For a while, I have been wanting to learn how to code in asm on the TI84+CE. But, I have no idea where to learn that, so could somebody please tell me where I could do that?
You could try ez80 Heaven:
http://ez80.readthedocs.io/en/latest/index.html
I've looked at that, but I wasn't sure whether it was very worth it due to the fact of how incomplete it is.
By far the first thing you should do is read is ASM in 28 Days, which provides an overview of how the processor executes instructions and the concept of registers and stacks. You should start with day 3, days 1 and 2 can be found in the ez80 docs that was linked earlier. Because the TI84+CE uses different hardware, you can also skip Week 4, it would probably be easier at that point to download the source of other programs and see how it is done. From there you can apply the same concepts that are covered in the lessons. Hope this helps, let us know if you have any particular questions!
