Found this fun game, basically you build tracks to try and make your marble travel as many meters as you can. Try it out here!
My current score is around 1k Razz
I have played that before, I am not very good though. Smile
Here's my first try at making one: (it overflowed past 999.9, but it doesn't count that for some reason).
here's my best: http://www.marblerun.at/tracks/611826
Here's one of my favorites I just made: http://www.marblerun.at/tracks/611868
There's no telling how long it will take, it's only luck if you get into the end zone. According to the gameplay, my most recent run took nearly 9000 meters.
Also, these:
http://www.marblerun.at/tracks/611952
http://www.marblerun.at/tracks/611958
http://www.marblerun.at/tracks/611959
http://www.marblerun.at/tracks/611971
I’m trying to make a uniary counter, we’ll see how that goes.
Edit: I saw lots of races by Cemetech users (mostly Mateo). I actually tried things similar to those below. By the way, I found that the longer the distance between the released thing and the spring, the more meters you rack up!
http://www.marblerun.at/tracks/611792
http://www.marblerun.at/tracks/611784
http://www.marblerun.at/tracks/611777
http://www.marblerun.at/tracks/611983
http://www.marblerun.at/tracks/611962
new best! http://www.marblerun.at/tracks/613109
went above 1100!
Here's mine: http://www.marblerun.at/tracks/613300
Currently 38100 meters. The game is silly and only displays up to 999.9 meters.
that's almost a total copy of mine!
Yep Razz
here's mine; it's small
http://www.marblerun.at/tracks/613305
I did one more:
http://www.marblerun.at/tracks/613345
Mateo then exploited a trick/glitch I found and created this monster:
http://www.marblerun.at/tracks/613359
Edit:
http://www.marblerun.at/tracks/613401
http://www.marblerun.at/tracks/613442
http://www.marblerun.at/tracks/613470 << this is the best. Please like it Evil or Very Mad
Edit:
http://www.marblerun.at/tracks/613478
http://www.marblerun.at/tracks/613487
Edit:
http://www.marblerun.at/tracks/613495
Finally surpassed 100000 meters: http://www.marblerun.at/tracks/613390
I'll have to check the javascript sometime in order to determine the actual length; I imagine it is around 400000 though.
wow that's long, here is my longest lasting course, but not very long meter-wise: http://www.marblerun.at/tracks/613394
I've given up, because of these lines:
    if (this.parent.trackLength > 9999) {
      this.parent.trackLength = 9999;
Oh well let's see how complex of a track can be made now.
Or, you could focus on duration!
I created a pinball machine! http://www.marblerun.at/tracks/613573
With inspiration from Mateo's latest design, here's my masterpiece. With the distance limiter removed, it clocked in at 2,242,791.9m. It took a few hours. http://www.marblerun.at/tracks/613999
It relies on nondeterministic behavior to activate that right-pointing spawner in the bottom-right after a very long time. If it gets activated right at the start, you have to run it again until it doesn't, which may take a few tries. But once it gets past the start successfully, a kind of shield of balls being pushed left along the bottom protects it and makes it extremely unlikely to be hit; but not impossible, because it needs to eventually be hit to actually trigger the goal.
For some reason mine aren't working when I publish them! http://www.marblerun.at/tracks/614372
This is what the track is suppose to do.
Tried to click the back arrow, this is what I got:
{"mode":"show","track":{"id":613305,"json":{"bricks":{"0":{"type":"Ball","rotation":0,"row":0,"col":0},"2":{"type":"Beamer","rotation":1,"row":0,"col":2},"3":{"type":"Boost","rotation":0,"row":0,"col":3},"4":{"type":"Graviton ","rotation":2,"row":0,"col":4},"11":{"type":"Curve","rotation":3,"row":1,"col":1},"12":{"type":"BallBox","rotation":0,"row":1,"col":2},"13":{"type":"BallBox","rotation":0,"row":1,"col":3},"15":{"type":"Curve","rotation":3," row":1,"col":5},"16":{"type":"Brick","rotation":2,"row":1,"col":6},"17":{"type":"Brick","rotation":2,"row":1,"col":7},"18":{"type":"Brick","rotation":2,"row":1,"col":8},"19":{"type":"Curve","rotation":0,"row":1,"col":9},"21": {"type":"Brick","rotation":2,"row":2,"col":1},"25":{"type":"Brick","rotation":2,"row":2,"col":5},"27":{"type":"Brick","rotation":2,"row":2,"col":7},"29":{"type":"Brick","rotation":2,"row":2,"col":9},"31":{"type":"Brick"," rotation":2,"row":3,"col":1},"32":{"type":"Brick","rotation":2,"row":3,"col":2},"33":{"type":"Curve","rotation":0,"row":3,"col":3},"35":{"type":"Brick","rotation":2,"row":3,"col":5},"37":{"type":"Brick","rotation":3,"row":3," col":7},"39":{"type":"Brick","rotation":2,"row":3,"col":9},"43":{"type":"Brick","rotation":2,"row":4,"col":3},"45":{"type":"Brick","rotation":2,"row":4,"col":5},"49":{"type":"Brick","rotation":2,"row":4,"col":9},"50":{"type": "Beamer","rotation":0,"row":5,"col":0},"51":{"type":"Brick","rotation":2,"row":5,"col":1},"52":{"type":"Brick","rotation":2,"row":5,"col":2},"53":{"type":"Curve","rotation":1,"row":5,"col":3},"55":{"type":"Brick","rotation":2 ,"row":5,"col":5},"59":{"type":"BallBox","rotation":0,"row":5,"col":9},"63":{"type":"Boost","rotation":0,"row":6,"col":3},"64":{"type":"Boost","rotation":0,"row":6,"col":4},"65":{"type":"Boost","rotation":0,"row":6,"col":5}," 66":{"type":"Boost","rotation":0,"row":6,"col":6},"67":{"type":"Boost","rotation":0,"row":6,"col":7},"68":{"type":"Boost","rotation":0,"row":6,"col":8},"70":{"type":"Curve","rotation":3,"row":7,"col":0},"71":{"type":"Brick"," rotation":2,"row":7,"col":1},"72":{"type":"Curve","rotation":0,"row":7,"col":2},"74":{"type":"Brick","rotation":2,"row":7,"col":4},"79":{"type":"Boost","rotation":1,"row":7,"col":9},"80":{"type":"Brick","rotation":2,"row":8," col":0},"82":{"type":"Brick","rotation":2,"row":8,"col":2},"84":{"type":"Brick","rotation":2,"row":8,"col":4},"86":{"type":"Brick","rotation":2,"row":8,"col":6},"89":{"type":"Boost","rotation":1,"row":8,"col":9},"90":{"type": "Brick","rotation":2,"row":9,"col":0},"91":{"type":"Brick","rotation":2,"row":9,"col":1},"92":{"type":"Brick","rotation":2,"row":9,"col":2},"94":{"type":"Brick","rotation":2,"row":9,"col":4},"95":{"type":"Brick","rotation":2, "row":9,"col":5},"96":{"type":"Brick","rotation":2,"row":9,"col":6},"99":{"type":"Boost","rotation":1,"row":9,"col":9},"100":{"type":"Brick","rotation":2,"row":10,"col":0},"102":{"type":"Brick","rotation":2,"row":10,"col":2}, "106":{"type":"Brick","rotation":2,"row":10,"col":6},"109":{"type":"Boost","rotation":1,"row":10,"col":9},"110":{"type":"Curve","rotation":2,"row":11,"col":0},"111":{"type":"Brick","rotation":2,"row":11,"col":1},"112":{"type" :"Curve","rotation":1,"row":11,"col":2},"116":{"type":"Brick","rotation":3,"row":11,"col":6},"118":{"type":"Boost","rotation":2,"row":11,"col":8},"119":{"type":"Boost","rotation":1,"row":11,"col":9},"120":{"type":"Boost"," rotation":3,"row":12,"col":0},"121":{"type":"Boost","rotation":0,"row":12,"col":1},"122":{"type":"Boost","rotation":0,"row":12,"col":2},"123":{"type":"Boost","rotation":3,"row":12,"col":3},"124":{"type":"Boost","rotation":2," row":12,"col":4},"125":{"type":"Boost","rotation":2,"row":12,"col":5},"126":{"type":"Boost","rotation":2,"row":12,"col":6},"128":{"type":"Line","rotation":2,"row":12,"col":8},"129":{"type":"Breaker","rotation":0,"row":12,"col ":9},"130":{"type":"Boost","rotation":0,"row":13,"col":0},"133":{"type":"Boost","rotation":3,"row":13,"col":3},"134":{"type":"Line","rotation":1,"row":13,"col":4},"135":{"type":"Line","rotation":0,"row":13,"col":5},"136":{" type":"Boost","rotation":3,"row":13,"col":6},"137":{"type":"Line","rotation":1,"row":13,"col":7},"138":{"type":"Line","rotation":2,"row":13,"col":8},"140":{"type":"Exit","rotation":0,"row":14,"col":0},"141":{"type":"Boost"," rotation":3,"row":14,"col":1},"143":{"type":"Boost","rotation":3,"row":14,"col":3},"144":{"type":"Line","rotation":1,"row":14,"col":4},"145":{"type":"Line","rotation":2,"row":14,"col":5},"146":{"type":"Boost","rotation":3," row":14,"col":6},"147":{"type":"Line","rotation":1,"row":14,"col":7},"148":{"type":"Line","rotation":2,"row":14,"col":8}},"pairs":[{"girl":{"row":5,"col":0},"boy":{"row":0,"col":2}},{"girl":{"row":0,"col":2},"boy":{"row":5," col":0}}]},"trackname":"SM84CE","username":"SM84CE","imagedata":"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAHoAAAC2CAYAAAAWc5krAAAcb0lEQVR4Xu1deXxTVdo+ N1vTpmnT0gW6UcYFWgTZkU1gZBkVqjOyjPAxbMI4igybDvOB0xZHcATFYfjNII6yyJQRRhSnCFL8AKGsApVCFUWBpBstS9ombZomud/vhKS9SXNzz3tzb7ilyT/9NXnvyXvOc97znPOcN+dQCCEahV73egtQlAto/Jf0lY0QyiU1XvdG7ytr/n4z3dv+rdzkQxNnHh/ poxze5ctkCKUmq1oVaSizIofjzttLXuhwdf7Sc11I/UcIgfyRoD0OZF5AD0cIHSZtqA/+1v9czurrvdz2MgqhzK5qNGda/NFfTisc5qMc3uX37xWBHspQo6ob9uZiE+MUqOhiPTp7vsH5Xs7LiUWzXjrdm9R/hBDIHwnaswOdg9DTFEIPI4SuZiO0BdAorUx3bhp0cHF22Qj8gUpJodxXOn3Zq7tqY3pK+BFN+ hcVbGWnpqbOoChqE03TM+vq6j7VarWHKIqia2trRxqNRqP7uR0fDDq0JKcMg4GGDtQgY40dXfjO0lxsj0w1ioqUo8JTZud7a3KSD0+addzpTzt5tQY6ByEdQuggQqg5AhFCRTkIMSMA1MOZEf3X11OOPP0/x4ZTlN95QXP5JGAzyycBOhTReFhDaAZCaJOPnv7LHIQ+db0P4iw3R/fMDEevvZLwdO+ fH9nNEUke5XOBzZwDkAAd4ug7QOe4JhPeWOS6PsPv84roIQM06L130npFpnzxDQfQrcpPTU3dTFHUdKvV6pxEqVSqKzRNbzEYDDPcEb10fiJqtNJo239uomoGRyfEydG0iR1QfYMD5e26jRb + Ni7E0YQRDaI2N0f3zFSj1//Y8amHh3/1GaQA74iOioo6SNM0VVdXNwJztZujOyYoUd + HI9CegppWxY8bHY3OlzQgfZk1xNHOGekdjj6E7kzE3K9vcjw5m1dE48LWrkj56lfTjz1GUcjmB2xWjvYGGZfB5OjOKSr0UEa4B9hMkJ11DM267zS9C2w8K8UTsqs5CG32AoUXR + MylEoKvba0U0Fyovyjfr0i9mrSCsp9AO4snyuS3c95r9PTUlSoZ0Y4yi + oQd4g42dCHE0 + nvKOaPwVeOWe8YAa/ W5m3NGnph4TdB3trkJasgo90i8CHT5mQterPQePUESTAw2yZK6jmQ/6UcZA5TPX0cwHo7VyVFPXIpy4P2vv62g828bcjBUvHLF46Gb7fz5CKIbt8949Ih7P7Kqb0K9PnDI9RSOPjVFMKKtocshllE0mQ3aHA8ntDlqhiZSZGi30RZPZFm0y23SRGoUxUqOo6ZER0b/g8K0q9//en3v/r4uSZX53ud5Mar /3wPWbm/J + Ok/qf3ycIuvsedMN0vKh/kPt1Wq663ffm6tUYfKiWVPiNw4fVxh1rrh + gB + 8eEugPjmaprurju2NnX66qGH2ybPm7pevNEaa6x1o2cKOlj/+ uVxNGqarlieB7IXi3LvlP7S + 2P71tZVqTYQM3d8lzPRI34gLvR + O + 59teu27rw5 + tLlRo + WbKepMk4925g10K46uvTKm2/GDY4/ vevNPyaZXVpRFkgINtReCc + 9D6 + + m/rLvdr8a/WZyh/1Zo6PnR/1s3yWvtuYNtEc5B3YNHpRfYMrbtcfYaocKG76Vm2JcnF2Kl21ErzU5yTVLcsqiiYwF0K4l4D + ovv7a85lxumtPjop8dtSvjh1ntB9voJsjGjfSvoOm7Tt2GzuzAbM6O7lucbbhMv48LUmlzOobFmW308174AolhT4 + 1WAqr7BZsc3br6Xct + jV0h9J7f + 8tJN9xrzT/Uk7BlPZI/FfiIjz55vQ5U96SnftFyM9wOYNtJOj9 + 0YNGDfQfNHbJHsrhyTg1RKhN59Maa0 + K8/pLg/z/z9g2XPr7 + VbHOtgqD2fDmaj/8knYkP5wo9h8GRnbskaaxrGOcN9HCa7n5827va/GUry0dzVd67x + I17vzOlsqSf5d2zJyWqv/ rD6o0Q3nLHAJqz4ejA/7Zb9qeVLBlD5NT1L9zuCRklfiASr8fNicnDWVG70nXr4q5YtTxvRV3xgfa1XsvK1WfvV1vYb5nC + O5rAH7y8H6r8 + EfWt/8HjMMQTjaKZfeIK2fEni3EefOLKRF9B4nTz92YzstzdUD + TqrfhzXxykVFDovnTVqR + vWgc02TxT1qD20IgWwv9gcq73d0E4fdHzCScX/O/ XGCd4RE + + A0VPLjxl9ohEtsqzcRZN04cpinJmhjBfUHsoRwvlP7S + dkPS d8N + 6MBIU97OEry0hQO9dmXPrXkfm6Z5a8hsFWHrgWxAQ + 2hES2U/9D63g37jvEKdOrMT/ir4UDv2jIob/kbFc + azK60So7xm23dxwY0G8f5sQdxtFD + s1VbKhyN/dNGytDFkqseQBNr3Uc + f9RkKLXKvbVrtv9jYuSqkkvm695acXSUoipcrWjw1q4R7UivrLbSpPZc2rW3di+U/2zad4+M8MFni+vtuD3kcspmt9MKrO2z/R+jkylLLpmrSbX05I6KQddKW+8dsLX/xFnHsfgEj2i2PG22Hg7lULHzosX2X2rl6/V6fkO3d54218wbyqHQnDSovdj+S6183kCz7f/64SwQh3J1nEA/F9t/ qZXPG2ixeyw0QqH2YvsvtfJ5Ay02B4U42v+YBW1/3kCL3WOhEQq1F9t/qZXPG2ixOShQDuZ6Xmz/pVY+b6DF7rHQCIXai+2/1MrnDTSUI0LraP9jDLR9oO3PG2ixeyw0QqH2YvsvtfJ5Ay02B3FxbKCfi+2/1Mr3BppY6/72+GPms8VmGamW2zlFqTlxpraMVMvlkbfsN8/cW+s+8cWj5h+ vWYn9N95urJmz6Az+KTFR3ju0fWiHvWbS7JPE5UP9nzjzGE7MFF/r5pNDBcxb5v1bMJLRQWwOFbt83kM3lIMgGRFsGSkcecsB/RaMC2yoVg9tH7HL5w00Dw4SLCeKJW+ZCyuPz3n4D9LqpVY+b6ChPVaIiGYi5SNvORTRfro6b6Ch6zg+HM2V5+yVtxziaDGAvtsR7a4TI295cCDnnnGN+ 2JzqNjl845oHhwkGEczQWHkLb/HBRbzcx7+hziapIGF5mjmd+K85S3bS3LPFdfvJfEF20BHJLEjTuzyeUe0FDjaDSrOW0YO40d5H5c/Rwo01H+x17lil88baGhEiBnROG/52V9Fbl247Px0UqCh/osdcWKXzxtoHhwnCkdjYHHe8oo/dMp7ZvrxqaRA8/D/nuJoYq37g7/ 1OWEy04mk2nWN0ZreYHW0ytNmex6atxymRpasKcf/QapFQ7ViqNYNbR9oXjpUS+etdYdyujjHDtC6Htqe0DkG76Ebuv8LtW/rHAqtL9Qe2j6BAM3ZpQMxaOscGkjdSZ6Ftk8gQIO0ZbF7rNizVmj50PpC7YMZ0ZLiILHXodDyoZwLtQ9xNMm4FwRlDBqhUPtgRjRhk/Izg3IQ9GxPscvnV2vyp6D+ hziasG1DHE3YUGJzEJRDoRwHLR9aX6g91P9QRBN21PYc0YRNxM8MykEhjvbfzrzzus98Oby08HRtE6nWDT2POjZGPqCq2kaR5o3Xmq23Zs37eqtUtG6EECjPHGofNK0byhFi5Iy5+zDevZo2QVu8dEVxT9LxA+p/u+Vo6DpO1P3oRCWanKXZuvhV6exHQ9fFUHto+/OejPHgUNH2o4cOjDRvWJ0yJip9/ zHSiObhP2g/mtQPvnZQ/3kDDe1RYkb0oufjT76/7dvc4hLp5IxBIxRqv3l9/9PL36iQ445Ccv55aWkpvldUmr + 94srrxpXs9oAaLV + QOPfR8UeShLjPmi3CpMzRJOefe0T0fzYPOSSXI8WYYZGTfF31a746ttOBo6adTTbUFKaiu7 +. 4tDSedOgRK6JXLks6MHXuiccpCg2RUl43NEKh9t4jKtf55x5Ap6Wloe5d1WjNiuTJ3Qcd3OEN4uH8R2evfKfyn99 + bxH9jgySOzgmjNddy1kUPybqvi + / J + 1wbjsox0HX6VB/Grandpa + / Pd3nnkroPEgvnJ50pdTnjsxlqJQ881gND1R9a + N +. j3LVlaMwjdhiBWh7gpzlT8pS2d4cox20siswhOuZ0D749A5RltQxvydf94KaNxo + IHV2clf3ZeueOu + tDD9T1csnS8ZbAuX5pYPdx + gLua6GPvgr3wcyePHan/Atofv1fX0WynH/sE2h1VPTLCnam0dSY7Kv7W4jG6cEWc91AkhD2eeE2fHFsw/jHNPB/Nabq/DdbuPaNzmvID2xxskHMp8Hnp + NS4/ Z3W57s5NbWrzgN4RF/r0CH9/2LgjmziuIyaiu3uRo4mBXv + XPlc1rrsh8fnZZrNNx//WBjd7are0kCqdbOdv83 + fFNKVXVjvVJJnZszreO7Q544Gl1c4vfuRZC2LHbeNVS7htqz + vmkWcfxiAdfR0M5MWTPOdCA5hg82pP/vVeQdSt0nRiy5/c92 + wYoDkJpm + + Ec3piRAG3jfCa7XaQxRF0bW1tSONRqPR+zvamz2gjXkDDe1RvO0JwWsuv73ZE4LNG2ixOcWjfALw2rU9Adi8geYdoQROYZNW5aempm6mKGq61Wrtgg1UKtUVmqa3GAyGGSF7zlblDTRnyUIaeEd0VFTUQZqmqbq6uhEkXH2v2xO0NW+ ggxbRhCCzcjQLyPeMPQHITi2F76w7KBxNCHKz1t3e7AlBDgjooEU0YWVC/vhvKN4RTdj+ITOJtIAH0KxnmOD7ljO76ib06xOnTE/RyOPjFFlnz5tukGrdYp+/Dc0zrzNZwmfPP/c5aR44VIuWoL3/iKbp7qpje2Onny5qmH3yrLn75SuNkeZ6B1q2sKOFJKfL3Zvx/nJbPn+ bh7YclDkMYLRgB7r2yphuu/fVrtu68+boS5cbPcoUZH/5fjX6zeQO+7NGR8+P+tm+S15Ogzi3rWeMBKLt4wmowWDY7EsOZrzvG+gDuwYPyi8w5e3aY0z31Wug+9H+7NvC+duAyAm6aVpaGk3T9Ewm2O7Vh16vp1wOtQYag7zvoGn7jt3GzmxeCxHRzLKlfv52IBFHiDxoBGP6w1xSYrC9// cJ9L4dgwbsO2j+iC2SmZwL5Wgueymfvy1ljtbpdDqtVvs0RVGbaJrGMvEMHOF1dXWfMlTDloim6e5h297V5i9bWT6aqxcKHdGMDlQwpU/Tk1S/M5I6f1viEV2EpWAG2E6QsSKo1+vxLzQ8BZPCz4fNzVlTudF74iU2RzPLl+r521wd/25+npqaWuTeo1er1TqLxWJ0y74Gg6FXK6DfWdX35Nv/ qB5I4rRYEY2/W4rnb0s5ol1DtzMhw2q1/lKlUn3iY8OnZeh+dkKmufCUSUMCtJh53VI8f1vKHI3xYoD9ME3T3/jY1WsBul/fLqiquvnHGX7xFjOipXj+tpQj2g2UC+x36urqFvjYum0BOjMjHZnMDpKABv/2CrLuluL520SNIm2jFqDzNj5iwWeGyGTI7nAgud1BK9j+j4mRq0ouma+ Tat1in78NPdMDehfkPaCltwCNf01J+oL+Xljs3zq19fKDMAfgBzT014Via9FtvfxA5gBgrRsS0dDfC4v9W6e2Xj7pSOrLDqx1Q4AORbR/aKDtE2hEu+RP58YGp9YNATrE0f6BhrZPIBwN1rohQEN7bFvnULH9DzCiYVo3BOgQR/uPaGj7BMLRYK0bAnQooqXD0WCtGwI0lIPa+ jpXbP8D4Wiw1g0BOhTR0olosNYNARrKQW19nSu2/4FwNOGzLcrYv1xat1xO2ex2WuHWun39/1A3tabg8O0yUq37Z53Dhlz60WIjPX8behckVOuWmv9ByAPnJ4GKuR+Ne6jYcwCp+R8oRxNENT+gxdyPxk6LPQeQmv8BrqNhed1Ajgadvw09ZywIcwBJ+ U8QkawmomrdUosIqHIlNf8DjWjRtG6pcRx0nSs1/wPhaFG1bqlFRDuPaFG1bklxHI91rqT8D4SjRdW6QxEtHWVMVK1bahzXnjlaVK07FNHSiWixtW5JcVx75mhCfuendcfoZMqSS+ZqUq27R0b44LPF9XZSrRuadw09fxt6frjY/ktW6xZbi4aWH8g6lCQioHMAqfnvcaAcRAIVW4uGlh+ IskQCNHSdHkz/21VeNwlYgdjwmAME7S5LUbVuaI + wwQydEM5qK1znJT9F1XrDkW0dNbRWAIFnWECiegg7BcHjeNIhm4pc7SoWncooqUT0aJq3SGOls5vr0TVukMRLZ2IFlvrBnGolDmurXM0if8eypj7DBOSvO5OifKIM + dN5aRad2yMfEBVtY0i1bprzdZbs + VckSQdAAp + w8 + Z9vVUq52lD88ahWn1QtW7IqURi7kfjU4mmTdAWL11R3JOwt2IzUc/HlvI6mrCNWnav + vfpgq7fkMA5Y4lKNDlLs3Xxq + MRIQgmET7DkGXjIxr3FiHujqDSpY6167su + ptRuqB5A0nJgZJouejz + HZfkO6SujIHO654yMdN89CTZyYGQc8NwQ0Lshw6MNG9YnTImKn3/enE1YCm/E/5/rZvc4tL6veS + OKyuWcimhBkn/d2EZ1h8tXnw + b + ec31jd9dtnC2r1gc3e0BNVq + IHHuo + OPJCGEcjkdaTG4JziaEGSPOQlY66bpvqptGxR7lq2quGvnda9clnRg6twTj1MUGiKl + 6mDxdEc928y + z0zomFaN77SrvanX3TNXlP + xcf57NcsQDmX1H7CeN21nEXxY6Lu +/J7QCQHxTRYHM2UM/ Ed2f642V1xsNaNgcYP35U7NbJ0hifHaCeNzCo8EQzOhc7SgxXRXnKm80J0FrCbIxqsdbuBdoO954BpO1tkC8nROJLHj9X + mgGy6Oti6Lo72Otogsj2mJOAzutmAo1bev9/BvSruilbtfWjW6O8J2hCzLrxxGv65NiC8Y9p5vkYrkWdRUs5ogm5qFX7EJ/X7Q00/kL6677KI1URM84W1c8 + da7hoR + uNGrq6 + 0o5 + LsUh2hU851dM7qcp0mQobu76I2D + gdcaFPj + Uk4/D3h407somikI20nLtlFyyOhtSPpu9QLcmLohA + iJ3CD2CJzO/dlBkP6p7p1ztO1TlVI1cq6Z9f1TdaSLVuk7kppaq6sV6ppM7Nmdbx3SFPHI0uLqnHa/ZDrtk17qEjGP/PRwjFSEXrhuaN7z1w/eamvJ/Hi + V/4ReDKy9 + 29gkl8mqtZFKY52pSWeut + k0EQoj83 + ZDFUnxIWbJ806NlLS90eT9FaXjajraCini22f917/8ugoVewLrxjCaByifl45L3e8NeulU7GsQLvG/LV1dXULfdzREHQOlZo/HJ1Q1PbBq4CqaltXtVpGv72hOoLNl9lTYmu + KbGodn32XbhPoN0KDUII35tUhKf5PsBG3jewa7Va57U8Qtm7K0Dqj7e9 + 1ogrvUoQJFyfgXUHjAyEZnu3DTo4OLsshHrXk8y7ymoo744VNcK7GGPaFCnRKVxx26jTq/X43KbOdpJ7sxKNDU1Pa1UKj/1AZ5PrRXfoMYCNm97qD + EIHisQwk2EHjbEyEH3H1jruu3ru9syX6zQn1Fb23 + qhidDC2Ym3Az + 83KDvhNn0BjpQV/iFNI3TejucFjXIHnwYkEkc3bHuIPIci4ek5/ xLYnBLnZH1L7f67rq1 + xpjrVbf/e2jTr/D8aVA2WO4T9 + v92uvHm + qq4mto7286sQPvKE8ZgM67Aa8VBHDotb3u2vGVf/kC1YrHtSYGDrus/+ XDgpYYGKu5qqVXxzYWGKHUYQiMGaxuzV1eGzZ8Tf/PLr2rDL15qbB7OWYduBqdtoShquo/ bSz3q4B3RzKGQhNv92Xvtzvj1h0BR8vBbbHsA0CBTzNHZb1aMSE9VoR4Z4ca+D2uQLooKC1MhxY7Pamr/u7/WOWS7X2wRPYPg3CpWzmUBTRB7P/utPrVfqFYshj0hgqBZ+gd/6382Z/V1902yzlnWM+N01swHwyxNTYhete56NCfQhBkLTo4DRDIve+ wsxB935QgilU0rZttICMieAGxiHQArYuve6P3TW/+4me4ud/bU2Fv1DY7w7buM4Z1TVeil5+Jvb95+M+bCd3dyC1gjmiAHCdQDoRzkfeO5lPwhAA2bgNon5w8PvNarRzyxpNnYaJv6cm5leqdEJVryQuLtD3fejCm60NDsmkKB0MwpHW6Z6uzh2z8xhvsEmrAiITMBW2D3v4YcXb3+ Ok62IHoteTGhZtvOW2FPjIoy56y + s4Ty9Ro6QGMZPlRr/u2CU9iGW + t29VDJatGkedGvLe9G9czoMMpms6dXVFqbNBqFMVKjqDGZbdFms03H9n9ZuYlasOz8/wmtXbv9abLb0ysryP1RKOgHVUpaWXXDUcr0X66Q3YiLVZmZ9UlKVKGxE49i4ctTMCHqUiLnUYulFef /. e9CfVr1TlTvvuXjL3zfdUBPWFU2bGK2fu+BMZ1J7Uv/d/kx+Ourq/KXnupCWr9MpXjMaba+S2nv8UsPXNqWfgkAcBOUsX/ZCaN3uhv3dzLhrGo38Q9KGOldUTa9Y88OfmPZC+jN7amzRrJdON8+iCfyCtn9LAj8GmkDhIvBBeBOo1s3mgRvoBb9NODRx5nG8dcfrJTV/CCrhCTR+gBBsaI/ibQ/ Vuv1V2g10IBEkNX8IQMYmrYEmBJt43edyhLc9ROvmqjRfTmRyrtT84aqz63PfQLvA3ozlT6vV6pwkqFSqKzRNbzEYDDOE4FwOBznzlrm0d1/lCxHREO2dCwQh/OH6Dr9AAxQvwu/hbwbRurm+RQiOlpo/XHVmBZoQZN6cS+gY9LdFRP4IEUGE53oFzR/C9vQ/6/ azq8Sbcwkday6fj9bNNeuGrluZHC01fwjbk52jSTmU8IuIejijLI+IFkrrFiqihfbnhTvr+m2EbYmKiqvpnL/8EBTBhNQnSdkJwdFCVsjtz8LnE2reebfaY2vR3/e8PC+x8KmphUMBvrREdFxc3CGZTFZSVVX1Ip5VR0dHzwsPDzcplcr9BoOhHOddJyQkJKjV6upbt27Fmkymm0Jrv2LndX+ 4oddDUZGasTaHvfaZ35x47277v21Dr4e0kZqxKhWS/XiloVpE7b3VlYUVer0e/zYZ7wP/FyE0DiGUr9frx7vew4B3qq+vP3Tjxg2IshQ0TvfXy4VYRxNGEVF9g+iPB9AVDoejkqIoDC5yOBxvyOXyUXa7/YBMJluK36NpOl8mk3W0WCyfuCK/ud5CaL++ONr9nhDlC8HRUvWHowO2mnUnURRV5nooS6/X /zctLQ1H82cuoJNdw7hHuUJpv2zOClW+UBwtNX8IRhneQPvMcybJAydwCpuIUr4QEd3mte60tLR8h8NxWyaT7XQN3UNkMll3h8NxUSaTFbremyiTyWJqamosNTU1E/F7Qmq/jE7QzHFCli8EJ0rNH8LA4TcZs1qtmysrK2e6geaTB87hYEjr9t9AUF3CA+h8u91+ Wy6XOyPaZrMNUSgU3W0220WFQuGMaLvdPlEul8fQNJ1nMBi24/eE1H591U3I8oXgaKn5A45oV+IB6WRMFC3a16xbatqy1PwRG2hRtGhfHC01bVlq/oCBTktLq0AIVdI07VxH0zT9hkwmG+VwOA5QFOVcR1MUlY8Q8lhHE967BOUUUbXu38/ pcE0VpuClLQtZXzeVBOIPH6DxM0TKGP6Vhl6vx0dhtKmXu2FffimxZs36KjG1ZaJ2CaI/HutoIudCRm22BZx53aFXO2iB/wfZBE8e0QXGsQAAAABJRU5ErkJggg==","length":5.58087680366676,"likes":0,"date":"21. November 2017","time":"10:48 PM"}}
http://www.marblerun.at/tracks/614410
http://www.marblerun.at/tracks/614423
Two new, high-ish quality tracks.
Edit; I believe the above problem is caused by the fact that your computer sucks. Razz
http://www.marblerun.at/tracks/614429
Page 1 of 2
