Hello, I am starting with the ti84 pce, not really much experience in z80 assembly, but understand the basics.
I wrote a simple ball bouncing program to get myself started. Writing/Erasing the sprite directly on the vRAM is pretty fast (both in 16bpp and 8bpp) but results in some flickering as the ball moves across the screen. I then tried double buffering (with 8bpp) but I am still getting some flickering and much reduced speed. I was wondering if there is any good tutorial/info on changing the LCD base instead of copying the whole buffer that seems to slow down the code.
I think Mateo posted something on that but a more detailed explanation will be appreciated.
Thanks in advance!
The CE LCD has a flag that is set when a new address is able to be loaded into the LCD base address. This is enabled using the following code:
   currDrawBuffer          equ 0e30014h
   ; ... other initialization code
   ld   hl,currDrawBuffer
   ld   de,vram+(320*240)
   ld   (hl),de
   ld   l,mpLcdIcr&$ff
   ld   (hl),4                       ; allow interrupts status for double buffering
Then when you want to swap the pointers, simply call this function:
SwapDraw:
; Safely swap the vram buffer pointers for double buffered output
   ld   hl,vram
   ld   de,(mpLcdBase)
   or   a,a
   sbc   hl,de
   add   hl,de
   jr   nz,+_
   ld   hl,vram+(320*240)
_:
   ld   (currDrawBuffer),de          ; set up the new buffer location
   ld   (mpLcdBase),hl               ; set the new pointer location
   ld   hl,mpLcdIcr
   set   2,(hl)                      ; clear the previous intrpt set
   ld   l,mpLcdRis&$ff
_:
   bit   2,(hl)                      ; wait until the interrupt triggers
   jr   z,-_
   ret
currDrawBuffer is used to specify which buffer you are drawing to, so use it as the base drawing offset 🙂
Thanks a lot Mateo!
I was wondering if the code for enabling the interrupt should be (in the first code fragment of your reply)
ld l, mpLcdImsc&$ff
instead of
ld l, mpLcdIcr&$ff
Anyway, I see that clearing & waiting for the interrupt makes the code way slower. Was that your experience as well?
I am currently swapping the two buffers by changing the mpLcdBase manually after finishing drawing in the buffer that is currently not displaying. This results in a pretty fast code with minimal visual artefacts.
It may be of course that I am missing something 🙂
Hello,
Based on Mateo's comment above, my current implementation for page-flipping is shown below (pseudocode with some Z80 assembly)
Main:
      initialisation code here
      set 8bpp & Palette
      call setup_bufs
Loop:
      draw in back buffer as required
      call swap_bufs
      jr to Loop unless done
      call restore_buf
      ret
setup_bufs:
            ld hl, vRam
            ld (mpLcdBase), hl
            ld hl, vRam+76800
            ld (backbufer), hl
            ld hl, mpLcdImsc      ; set interrupt
            ld (hl), 4
            ret
swap_bufs:
            ld hl, (backbuffer)
            ld de, (mpLcdBase)
            ld (backbuffer), de
            ld (mpLcdBase), hl
clear_int:
            ld hl, mpLcdIcr
            set 2, (hl)            ; clear interrupt
            ld hl, mpLcdRis
wait_int:
            bit 2, (hl)
            jr z, wait_int         ; wait for interrupt
            ret
restore_buf:
            ld hl, vRam
            ld  (mpLcdBase), hl
            call set_16bpp
            ret
Please feel free to comment and improve!
Thanks
PS: An interesting article on double-buffering and page-flipping can be found at https://docs.oracle.com/javase/tutorial/extra/fullscreen/doublebuf.html
I probably dont know what im talking about, but i am pretty sure the CE is ez80, not z80 (dont know if that changes anything)
Yep, that's basically it, although don't forget to erase the buffer before drawing to it 😛
(Also, I prefer writing numbers as a logical expression. 76800 doesn't make sense to a beginner, while 320*240 does 🙂)
Thanks guys.
I agree Pienman7373, should had put down eZ80, not Z80 in my post
Thanks for the tip PT, 320*240 clearly makes more sense than 76800. Also I do erase the back buffer, but you are right I should had clarified this in the pseudocode above.
Also, in many programs, you see like LCD_WIDTH * LCD_HEIGHT which makes even more sense 😉
