I'm not going to get into the Mac vs Windows debate that seems to be starting - because (1) it's off topic and (2) it seems to devolve into an uncivilized discussion - but I will report back on the angle count from my earlier post. I combined the max number of clips I can, 16, and I can edit and view them all at the same time. Click for full size awesomeness.
Each clip has it's own audio as well, so that's 16 audio and video tracks playing at once. There's probably some behind the scenes magic, such as not loading the audio tracks of all 16 clips but I'm fairly sure all those clips are playing back at 1080p each, for a total of 17 1080p videos on screen (got to include the preview!)
But I doubt it's going through the GPU for this, it's just 16 videos streaming from the SSD, through RAM and, into the software. I can throw the
90GB project file onto a MacBook Air at work and see how well it handles
๐
Some advice I can give regarding video editing on computers. It's not wholly about the GPU. Sure, it helps but the CPU will be many times better. I don't know what software you're using for video editing, Acagliano, but focus more on the CPU. Go for an i7 Quad Core for the multi-threading as that will help you immensely. I have a quad-core i7 2.0GHz Mac mini from 2011 and it's still a power house. Doing tasks faster than my moms 2014 MacBook Pro, granted she has a dual core but it's clocked at 2.4Ghz. I know have a 2.9GHz Quad Core i7.
Professional software is very likely to be multithreaded. Heck, even iMovie is multi-threaded. Unless you're doing something that utilizes a GPU, like Motion, then you'll want to focus on GPU. Now, if you're render times are slow when exporting a movie, consider again the CPU. Now, if you
are using Final Cut Pro, you may be better off for the long term by purchasing two used Mac minis. Purchasing Compressor and install that on those Mac minis. Now you can distribute the video rendering across those computers. It's going to run you a little bit more than an eGPU route though.
Now, after writing all that I realized that you never mentioned video editing, that was in the post I replied to from TheLastMillennial. So, this is probably all for naught. But it may help someone in the future.
But to your initial question, I doubt it's worth it, let alone practical. Doesn't even look like you have Thunderbolt, just Firewire and DisplayPort, as
Thunderbolt was introduced in 2011.
