I'm trying to access a user defined variable (N) from assembly. This is my code:
.nolist
#include "ti83plus.inc"
.list
.org   $9D95 - 2
.db      t2ByteTok, tAsmCmp
   LD HL, RealVariableN
   bcall(_Mov9toOP1)
   bcall(_RclVarSym)
   bcall(_DispOP1A)
   ret
RealVariableN:
   .db RealObj, "N", 0, 0 ;line 17
When N is not defined the code errors "UNDEFINED" (as expected), when N is defined (1→N) the error is "OVERFLOW". What am I doing wrong?
I'm going to assume you meant when N is defined there Smile It's because the register A is never set before you call _DispOP1A. Hope this helps! Smile
Edited, thanks Smile.
I added
LD A, 5
before that line, and the program has stopped crashing, but it still doesn't display anything to the screen. Do you know what the problem is?
Yeah, you probably just didn't set up penCol and penRow, but I imagine the real reason is you didn't copy the graph buffer to the screen at the end of your code Smile I think calling _GrBufCpy at the end will fix that.
I'll try tomorrow, thanks! Why should the graph buffer be copied though?
The graph buffer is basically where the screen data exists. Since the LCD screen is not memory mapped, it uses ports to write the data in the graph buffer to the physical screen Smile
I'm sorry it took so long, but it still doesn't work. My current code:
.nolist
.list
.org   $9D95 - 2
   bcall(_Mov9toOP1)
   bcall(_RclVarSym)
   LD A, 5
   bcall(_DispOP1A)
   bcall(_GrBufCpy)
   ret
RealVariableN:
The display show the axis and nothing else.
Sounds like you need to set (penCol) and (penRow) before the displaying Wink
