- Fake Green Technologies
- 29 Aug 2016 04:37:25 pm
- Last edited by jonbush on 29 Aug 2016 06:16:12 pm; edited 1 time in total
There's rightly been a lot of hype about electric cars in the past years; however, this is accompanied by what I see as irresponsible and misleading labeling (as are most consumer goods). When I was at the post office a few weeks ago, I saw a Nissan Leaf with the words "Zero Emissions" written on the side. In Washington State, this is nearly true because most of our power comes from hydro and nuclear. However, a sizable portion also comes from coal and natural gas combustion.
As you can see, the vast majority of energy consumed in the United States does not come from renewable sources. When you charge an electric car, emissions are almost certainly being produced. Now, if you live in a region where a sizable portion of your electricity comes from renewable sources, an electric car may indeed produce fewer net GHG emissions than a gas powered car. This article from Mother Jones discusses a study that found that the environmental damages from electric cars are higher than those of gas driven cars in some areas.
Gas Electric
Calculated environmental damages by type of vehicle. (I am skeptical of the accuracy of this chart.)
My point is that while electric cars may produce fewer emissions than regular cars in some regions, they are by no means "Zero Emissions." Labeling products in this way distracts from the actual problem, and can even worsen it. If you have an electric car that is less expensive to drive than a gas powered car, you may be inclined to drive it more than you otherwise would. Since it is labeled as "Zero Emissions" you feel that you have done no harm while you have actually produced more pollutants in some distant place.
_____________________________________________________________________________________________
The Tesla Powerwall is also bothersome to me in several ways.
First of all, there is simply no way that owning a Powerwall will save you money. PG&E peak electricity rates are $0.05/kWh greater than off peak rates. For the sake of this calculation, we will assume that the Powerwall is 100% efficient (which it of course is not). If the Powerwall stores 6.4 kWh of energy in one charge and costs $3,000, it will take $3000/(($0.05/kWh)*6.4kWh)=9375 cycles to break even. The problem is that the battery is only good for 1,000 to 1,500 cycles. If you throw in the fact that 8% of the energy is lost in the charging and discharging process, you would only save $327 on electricity over the course of 1,500 cycles (with the summer PG&E rates). In the end, your purchase will have saved you $327-$3000=$-2673.
Another problem is the use of this misleading diagram:
While it may be true that there is larger residential demand in the morning and evening, that demand is relatively insignificant compared to the overall peak demand. There is a reason why some electric companies charge peak rates during the middle of the day. This is what actual demand looks like:
It seems to me that the peak solar an peak demand line up much more closely than what Tesla claims.
Most grid-tie systems are between 94%-96% efficient, compared to the 92% efficiency of the Powerwall. By connecting a residential PV solar system to the grid, more of the energy produced will actually be consumed (albeit not by the homeowner).
Moreover, using a Tesla Powerwall is not an environmentally friendly choice. No matter how you slice it, using a Powerwall will result in the connected appliances indirectly consuming >108.6% of electricity they normally would. Even if the electricity used was produced during off-peak times, there will still be more GHG emissions produced.
Finally, there are many issues surrounding the sourcing of lithium and other metals used in the batteries. Producing billions more lithium-ion batteries is not going to solve our environmental problems.
https://en.wikipedia.org/wiki/Tesla_Powerwall
http://insideevs.com/solarcity-reveals-installed-pricing-for-tesla-powerwall/
https://en.wikipedia.org/wiki/Grid-tie_inverter
http://www.digitaltrends.com/cars/hold-smugness-tesla-might-just-worse-environment-know/
Where else do you see products or movements that distract from real problems by making people feel falsely good?
Please let me know if you find any discrepancies in my reasoning.
Gas Electric
