sprite
;   ix = sprite address
;   ix+b = mask address (same length as sprite, please)
;Outputs:
;   Mask and then sprite displayed at specified location on the graph buffer
;Destroys:
;   AF, BC, DE, HL, IX, DE', HL' (shadow registers)
;Improvements from Fallen Ghost's version:
;   - 4 bytes less
;   - Faster
  ld e,l
  ld h,0
  ld d,h
  add hl,hl
  add hl,de
  add hl,hl
  add hl,hl
  ld e,a
  and 7
  ld c,a
  xor e  ;essentially gets E with the bottom 3 bits reset
#if (plotSScreen&255) = 64
  inc a
  rra
  rra
  rra
  ld e,a
  ld d,plotSScreen>>8
#else
  rra
  rra
  rra
  ld e,a
  add hl,de
  ld de,plotSScreen
#endif
  add hl,de
   ld a,b
   exx
   add a,ixl
   ld l,a
   ld a,ixh
   adc a,0
   ld h,a
   exx
putMaskLoop1:
  exx
  ld      d,0FFh
  ld      e,(hl)
  inc hl
  exx
  xor a
   ld   d,(ix)
   ld   e,a
   sub c
   jr   z,putMaskSkip1
putMaskLoop2:
  exx
  rr e
  rr d
  exx
   srl   d
   rr   e
   sub -1
   jr   nz,putMaskLoop2
putMaskSkip1:
   ld   a,(hl)
   exx
   and e
   exx
   or   d
   ld   (hl),a
   inc   hl
   ld   a,(hl)
   exx
   and     d
   exx
   or   e
   ld   (hl),a
   ld   de,00Bh
   add   hl,de
   inc   ix
   djnz   putMaskLoop1
   ret
However, the reason they had to resort to the shadow registers was due to the sprite format. Instead of keeping the mask and the sprite data in two different chunks of memory, you can interleave them and avoid having to calculate another pointer. Doing it this way, I was able to save 17 more bytes and make it even faster:
putsprite_masked:
;Inputs:
;   (A,L) = (x,y)
;   B is height
;   IX points to the sprite data
;       first byte is the data
;       second byte is mask
;       continues, alternating like this.
;Outputs:
;   Mask is ANDed to the buffer, then data is ORed on top of that.
;Destroys:
;Notes:
;   To set a pixel...
;     black: mask is any, data is 1
;     white: mask is 0, data is 0
;     clear: mask is 1, data is 0 (keeps the data from the buffer)
;This routine is free to use :)
;65 bytes (or 66 bytes if gbuf is not located at 0x**40
  ld e,l
  ld h,0
  ld d,h
  add hl,hl
  add hl,de
  add hl,hl
  add hl,hl
  ld e,a
  and 7
  ld c,a
  inc a
  rra
  rra
  rra
  ld e,a
  ld d,plotSScreen>>8
#else
  rra
  rra
  rra
  ld e,a
  add hl,de
  ld de,plotSScreen
#endif
  add hl,de
putsprite_masked_loop:
  push bc
  xor a
  ld   d,(ix)
  ld   e,a
  sub c
  ld b,c
  ld c,$FF
  inc ix
  ld a,(ix)
  jr   z,putsprite_masked_rotdone
putsprite_masked_rot:
  scf
  rra
  rr c
  srl   d
  rr   e
  djnz putsprite_masked_rot
putsprite_masked_rotdone:
  and (hl)
  or   d
  ld   (hl),a
  inc   hl
  ld   a,(hl)
  and c
  or   e
  ld   (hl),a
  ld c,11
  add   hl,bc
  inc   ix
  pop bc
  djnz   putsprite_masked_loop
  ret
We can save even more if we don't have to rotate in '1' bits into the mask, but this requires us to use a non-traditional masking method (but better in my opinion). We can OR the mask, then XOR the sprite data. This actually gives us an additional option for masking, too. Instead of black/white/clear, we can get black/white/clear/invert. See the 'Notes' section in the code below for the rules for generating a sprite:
putsprite_masked:
;Inputs:
;   (A,L) = (x,y)
;   B is height
;Outputs:
;   Mask is ORed to the buffer, then data is XORed on top of that.
;Destroys:
;Notes:
;   To set a pixel...
;     black: mask is 1, data is 0
;     white: mask is 1, data is 1
;     clear: mask is 0, data is 0 (keeps the data from the buffer)
;     invert: mask is 0, data is 1 (inverts the data from the buffer)
;63 bytes (or 64 bytes if gbuf is not located at 0x**40
  ld e,l
  ld h,0
  ld d,h
  add hl,hl
  add hl,de
  add hl,hl
  add hl,hl
  ld e,a
  and 7
  ld c,a
  inc a
  rra
  rra
  rra
  ld e,a
  ld d,plotSScreen>>8
#else
  rra
  rra
  rra
  ld e,a
  add hl,de
  ld de,plotSScreen
#endif
  add hl,de
  push bc
  xor a
  ld d,(ix)
  ld e,a
  or c
  ld b,c
  ld c,e
  inc ix
  ld a,(ix)
  rra
  rr c
  srl d
  rr e
  or (hl)
  xor d
  ld (hl),a
  inc hl
  ld a,(hl)
  or c
  xor e
  ld (hl),a
  ld c,11
  add hl,bc
  inc ix
  pop bc
  ret
In these two routines, note that I organize it with data first, then mask. In many cases, it could be cheaper for other operations if you put it in mask-data order. Since we are using the index registers to get the data, it's easy enough to swap the formats Smile
Big Sprites
I also made some "bigsprite" routines! These do have clipping, too. First, they use some common subroutines for computing masks and performing most of the clipping and shifting:
;133 bytes total
;This is made by Zeda, feel free to use it for whatever.
;Takes inputs for a big sprite and sets up masks and clipping
;requires 4 bytes of temporary RAM, but doesn't use SMC
spritetmp = 8000h     ;relocate this as needed! Just need 4 bytes.
sprite_width  = spritetmp+0
sprite_x      = spritetmp+1
sprite_mask0  = spritetmp+2
sprite_mask1  = spritetmp+3
bigsprite_subroutine:
;Inputs:
;     B is the X-coordinate
;     C is the Y-Coordinate
;     DE points to the sprite
;     H is the height
;     L is the width in bytes
;Outputs:
;   carry flag is set if okay to draw, nc if out-of-bounds.
;   B is height.
;   C is width.
;   HL points to the byte to start drawing at.
;   DE points to where to start sourcing the sprite data
;   (sprite_width) is the width of the sprite in bytes
;   (sprite_x) is the intitial x coordinate to begin drawing at
;   (sprite_mask0) is the left mask
;   (sprite_mask1) is the right mask
;92 bytes
;First check if the sprite is on-screen in the horizontal direction
  ld a,c
  cp 64
  jr c,+_
  add a,h
  ret nc
  ld h,a
  push hl
  xor a
  ld h,a
  sub c
  ex de,hl
  add hl,de
  dec a
  jr nz,$-2
  ex de,hl
  pop hl
  xor a
  ld c,a
_:
;Next check h+c<=64
  ld a,64
  sub c
  cp h
  jr nc,+_
  ld h,a
_:
;Make sure the height is not now 0
  ld a,h
  or a
  ret z
;Save the width and height of the sprite
  push hl               ;height,width
  ld h,b
  ld (sprite_width),hl  ;x,width
  push de               ;sprite pointer
;Set up a pointer to the routine for shifting the  routine for shifting the sprite data
  ld ixh,rshiftHA_7>>8
  ld a,h
  cpl
  and 7
  ld l,a
  add a,a
  add a,l
  add a,rshiftHA_7&255
  ld ixl,a
#if (rshiftHA_7&255)>234
  jr nc,$+4
  inc ixh
#endif
  ld a,b
  and 7
  ld de,spritemask
  add a,e
  ld e,a
#if spritemask&255>248
  jr nc,$+3
  inc d
#endif
  ld a,(de)
  ld (sprite_mask0),a
  cpl
  ld (sprite_mask1),a
  ld a,c
  add a,a
  sbc a,a
  ld h,a
  ld a,b
  ld b,h
  ld l,c
  add hl,hl
  add hl,bc
  add hl,hl
  add hl,hl
  ld c,a
  add a,a
  sbc a,a
  ld b,a
  ld a,c
  sra c
  sra c
  sra c
  add hl,bc
  ld bc,plotSScreen
  add hl,bc
  pop de
  pop bc
  ;B is height
  ;C is width
  ex de,hl
  scf
  ret
rshiftHA_7:
  rr h \ rra
  rr h \ rra
  rr h \ rra
  rr h \ rra
  rr h \ rra
  rr h \ rra
  rr h \ rra
  ex de,hl
  ld e,a
  ret
spritemask:
  .db $00,$80,$C0,$E0,$F0,$F8,$FC,$FE
call_ix:
  jp (ix)
Then you can draw a big sprite with OR logic:
bigsprite_OR:
;Inputs:
;     H is the height
;68 bytes
;Set up the clipping
  call bigsprite_subroutine
  ret nc
bigsprite_OR_loop:
  push bc   ;height,width
  push de   ;gbuf ptr
  push hl   ;sprite data pointer
  ld a,(sprite_x)
  ld c,a
  add a,8
  ld (sprite_x),a
spriteloop_OR:
  push bc
  push hl
  ld h,(hl)
  xor a
  call call_ix
  ld a,c
  cp 96
  jr nc,+_
  ld a,(hl)
  or d
  ld (hl),a
  ld a,c
_:
  inc hl
  add a,8
  cp 96
  jr nc,+_
  ld a,(sprite_mask1)
  ld a,(hl)
  or e
  ld (hl),a
_:
  ld bc,11
  add hl,bc
  ex de,hl
  pop hl
  ld a,(sprite_width)
  ld c,a
  add hl,bc
  pop bc
  djnz spriteloop_OR
  pop hl
  inc hl
  pop de
  inc de
  pop bc
  dec c
  jr nz,bigsprite_OR_loop
  ret
Or draw with XOR logic:
bigsprite_XOR:
;Inputs:
;     H is the height
;68 bytes
  ret nc
bigsprite_XOR_loop:
  push de   ;gbuf ptr
  ld a,(sprite_x)
  ld c,a
  add a,8
  ld (sprite_x),a
spriteloop_XOR:
  push bc
  push hl
  ld h,(hl)
  xor a
  call call_ix
  ld a,c
  cp 96
  jr nc,+_
  ld a,(hl)
  xor d
  ld (hl),a
  ld a,c
_:
  inc hl
  add a,8
  cp 96
  jr nc,+_
  ld a,(sprite_mask1)
  ld a,(hl)
  xor e
  ld (hl),a
_:
  ld bc,11
  add hl,bc
  ex de,hl
  pop hl
  ld a,(sprite_width)
  ld c,a
  add hl,bc
  pop bc
  djnz spriteloop_XOR
  pop hl
  inc hl
  pop de
  inc de
  pop bc
  dec c
  jr nz,bigsprite_XOR_loop
  ret
Or draw with AND logic:
bigsprite_AND:
;Inputs:
;     H is the height
;69 bytes
  ret nc
bigsprite_AND_loop:
  push de   ;gbuf ptr
  ld a,(sprite_x)
  ld c,a
  add a,8
  ld (sprite_x),a
spriteloop_AND:
  push bc
  push hl
  ld h,(hl)
  scf \ sbc a,a
  call call_ix
  ld a,c
  cp 96
  jr nc,+_
  ld a,(hl)
  and d
  ld (hl),a
  ld a,c
_:
  inc hl
  add a,8
  cp 96
  jr nc,+_
  ld a,(sprite_mask1)
  ld a,(hl)
  and e
  ld (hl),a
_:
  ld bc,11
  add hl,bc
  ex de,hl
  pop hl
  ld a,(sprite_width)
  ld c,a
  add hl,bc
  pop bc
  djnz spriteloop_AND
  pop hl
  inc hl
  pop de
  inc de
  pop bc
  dec c
  jr nz,bigsprite_AND_loop
  ret
Or draw with Erase logic:
bigsprite_Erase:
;Inputs:
;     H is the height
;67 bytes
  ret nc
bigsprite_Erase_loop:
  push de   ;gbuf ptr
  ld a,(sprite_x)
  ld c,a
  add a,8
  ld (sprite_x),a
spriteloop_Erase:
  push bc
  push hl
  ld h,(hl)
  xor a
  call call_ix
  ld a,c
  cp 96
  jr nc,+_
  ld a,d
  cpl
  and (hl)
  ld (hl),a
  ld a,c
_:
  inc hl
  add a,8
  cp 96
  jr nc,+_
  ld a,e
  cpl
  and (hl)
  ld (hl),a
_:
  ld bc,11
  add hl,bc
  ex de,hl
  pop hl
  ld a,(sprite_width)
  ld c,a
  add hl,bc
  pop bc
  djnz spriteloop_Erase
  pop hl
  inc hl
  pop de
  inc de
  pop bc
  dec c
  jr nz,bigsprite_Erase_loop
  ret
Or draw with Overwrite logic:
bigsprite_Overwrite:
;Inputs:
;     H is the height
;71 bytes
  ret nc
bigsprite_Overwrite_loop:
  push de   ;gbuf ptr
  ld a,(sprite_x)
  ld c,a
  add a,8
  ld (sprite_x),a
spriteloop_Overwrite:
  push bc
  push hl
  ld h,(hl)
  xor a
  call call_ix
  ld a,c
  cp 96
  jr nc,+_
  ld a,(sprite_mask0)
  and (hl)
  or d
  ld (hl),a
  ld a,c
_:
  inc hl
  add a,8
  cp 96
  jr nc,+_
  ld a,(sprite_mask1)
  and (hl)
  or e
  ld (hl),a
_:
  ld bc,11
  add hl,bc
  ex de,hl
  pop hl
  ld a,(sprite_width)
  ld c,a
  add hl,bc
  pop bc
  djnz spriteloop_Overwrite
  pop hl
  inc hl
  pop de
  inc de
  pop bc
  dec c
  jr nz,bigsprite_Overwrite_loop
  ret
EDIT: Formatting and added bigsprite routines
Here is a useful routine! It is a scrollable menu that can have multiple titles, but works on the graph screen.
Feel free to use any of these!
Scrollable Menu With Multiple Headings
;This routine is a little complicated to set up!
;It is intended to work in a variety of environments, so it needs a few
;variables, and 17 bytes of RAM.
;First, you'll need to define the routine that you are using to display text.
;#define Text() bcall(_VPutS)
;How tall is the text?
;#define TEXT_HEIGHT 6
;Are text coords stored with the upper byte as Y and lower byte as X ?
;If so, uncomment the following! You'll want this for VPutS, for example.
;#define TEXTCOORD_YX      ;define if textcoord is Y then X (TI-OS is Y then X for small font, large font and some custom text routines use the opposite)
;Where are the text coordinates stored?
;textcoord       = penCol
;How are you updating the LCD? Expect interrupts to be on, but you may turn them off.
; #macro LCD_Update()
;   di
;   call UpdateLCD
; #endmacro
;We need to draw rectangles, so what routines do you want to use?
;Inputs are (B,C)=(x,y), and (D,E)=(width,height)
; #macro rect_OR()
;   ;Draw a black rectangle
;   ld hl,plotSScreen
;   call rectOR
; #endmacro
; #macro rect_XOR()
;   ;Draw an inverted rectangle
;   ld hl,plotSScreen
;   call rectXOR
; #endmacro
; #macro rect_Erase()
;   ;Draw a white rectangle
;   ld hl,plotSScreen
;   call rectErase
; #endmacro
;Now define where vars are located, 17 bytes required in all.
;textbox_top     = $8000
;textbox_left    = textbox_top+1    ;needs to follow textbox_top
;textbox_bottom  = $8002
;textbox_right   = textbox_bottom+1 ;needs to follow textbox_bottom
;menucallptr     = $8004
;menutop         = $8006
;menucur         = $8008
;menuselection   = $800A
;menuheader_ptr  = $800C
;menuheader_coord= $800E
;menuheader_cur  = $8010   ;1 byte
menu:
;Input:
;   (B,C) = (x,y)
;   (D,E) = (width,height)
;   HL points to the header
;   IX points to the get/select code
;     If you are using the TI-OS VPutS routine, you'll need to have the textWrite flag set in sGrFlags
;Notes:
;   The header is set up as follows:
;       .db number_of_titles
;       .db "title 0",0
;       .db "title 1",0
;       .db "title 2",0
;   The get/select code is passed the following information:
;       A is the index of the current title (0 is the first, 1 is the second, etc.)
;       HL is the index of the currently highlighted item
;       carry flag is reset if it needs to return a pointer to the string for the element
;           Return carry flag as set if the element is out-of-bounds.
;       carry flag is set if it needs to return a pointer to the data for the element
  ld (menucallptr),ix
;save box dimensions
  push bc
;Save the pointer to the menu headers field
  ld (menuheader_ptr),hl
;Set the menu header to header 0
  xor a
  ld (menuheader_cur),a
;establish the bottom and right edges of the textbox
  ld a,c
  add a,e
  ld (textbox_bottom),a
  ld a,b
  add a,d
  ld (textbox_right),a
; Draw the rectangle for the menu. Black border, white fill.
  rect_OR()
; Display the header
; get coords
  pop hl
  inc h
  inc h
  inc l
  push hl
#ifdef TEXTCOORD_YX
  ;need to swap the coords order
  ld a,h
  ld h,l
  ld l,a
#endif
  ld (menuheader_coord),hl
  call draw_header
  pop bc
;Before we do too much, let's establish the top-left textbox boundaries.
  ld a,TEXT_HEIGHT+2
  add a,c
  ld c,a
  ld (textbox_top),bc
  call reset_menu_cursor
; Now we have drawn the menu box, we have to populate it.
; We'll call a routine to get the n-th string to be displayed.
; Stop fetching once the next item would go at or past textbox_bottom.
; Draw at least one item.
menu_render:
;Restore the text coordinates top
  ld hl,(textbox_top)
#ifndef TEXT_PAD_TOP
  inc l
#endif
#ifdef TEXTCOORD_YX
  ld a,h
  ld h,l
  ld l,a
#endif
  ld (textcoord),hl
;rerender the items
  call menu_render_sub
menu_render_0:
;highlight the current option
  ld bc,(menuselection)
  ld hl,(textbox_bottom)
  ld a,h
  sub b
  ld d,a
  ld e,TEXT_HEIGHT+1
  dec d
  push de
  push bc
  rect_XOR()
  LCD_Update()
  pop bc
  pop de
  rect_XOR()
;wait for a keypress
_:
  in a,(4)
  and 8
  jr z,menu_get_select_err
  call getKeyDebounce
  or a
  jr z,-_
  cp 9
  scf
  cp 15
  call menu_arrow
  jr c,menu_render_0
  jr menu_render
menu_get_select:
  ld hl,(menucallptr)
  ld a,(menuheader_cur)
  jp (hl)
menu_render_sub:
; need to clear out the textbox
  ld bc,(textbox_top)
  ld a,h
  sub b
  ld d,a
  ld a,l
  sub c
  ld e,a
  dec e
  dec b
  rect_Erase()
  xor a
  ld bc,(menutop)
menu_render_sub_loop:
  push bc
  call menu_get_select
  pop bc
  ret c
  ld de,(textcoord)
  push de
  Text()
  pop de
#ifdef TEXTCOORD_YX
  ld a,TEXT_HEIGHT
  add a,d
  ld d,a
  ld a,(textbox_bottom)
#ifdef TEXT_PAD_TOP
  sub TEXT_HEIGHT+2
#else
  sub TEXT_HEIGHT+1
#endif
  cp d
#else
  ld a,TEXT_HEIGHT
  add a,e
  ld e,a
#ifdef TEXT_PAD_TOP
  sub TEXT_HEIGHT+2
#else
  sub TEXT_HEIGHT+1
#endif
  cp e
#endif
  ld (textcoord),de
  inc bc
  jr nc,menu_render_sub_loop
  ret
menu_get_select_err:
;return a null pointer.
;A=0, HL=0
  xor a
  ld h,a
  ld l,a
  ret
menu_arrow:
;check arrow keys
  dec a
  jr z,menu_down
  dec a
  jr z,menu_left
  dec a
  jr z,menu_right
  add a,-1      ;sets the carry flag if it is not a keypress
  ret nz
;if would select oob
;   if next element exists
;       increment the menutop and rerender the menu
;else
;   move menuselection
menu_up:
  or a
  ld bc,(menucur)
  dec bc
  push bc
  pop hl
  ret c
  ld (menucur),hl
  ld a,(menuselection)
  ld hl,(textbox_top)
  cp l
  jr z,+_
  sub TEXT_HEIGHT
  ld (menuselection),a
  scf
  ret
_:
  ld hl,(menutop)
  dec hl
  ld (menutop),hl
  ret
menu_down:
  or a
  ld bc,(menucur)
  inc bc
  push bc
  pop hl
  ret c
  ld (menucur),hl
  add a,TEXT_HEIGHT+TEXT_HEIGHT+1
  cp l
  jr nc,+_
  sub TEXT_HEIGHT+1
  scf
  ret
_:
  ld hl,(menutop)
  inc hl
  ld (menutop),hl
  ret
;These change to the next menu header
menu_left:
  dec a
  jr +_
menu_right:
  inc a
_:
draw_header:
;Set up textcoord
  ld hl,(menuheader_coord)
#ifdef TEXTCOORD_YX
  inc h
#else
  inc l
#endif
#endif
  ld (textcoord),hl
;Need to erase the current header area
#ifdef TEXTCOORD_YX
  ld b,l
  ld c,h
#else
  ld b,h
  ld c,l
#endif
  dec c
#endif
  ld de,(textbox_bottom)
  ld a,d
  sub b
  ld d,a
  dec b
  ld e,TEXT_HEIGHT+1
  rect_Erase()
;Verify that the header element is valid, wrap if needed
  ld hl,(menuheader_ptr)
  cp (hl)
  jr c,+_
  inc a
  jr nz,$+5
  ;cycle to the last header
  ld a,(hl)
  dec a
  .db $FE
  ;cycle to the first header
  xor a
_:
;A is the header to seek
  ld bc,0   ;using CPIR, want to make sure it doesn't exit too soon!
  inc hl    ;point to the first header
  or a
  jr draw_header_loopend
draw_header_loop:
  push af
  xor a
  cpir
  pop af
  dec a
draw_header_loopend:
  jr nz,draw_header_loop
;now draw the header
  Text()
  or a
  ret
reset_menu_cursor:
  ld hl,(textbox_top)
  dec h
  ld (menuselection),hl
  ld hl,0
  ld (menutop),hl
  ld (menucur),hl
  ret
In my test, for example, I define these:
#define K_DELAY_DEFAULT 13
#define K_DELAY_ACCEL 3
#define TEXTCOORD_YX      ;comment if textcoord is X then Y (TI-OS is Y then X)
#define TEXT_PAD_TOP    ;comment if there is not a row of padding above the text
textcoord       = penCol
textbox_top     = $8000
menucallptr     = $8004
menutop         = $8006
menucur         = $8008
k_save          = $8011   ;3 bytes
#macro rect_OR()
  ld hl,plotSScreen
  call rectOR
#endmacro
#macro rect_XOR()
  ld hl,plotSScreen
  call rectXOR
#endmacro
#macro rect_Erase()
  ld hl,plotSScreen
  call rectErase
#endmacro
#macro LCD_Update()
 bcall(_GrBufCpy)
#endmacro
And I include the following routines for getkey and rectangle drawing, and converting ints to a string:
getKeyDebounce:
k_count     = k_save+1
k_delay     = k_count+1
  ei
  halt
  call GetKey
  ld hl,k_save
  cp (hl)
  jr nz,newkeypress
;if the keys match, decrement k_count
  inc hl
  dec (hl)
  jr z,+_
  xor a
  ret
_:
  inc hl
  ld a,(hl)
  sub K_DELAY_ACCEL+1
  jr nc,+_
  xor a
_:
  inc a
  ld (hl),a
  dec hl
  ld (hl),a
  dec hl
  ld a,(hl)
  ret
newkeypress:
  ld (hl),a
  inc hl
  ld (hl),K_DELAY_DEFAULT
  inc hl
  ret
getKey:
;Input:
;   Expects that interrupts are either off or won't interfere with port 1.
;Outputs:
;   A is a value from 0 to 56 that is the keypress
;Destroys:
;   C, DE
;     C is actually 1
;     E is actually a copy of the keypress
  ld c,1
  ld de,$FEFF
_:
  out (c),d
  rlc d
  ret nc
  inc e
  in a,(1)
  inc a
  jr z,-_
  dec a
  sla e
  sla e
  sla e
_:
  inc e
  rra
  jr c,-_
  ld a,e
  ret
rectOR:
;  (B,C) = (x,y) signed
;  (D,E) = (w,h) unsigned
;  HL points to buf
    push hl
    call rectSub
    pop ix
    ret nc
    ex de,hl
    add ix,de
    ex de,hl
    push ix
    pop hl
    dec b
    jp m,orrect0
    inc b
or_rect_loop:
    push bc
    push hl
    ld a,(hl) \ or d \ ld (hl),a \ inc hl
    dec b
    jr z,$+8
    ld c,-1
    ld (hl),c \ inc hl \ djnz $-2
    ld a,(hl) \ or e \ ld (hl),a
    ld bc,12
    pop hl
    add hl,bc
    pop bc
    dec c
    jr nz,or_rect_loop
    ret
orrect0:
    ld a,d
    and e
    ld b,c
    ld c,a
    ld de,12
    ld a,c
    or (hl)
    ld (hl),a
    add hl,de
    djnz $-4
    ret
rectXOR:
;  HL points to buf
    push hl
    call rectSub
    pop ix
    ret nc
    ex de,hl
    add ix,de
    ex de,hl
    push ix
    pop hl
    dec b
    jp m,xorrect0
    inc b
xor_rect_loop:
    push bc
    push hl
    ld a,(hl) \ xor d \ ld (hl),a \ inc hl
    dec b
    jr z,$+8
    ld a,(hl) \ cpl \ ld (hl),a \ inc hl \ djnz $-4
    ld a,(hl) \ xor e \ ld (hl),a
    ld bc,12
    pop hl
    add hl,bc
    pop bc
    dec c
    jr nz,xor_rect_loop
    ret
xorrect0:
    ld a,d
    and e
    ld b,c
    ld c,a
    ld de,12
    ld a,c
    xor (hl)
    ld (hl),a
    add hl,de
    djnz $-4
    ret
rectErase:
;  HL points to buf
    push hl
    call rectSub
    pop ix
    ret nc
    ex de,hl
    add ix,de
    ex de,hl
    push ix
    pop hl
    ld a,d
    cpl
    ld d,a
    ld a,e
    cpl
    ld e,a
    dec b
    jp m,eraserect0
    inc b
erase_rect_loop:
    push bc
    push hl
    ld a,(hl) \ and d \ ld (hl),a \ inc hl
    dec b
    jr z,$+7
    xor a
    ld (hl),a \ inc hl \ djnz $-2
    ld a,(hl) \ and e \ ld (hl),a
    ld bc,12
    pop hl
    add hl,bc
    pop bc
    dec c
    jr nz,erase_rect_loop
    ret
eraserect0:
    ld a,d
    xor e
    ld b,c
    ld c,a
    ld de,12
    ld a,c
    and (hl)
    ld (hl),a
    add hl,de
    djnz $-4
    ret
rectsub:
;(B,C) = (x,y) signed
;(D,E) = (w,h) unsigned
;Output:
;  Start Mask  D
;  End Mask    E
;  Byte width  B
;  Height      C
;  buf offset  HL
  bit 7,b
  jr z,+_
  ;Here, b is negative, so we have to add width to x.
  ;If the result is still negative, the entire box is out of bounds, so return
  ;otherwise, set width=newvalue,b=0
  ld a,d
  add a,b
  ret nc
  ld d,a
  ld b,0
_:
  bit 7,c
  jr z,+_
  ld a,e
  add a,c
  ret nc
  ld e,a
  ld c,0
_:
;We have clipped all negative areas.
;Now we need to verify that (x,y) are on the screen.
;If they aren't, then the whole rectangle is off-screen so no need to draw.
  ld a,b
  cp 96
  ret nc
  ld a,c
  cp 64
  ret nc
;Let's also verfiy that height and width are non-zero:
  ld a,d
  or a
  ret z
  ld a,e
  or a
  ret z
;Now we need to clip the width and height to be in-bounds
  add a,c
  cp 65
  jr c,+_
  ;Here we need to set e=64-c
  ld a,64
  sub c
  ld e,a
_:
  ld a,d
  add a,b
  cp 97
  jr c,+_
  ;Here we need to set d=96-b
  ld a,96
  sub b
  ld d,a
_:
;B is starting X
;C is starting Y
;D is width
;E is height
  push bc
  ld l,b
  ld a,b
  and 7
  ld b,a
  ld a,-1
  jr z,+_
  rra \ djnz $-1
_:
  inc a
  cpl
  ld h,a    ;start mask
  ld a,l
  add a,d
  and 7
  ld b,a
  ld a,-1
  jr z,+_
  rra \ djnz $-1
_:
  inc a
  ld l,a  ;end mask
  ex (sp),hl
  ld a,h
  ld h,b
  add hl,hl
  add hl,bc
  add hl,hl
  add hl,hl
  ld b,a
  rrca
  rrca
  rrca
  and 31
  add a,l
  ld l,a
  jr nc,$+3
  inc h
;B is the starting x, D is width
;Only A,B,D,E are available
  ld a,b
  add a,d
  and $F8
  ld d,a
  ld a,b
  and $F8
  ld b,a
  ld a,d
  sub b
  rrca
  rrca
  rrca
  ld b,a
  ld c,e
  pop de
  scf
  ret
uitoa_16:
;Input:
;Output:
  push de
  push bc
  push af
  ex de,hl
  ld bc,-10000
  ld a,'0'-1
  ld (de),a
  inc de
  ld bc,1000
  ld a,'9'+1
  ld (de),a
  inc de
  ld bc,-100
  ld a,'0'-1
  ld (de),a
  inc de
  ld a,l
  ld h,'9'+1
  add a,'0'
  ex de,hl
  ld (hl),d
  inc hl
  ld (hl),a
  inc hl
  ld (hl),0
;Now strip the leading zeros
  ld c,-6
  add hl,bc
  ld a,'0'
;Make sure that the string is non-empty!
  ld a,(hl)
  or a
  jr nz,+_
  dec hl
_:
  pop af
  pop bc
  pop de
  ret
And I call it with:
  ld ix,menulookup
  ld bc,$1C02
  ld de,$283B
  ld hl,menhead
  set textWrite, (IY + sGrFlags)
  xor a
  ld (kbdScanCode),a
  call menu
  xor a
  ld (kbdScanCode),a
  res textWrite, (IY + sGrFlags)
menhead:
  .db 3
  .db "Strings",$05,0
  .db $CF,"Pictures",$05,0
  .db $CF,"GDB",0
menulookup:
  jr c,menu_select
menu_get:
  ld d,a
  ld a,b
  add a,-1
  ret c
  inc bc
  ld a,c
  sub 10
  jr nz,+_
  ld b,a
  ld c,a
_:
  push bc
  ld hl,s_str
  dec d
  jr nz,+_
  ld hl,s_pic
_:
  dec d
  jr nz,+_
  ld hl,s_GDB
_:
  ld de,OP1
  ldi
  ldi
  ldi
  ex de,hl
  pop de
  push hl
  call uitoa_16
  pop de
  ;de is where to write
  call strcopy
  ld hl,OP1
  xor a
  ret
menu_select:
  ld hl,(menucur-1)
  ld l,$AA
  dec a \ jr nz,$+4 \ ld l,$60
  dec a \ ret nz \ ld l,$61
  ret
s_str: .db "Str"
s_pic: .db "Pic"
s_GDB: .db "GDB"
It's a lot of overhead if your project doesn't need those rectangle routines or the getkey routines, but, you can modify those to use the built-in routines (it's just smoother this way). Either way, check out the example:
EDIT: Updated to define if there is padding above the text or not. Here is a screenshot of using the large font (save bandwidth, don't need a gif for this one Razz)
The scrollable menu looks great!
sqrtHLIX
This is a 32-bit integer square root routine. It uses the unrolled sqrtHL routine at the bottom of this post as a subroutine. Note that this routine makes use of the undocumented SLL instruction, and so you might need to modify it for some devices. You can replace it with scf \ rl * at the cost of one byte and 4cc.
sqrtHLIX:
;Input: HLIX
;speed: 751+6{0,6}+{0,3+{0,18}}+{0,38}+sqrtHL
;min: 1103
;max: 1237
;avg: 1165.5
;166 bytes
  call sqrtHL   ;expects returns A as sqrt, HL as remainder, D = 0
  add a,a
  ld e,a
  rl d
  ld a,ixh
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  ld a,ixl
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
  sll e \ rl d
  add a,a \ adc hl,hl
  add a,a \ adc hl,hl
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
_:
  inc e
sqrt32_iter15:
  add a,a
  adc hl,hl
  add a,a
  adc hl,hl       ;This might overflow!
  jr c,sqrt32_iter15_br0
  sbc hl,de
  jr nc,+_
  add hl,de
  dec e
  jr sqrt32_iter16
sqrt32_iter15_br0:
  or a
  sbc hl,de
_:
  inc e
sqrt32_iter16:
  add a,a
  ld b,a        ;either 0x00 or 0x80
  adc hl,hl
  rla
  adc hl,hl
  rla
;AHL - (DE+DE+1)
  sbc hl,de \ sbc a,b
  inc e
  or a
  sbc hl,de \ sbc a,b
  ret p
  add hl,de
  adc a,b
  dec e
  add hl,de
  adc a,b
  ret
This routine outputs a remainder, which is useful to have on hand if you want to build higher precision routines. The two routines combined use 260 bytes in total, but that's the price of quick maffs.
Here is a neat circle routine that I made:
;Written by Zeda Thomas, free to use.
;This draws a circle centered at 8-bit coordinates and with radius up to 127.
;IX points to a `plot` routine that takes (B,C)=(x,y) as input and does something
;with it, like plot the pixel a certain color, or plot a "big" pixel, or whatever.
;   plot
;     Takes coordinates, (B,C) = (x,y) and plots the point.
;For example, on the TI-83+/84+/SE the plot routine might look like:
; plot:
;   call getpixelloc
;   ret nc            ;Exit if the coordinates are out-of-bounds
;   or (hl)
;   ld (hl),a
;   ret
; Required subroutines:
;     call_ix:
;       jp (ix)
circle:
;Input:
; (B,C) is the center (x,y)
; D is the radius, unsigned, less than 128 (0 or greater than 128 just quits).
; IX points to a `plot` routine that takes (B,C)=(x,y) as input.
  ld a,d
  add a,a
  ret c
  ret z
  ld l,d
  dec a
  ld e,a
  dec a        ;if the pixel is only 1 wide, just plot the point
  jp z,call_ix ;Jump to the plot routine
  xor a
  ld h,-1
  ld d,1
  scf     ;skip the first plot
circleloop:
  call nc,plot4
  inc h
  sub d
  inc d
  inc d
  jr nc,circleloop
_:
  dec l
  call plot4
  add a,e
  dec e
  ret z
  dec e
  jr nc,-_
  jp circleloop
plot4:
;BC is center
;HL is x,y
  push de
  push af
  push hl
  push bc
;If H is 0, or L is 0, we need to draw only half
  push hl
  ld a,b
  sub h
  ld b,a
  add a,h
  add a,h
  ld h,a
  ld a,c
  sub l
  ld c,a
  add a,l
  add a,l
  ld l,a
;B is x0-x
;C is y0-y
;H is x0+x
;L is y0+y
;plot(x0-x,y0-y)
;plot(x0+x,y0+y)
  push bc
  push hl
  call call_ix    ;call the plot routine
  pop bc
  push bc
;now swap the y coords
  pop hl
  pop bc
  ld a,l
  ld l,c
  ld c,a
  pop de
  xor a
  cp d
  jr z,+_
  cp e
  jr z,+_
;plot(x0-x,y0+y)
;plot(x0+x,y0-y)
  push hl
  pop bc
_:
  pop bc
  pop hl
  pop af
  pop de
  ret
The really cool feature about this is that you can define a custom plot routine pointed to by IX, so it isn't TI-specific, and you can do all sorts of wonky things like:
Draw 2x2 pixels:
;calling with `ld ix,pixelOn_2x2`
pixelOn_2x2:
  sla b
  ret c
  sla c
  ret c
  push bc
  call pixelOn
  pop bc
  inc b
  push bc
  call pixelOn
  pop bc
  inc c
  push bc
  call pixelOn
  pop bc
  dec b
  jp pixelOn
Or draw a circle whose "pixels" are circles:
;calling with `ld ix,pixelOn_circle`
pixelOn_circle:
  ld a,b
  cp 32
  ret nc
  add a,a
  add a,a
  ld b,a
  ld a,c
  cp 32
  ret nc
  add a,a
  add a,a
  ld c,a
  ld d,4
  push ix    ;need to save IX!
  ld ix,pixelOn
  call circle
  pop ix
  ret
EDIT: I inlined some subroutines because there was no reason to have them called. It was a waste of clock cycles and space!
EDIT: Have a separate, filled rectangle routine!
Note that if you pass the same arguments as the regular circle routine, this only draws the inside part and skips the border.
;This draws the fill of a circle centered at 8-bit coordinates and with radius
;up to 127.
;IX points to a `horizontal line` routine that takes E=x, A=y, D=width as input
;and does something with it, like plot a horizontal line.
; For example, on the ti-83+/84+/SE calculators, you might have:
;     horizontal_line:
;       ld b,e
;       ld c,a
;       ld e,1
;       ld hl,gbuf
;       jp rectOR
;     call_ix:
;       jp (ix)
filledcircle:
;Input:
  ld a,d
  add a,a
  ret c
  ret z
  ld l,d
  dec a
  ld e,a
  xor a
  ld h,-1
  ld d,1
filledcircleloop:
  ; call c,fillcircle_plot
  inc h
  sub d
  inc d
  inc d
  jr nc,filledcircleloop
_:
  dec l
  call fillcircle_plot
  add a,e
  dec e
  ret z
  dec e
  jr nc,-_
  jp filledcircleloop
fillcircle_plot:
  inc h
  dec h
  ret z
  push hl
  push de
  push bc
  push af
  dec h
  ld a,b
  sub h
  ld e,a
  ld d,h
  sll d   ;aka `slia`, undocumented
  ld a,l
  or a
  ld h,c
  jr z,+_
  add a,h
  push de
  push hl
  call nz,call_ix
  pop hl
  pop de
_:
  ld a,h
  sub l
  call call_ix
  pop af
  pop bc
  pop de
  pop hl
  ret
Here is an example screenshot of when I used an inverted horizontal line routine:
I have two routines that I am proud of and thought they'd be useful!
Binary Search
Binary Search is an efficient way to search through sorted data. Regardless of the data, the core of the algorithm is the same, so I made a routine that is the core algorithm!
All you have to do is pass a pointer to a routine in IX that compares two pieces of data
;Requires `call_ix` routine that looks like:
;   call_ix:
;       jp (ix)
;IX points to a comparison routine that takes as input:
;   HL points to the input element to find
;   DE is the element to compare to
;Outputs are:
;   carry set if the HL element is less than the DE element
;   carry reset if the HL element is greater than or equal to the DE element
;   z set if the HL element is equal to the DE element
;   nz set if the HL element is not equal to the DE element
;This is useful if you have a table of pointers to strings, and want to find a
;string in the array. See the end of this file for an example.
binarysearch:
;This is a general-purpose binary search routine.
;Inputs:
;   BC is the element to find
;   HL is the number of elements
;   IX points to a callback routine that compares the input element
;Outputs:
;   DE is the matching element index
;   z means match found
;   nz means no match
;       In this case, DE is interpreted as where the match should have been
;Destroys:
;   AF, DE
;RAM needed:
;   10 bytes of stack space (4 pushes and a call)
  ld de,-1
binarysearch_loop_inc_lower:
  inc de
binarysearch_loop:
  push hl
  push de
  or a
  sbc hl,de
  jr z,binarysearch_nomatch
  rr h
  rr l
  add hl,de
  ld d,h
  ld e,l
  push hl   ;test index
  push bc   ;input
  ld h,b
  ld l,c
  call call_ix
  pop bc    ;input
  jr nc,binarysearch_input_bigger_or_equal
  pop hl    ;test index is the new upper index
  pop de    ;restore the lower index
  pop af    ;dummy pop
  jr binarysearch_loop
binarysearch_input_bigger_or_equal:
  pop de    ;test index +1 is the new lower index
  pop hl    ;dummy pop
  pop hl    ;restore upper index
  jr nz,binarysearch_loop_inc_lower
  ;a match was found
  ;DE is left as the index
  ret
binarysearch_nomatch:
  pop de    ;lower index
  pop hl    ;upper index (also lower index and test index)
  or 1
  ret
Heapsort
Heapsort is a clever and efficient sorting algorithm. Much like the Binary Search routine above, you pass IX pointing to a routine that actually interprets your data, so this can work on even your weirdest data format. IX points to a routine that either swaps two elements, or compares two elements (based on carry flag passed in).
NOTE: This also includes the heapify routine, used by heapsort. This might also be useful if you only need to arrange data into a heap structure, but don't need to sort.
; This routine requires the following subroutine:
;     call_ix:
;         jp (ix)
; To use SMC, define SMC.
;     #define SMC
; If you are not using SMC, you'll need to define `arraylen` to point
;to 2 bytes of scrap RAM
heapsort:
;Inputs:
;   BC is the size of the array.
;   IX points to the routine that compares or swpas two entries
;     HL is the index of the first element
;     DE is the index of the second element
;     c means swap
;     nc means compare HL to DE
;       Should return:
;         z if they are equal
;         nc if HL>=DE
;         c if HL<DE
;Outputs:
;   The data is sorted.
;Destroys:
;   All
;Notes:
;   You can make the comparison routine work any way that you want :)
;   For example, you can invert the carry flag output to sort descending.
;If the array is size 0 or 1, then it is sorted
    inc b
    dec b
    jr nz,heapsort_heapify
    dec c
    ret z
    inc c
    ret z
heapsort_heapify:
    call heapify
    ld hl,(arraylen)
heapsort_loop:
    dec hl
    ld (arraylen),hl
    push hl
;HL is the last element
    ld de,0
    call heapsort_swap
    ld bc,1
    call propogate
    pop hl
    ld a,h
    or l
    jr nz,heapsort_loop
    ret
heapify:
;Inputs:
;   HL points to the array data
;   BC is the size of the array. NOT GREATER THAN 32767
;   IX points to the routine that compares the values
    ld (arraylen),bc
    srl b
    rr c
_:
    push bc
    call propogate
    pop bc
    dec bc
    ld a,b
    or c
    jr nz,-_
    ret
propogate:
;BC-1 is the parent index
;2BC-1 is the child0 index
;2BC is the child1 index
    sla c
    rl b
    ld d,b
    ld e,c
#ifdef SMC
arraylen=$+1
    ld hl,0
#else
    ld hl,(arraylen)
#endif
    sbc hl,de
    add hl,de
    ret c  ;no children
;z means one child
;compare the two children
    ld h,b
    ld l,c
    dec hl
;HL is the child0 index
;DE is the child1 index
    call nz,heapsort_cmp
    jr nc,+_
    ex de,hl
_:
;parent is (HL+1)>>1
;child is HL
    ld d,h
    ld e,l
    inc hl
    srl h
    rr l
    dec hl
    call heapsort_cmp
    ret nc
    call heapsort_swap
;values heapsort_swapped, now set parent=child+1
    ld b,d
    ld c,e
    inc bc
    jr propogate
heapsort_swap:
;HL and DE are the indices of the elements to heapsort_swap
    push hl
    push de
    scf
    call call_ix
    pop de
    pop hl
    ret
heapsort_cmp:
    push hl
    push de
    or a
    call call_ix
    pop de
    pop hl
    ret
Long post incoming!
rand_ti_float, rand10, rand5
I've long been annoyed about TI's implementation of rand. First, it is so. Freaking. Slow. Plus, the range is pretty limited in that the smallest number it returns is 1/2147483563 =4.6566...*10^-10. In fact, it an only return up to 2147483563 distinct values! (I'm basing this info off of this. It is for the 68k calcs, but I believe I read that the same algorithm is used on the Z80 calcs).
Anyways, I set out to make a better and faster rand for TI Floats after my breakthrough with the rand implementations in z80float. So here is the code:
rand_TI_Float:
;Generates a random TI float at HL
  push hl
  ld de,$8000   ;D is exponent, E is type
get_rand_exponent_loop:
;decrement exponent
  dec d
;if the exponent is -100, underflow to 0.
;I don't think this is possible with this RNG, or even likely to ever happen
;before the universe's heat death with a true RNG, but better to be safe?
;  ld a,d
;  cp 28
;  jp z,SetAnsZero
;save the exponent
  push de
;Generate a uniform random digit on [0,9] as a candidate for our first digit.
  call rand10
;restore the exponent+type
  pop de
;if A is 0, we'll decrement the exponent and find a new candidate for the first
;digit. This is because we need our float to be "normalized" (top digit non-zero)
;This also preserves the uniform distribution for values.
  jr z,get_rand_exponent_loop
  pop hl
  ld (hl),e
  inc hl
  ld (hl),d
  inc hl
;write the first digit
  ld (hl),a
  ld b,13
math_rand_loop:
;now generate subsequent digits
  push bc
  rr b
  ld a,l
  sbc a,255
  ld l,a
  push hl
;generate the next digit
  call rand10
  pop hl
  rld
  pop bc
  djnz math_rand_loop
  ret
I tried to be good with the comments on this code, so I won't go into depth with the algorithm. The main takeaway is that it needs rand10 to return A with a value on [0,9], and as long as the rand10 has a uniform distribution, then the float will return with a uniform distribution on [0,1).
So now we come up to the next challenge: generating a random integer on [0,9]. Well, that's simple! Just generate rand5, an integer on [0,4], then shift in a random bit:
rand10:
;Returns A as a random integer on [0,9]
;Destroys: All
  call rand5  ;return with the top bit of H as a random bit
  sla h
  rla
  ret
Now we need to generate a random number on [0,4], and this is where the fun starts. There are two popular methods, and I'll try to illustrate why they fail. Suppose we have a True RNG that spits out a 0 or 1 with equal probability (for example, flipping a fair coin if that could exist). Just for ease of illustration, let's generate 4 bits and perform rand%5, a common technique. Well, with a True RNG, that means 4 values map to 0 (0, 5, 10, 15), and 3 values map to each of 1, 2, 3, and 4. So this means even with a true RNG, this method will bias the output to 0. Another popular technique is to essentially do int(5*rand). So in this example of generating a 4-bit number, we would do int((5*rand)/16). Well, we run into the same problem where it biases toward a value (in this case it is 0 again).
So how do you mitigate this? Well, if we add more bits, then we shrink the bias. For example with 8 bits, the rand%5 option only biases toward 0 by an extra ~2%. And if we went to 16-bit, the bias would be an extra ~.00763%. And honestly, that can be acceptable. But with only a finite number of bits, it'll never be truly uniform. So we need another approach, one that is finite.
It is worth noting, that if you had to choose from, say, 4 values, then you can always do that with exactly 2 bits. For 8 values, you can do it with exactly 3 bits. With 2^n values, you can do it with exactly n bits. These are finite processes and we like these. In fact, most of the best pseudo-random number generators are really good at providing "random" bits with uniform distribution. So we need a trick to take the ease of generating bits, and using that to make a finite process for rand5.
My approach basically looks at the binary expansion of 1/5, 2/5, 3/5, and 4/5.
   1/5 = .0011001100110011...
   2/5 = .0110011001100110...
   3/5 = .1001100110011001...
   4/5 = .1100110011001100...
So if we generate random bits and I get .001100, then a 0, then we know that no matter what all of the rest of the bits are, the number is less than 1/5, and so int(5*rand) is 0.
By applying similar logic to the rest of the values, we can guarantee a uniform distribution on [0,4]. But there are four cases where this process might continue forever, specifically the cases that are like ...00110011...., but lucky for us, this happens 4/inf= 0% of the time. In fact, on average it takes 4 bits before the algorithm can assert which value to return. The one caveat is that on the Z80, we generally don't have truly random numbers Neutral On the other hand, it is easy enough to generate pseudo-random bits with equal probability Smile
So, without further ado:
rand5:
;Returns A on [0,4], bit 7 of H is random.
;Destroys: All
';NOTE: This expects rand to return 16 random or pseudo-random bits in HL. It does not require rand to preserve any registers.
  call rand
  ld a,h
  and $C0
  push af    ;save the original value
  ld c,a
rand5_start:
  push bc
  call rand
  pop bc
  ld b,15    ;I set this to 15 because I like to guarantee a bit is available for rand10.
rand5_loop:
  ld a,h
  xor c
  jp p,rand5_end
  add hl,hl
  sla c
  jr c,$+4
  set 6,c
  djnz rand5_loop
  jr rand5_start
rand5_end:
  pop af
  rlca
  rlca
  sla h
  adc a,0
  ret
If I use this as my rand routine (a fast xorshift+ generator), then generating a quality, random TI-float on [0,1) with uniform distribution seems to take under 13400cc. This translates to over 1100 TI floats per second at 15MHz). You can also heavily modify the rand5 routine to keep track of it's internal state (specifically HL [random bits] and B [counter]) and only call rand when HL runs out of bits. When I did this (and used a slightly faster RNG), I was able to get over 1960 random floats per second.
For reference, the OS _Random bcall can run nearly 71 times per second, which is about 15.5 times slower than the code above, and 27.5 times slower than a heavily optimized version.
rand8 (very fast)
I have a beautiful RNG. It is 47cc and 10 bytes.
;HL must be non-zero
  add hl,hl
  sbc a,a
  and %00101101
  xor l
  ld l,a
  ld a,r
  add a,a   ;Because R is a 7-bit register
  add a,h
;HL is the new seed
;A is the output, or AL for 16 bits.
Upon first inspection, that use of the R register might look like it is being used as a source of randomness, but it is in fact being used as a cheap counter. This leaves us in a very interesting position: If the R register happens to be random or chaotic in your use-case, then that is good! But if R just acts as a counter, then that is also good, because that is what the PRNG needs.
The basic trick is to combine a counter or LCG with an LFSR to smooth out the distribution of the LSFR. Since LSFRs are very fast, and R is a built-in counter on the Z80, we can combine them to make a very, very fast random number generator that is decent quality.
Now, there are some caveats. Due to the nature of the R register, this does not have a fixed cycle length. On average, it has a cycle length of 5592320 (meaning you could expect it to loop after every 5592320 numbers generated). The cycle length could be as low as 65535 (it is essentially just the LFSR), or as high as 8388480. If you wait for external input between calls, then you basically have a true RNG.
Here is a gif demonstration:
Another good use-case is fire animation! (sorry for the poor quality gif, it's really a lot smoother IRL)
EDIT: If HL is 24-bit, as in ADL mode on the eZ80, then your LFSR needs different taps (but in this case, it doesn't improve cycle length because we are still using H instead of UHL):
  add hl,hl
  sbc a,a
  and %10000111
  xor l
  ld l,a
  ld a,r
  add a,h
;HL is the new seed
I have no idea what the speed is on the eZ80. 10 fetches, maybe?
EDIT2: this comparison might be a little easier to interpret:
(LFSR only)
(combined with R as a counter)
EDIT: (2020-07-23)
Apparently even an 8-bit LFSR combined with the R register does a great job at generating noise, so here is an even faster version (faster for the Z80, though this code also works on the eZ80):
 ;E must be non-zero
:10 bytes, 39cc
  sla e
  sbc a,a
  and %01011111
  xor e
  ld e,a
  ld a,r
  add a,e
;E is the new seed, non-zero so long as the input was non-zero
;A is the output
Zeda, your prng routine is awesome!
(Here's something I made using it, ez80 calc compatibility)
(Packed) BCD to Binary, 2 or 3 digits (z80, no bcalls)
Don't know if anything like this has been posted yet, so here's what I came up with. Uses the Reverse Double Dabble algorithm for converting binary-coded decimal to standard binary. Any loops are unrolled for step-specific optimizations (and thus, overall, optimized more for speed than size). The 3-digit version is not exactly optimized, but the 2-digit version is (as best I can), and is presented in a form both with and without using shifts/rotations.
3 digits:
; Input: 3-digit BCD number held in the 3 most-significant nibbles of HL.
;       The least-significant nibble of L is assumed to be zero
; Output: HL: The number converted to standard binary (at most 10 bits used)
; Destroyed: A, BC
threeDigitBCDtoBin:
   ld BC, $0030
   xor A
   srl H         ; Right shift (1st)
   rr L
   ; rra   ; Dont need this yet, since A is still $00 ; potential spot for optimization: use A instead of L for these first few shifts
   ; no need to test `bit 7,H`, since the 1st `srl H` eliminates the possibility
   bit 7,L
   jr z, lbl_10
   sbc HL,BC
lbl_10:
   bit 3,H
   jr z, lbl_16
   dec H
   dec H
   dec H
lbl_16:
   srl H         ; Right shift (2nd)
   rr L
   ; rra
   bit 7,L
   jr z, lbl_23
   sbc HL,BC
lbl_23:
   bit 3,H
   jr z, lbl_29
   dec H
   dec H
   dec H
lbl_29:
   srl H         ; Right shift (3rd)
   rr L
   ; rra
   bit 7,L
   jr z, lbl_36
   sbc HL,BC
lbl_36:
   bit 3,H
   jr z, lbl_42
   dec H
   dec H
   dec H
lbl_42:
   srl H         ; Right shift (4th)
   rr L
   ; rra
   bit 7,L
   jr z, lbl_49
   sbc HL,BC
lbl_49:
   bit 3,H
   jr z, lbl_55
   dec H
   dec H
   dec H
lbl_55:
   srl H         ; Right shift (5th)
   rr L
   rra
   bit 7,L
   jr z, lbl_62
   sbc HL,BC
lbl_62:
   bit 3,H
   jr z, lbl_68
   dec H
   dec H
   dec H
lbl_68:
   srl H         ; Right shift (6th)
   rr L
   rra
   bit 7,L
   jr z, lbl_75
   sbc HL,BC
lbl_75:
   srl H         ; Right shift (7th)
   rr L
   rra
   bit 7,L
   jr z, lbl_81
   sbc HL,BC
lbl_81:
   srl H         ; Right shift (8th)
   rr L
   rra
   bit 7,L
   jr z, lbl_88
   sbc HL,BC
lbl_88:
   srl H         ; Right shift (9th) ; might not need this srl H
   rr L            ; If so, would use srl L here instead
   rra
   bit 7,L
   jr z,lbl_96
   sbc HL,BC
lbl_96:
   srl H         ; Right shift (10th) ; ditto
   rr L
   rra
   bit 7,L
   jr z,lbl_103
   sbc HL,BC
lbl_103:
   srl L         ; Two more right shifts, to align the results to the lsb of A
   rra
   srl L
   rra
   ld H,L
   ld L,A
   ret
2 digits, using shifts:
; Input: A: 2-digit BCD number
; Output: A: Standard binary format (at most 7 bits)
; Destroys: None
twoDigitBCDtoBin:
   or A   ; if A = $00, dont waste time here
   ret z
   rrca         ; Right shift (1st)
   bit 3,A
   jr z,lbl_141
   sub 3
lbl_141:
   rrca         ; Right shift (2nd)
   bit 3,A
   jr z, lbl_146
   sub 3
lbl_146:
   rrca         ; Right shift (3rd)
   bit 3,A
   jr z, lbl_151
   sub 3
lbl_151:
   rrca         ; Right shift (4th)
   bit 3,A
   jr z, lbl_156
   sub 3
lbl_156: ; At this point, if we were doing this with a 2nd register to hold the result
   ; (and loading 0s into bit 7 of A, rather than the leaving carry/bit 0), the most-
   ; significant nibble of A would be filled with 0s. Thus, at this point, we stop testing
   ; bit 3 after each shift, as we know it is (or rather, would be) 0.
   rrca         ; Right shift (5th)
   rrca         ; Right shift (6th)
   rrca         ; Right shift (7th)
   rrca   ; To put the lsb in bit 0
   ret
2 digits, no shifting:
; Destroys: None
twoDigitNoShift:
   or A
   ret z
   bit 4,A
   jr z,lbl_59
   sub %00000110
lbl_59:
   bit 5,A
   jr z, lbl_64
   sub %00001100
lbl_64:
   bit 6,A
   jr z, lbl_69
   sub %00011000
lbl_69:
   bit 7,A
   ret z
   sub %00110000
   ret
Some of the optimizations found for the 2-digit version could probably be applied to the 3-digit version.
If you can afford to use more registers, there is a snippet here that you might find useful: https://www.cemetech.net/forum/viewtopic.php?p=238223#238223
ld a,(hl)
and $F0
rra
ld c,a
rra
rra
sub c
add a,(hl)
In my use-case, I was reading BCD bytes at HL and converting them to 8-bit ints. If you have the BCD byte in a register, it is easy enough to adapt:
;Input: A is a BCD number
;Output: A is an 8-bit integer
;Destroys: BC
;9 bytes
;35cc
ld b,a
and $F0
rra
ld c,a
rra
rra
sub c
add a,b
(By my calculation, your last routine averages 91.824cc assuming all inputs are valid BCD.)
Your routine is pretty great when you can't destroy any RAM or registers except A, and I like that approach; I'm curious how well it can be optimized.
» Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
Page 8 of 8
