Hello,
I am using WabbitEmu for Mac and no matter what ROM I open the buttons on the calculator are off. For instance, when I click clear it'll click 4, and when I click 5 it does nothing. How can I fix this so the buttons do the right thing?
Thanks in advance!
You could use jsTIfied here:
https://www.cemetech.net/projects/jstified/
I think the most likely problem is with the ROM, and long story short the emulator failed to work. Try using jsTIfied, and if that does not work it is definitely a ROM problem. If the problem persists, try dumping again and redoing the setup wizard.
It worked that time on jsTIfied, so why wouldn't it work on wabbit?
I assume there must be a problem with wabbitemu, however I am not familiar with the mac version. Try their web page for help, and see if wabbit was installed correctly.
The mac version of WabbitEmu doesn't work for me, either. It flat out doesn't launch! (I'm running a relatively old version though)
