G-CLOCK is a clock add-in for CASIO fx-CG10/fx-CG20 Graphing Calculator:
Current functionality is just switching between main menu and the addin in 12-hour format timekeeping mode with PM and backlight indicator.
Look wise I tried other background colours closer to digital watch ones but they looked different even between LCD versions I have on my calculators and were certainly less legible at least when viewed at an angle so I opted for the white background at the end.
I may extend this add-in eventually to integrate with my LOCK add-in and possibly even a little bit more with the OS itself but for now it is even lacking time setup interface - you will have to use other tools to set it up at least once - I used gbl08ma's excellent Utilities add-in.
The other items on my to do list are: shortcuts to launch applications as if from the main menu (1 for Run-Mat, etc), running other commands, 24-hour format option, timer, stopwatch (maybe alarm and calendar), option to auto power off, changing the addin icon to look more like a digital watch in 3D at an angle, drawing weekday etc on the addin icon upon exiting it if I manage that.
I hope you will enjoy using this addin and look forward to your feedback.
See my signature below for add-in description and source code downloads archived here:
