id really like to learn Assembly. I know BASIC (obviously) and JavaScript, but every time i try to open tasm it says unavailable on our server. How do i get past that. HELP!
Moderator Translation:
Hello, I would really like to learn assembly for use on the TI84+CE. I am familiar with the BASIC and JavaScript languages, but I am unsure where to begin. I've downloaded TASM80, but it doesn't seem to be working. Any help is much appreciated.
Well, clearly some tech support question was lost in translation.
Where did you try to download TASM from and what guide were you using?
You don't want to use TASM80 any more. If you're trying to develop in Assembly for the TI-83 Plus/TI-84 Plus monochrome calculators, consider the Doors CS 7 SDK, which uses Brass instead of TASM and has everything you need out of the box. There's a similar Doors CSE 8 SDK for the TI-84 Plus C Silver Edition (not to be confused with the TI-84 Plus CE). For this latest calculator, you could grab SPASM-ng yourself, or use it directly within SourceCoder.
