For quite a while now, it seems that whichever of my unread private messages is the last to have been read, I am unable to access it. Whenever I do, it says "Cannot update private message read status for user". Even if I try deleting it, I can't for the same reason.
When it first started happening, it was a PM from lirtosiast back in May of 2015. Then, once I finally tried reading it again with some other messages unread, it happened with one of my recent "file accepted" PMs. Now, it's happening with a PM from mets11rap, which I have yet to read because of this.
Any help?
It sounds like this happens when you have more than one unread message but then when you try and read the last message, you get this error. Correct?
Some basic questions that may or may not help pin-point the problem:
- Is your PM inbox full?
- I sent you a PM, can you read the message that was unreadable?
- Can you read my PM?
1. No, far from it. It's only 46% full.
2. Yes, now I can.
3. Not after reading the last "unreadable" message. Same error.
It told me I have 1 new message in the top right corner of the site when you sent me that PM, however, even though two had blue icons as if they were new.
I think this is because the sender’s sentbox is full.
If I recall Kerm used to send PM’s like this accidentally when he accepted files a lot and forgot to clear his sentbox.
This might be the issue as my sent box was full. Try opening my message again JWinslow.
It sounds like an issue with the server, maybe you should try to contact the devs. I don't know what else to do, I guess I should just send you another PM to see if it'll work. This is an absolutely mystifying mystery. 😕
They ARE the devs.
It is because they sentbox was full, so the message couldn’t send.
_iPhoenix_ wrote:
They ARE the devs.
Oh well. 🙄
