I have a question, I'm trying to make an mt3 song on calc using Mimas, but I don't know how to define "note(l1,l2,r1,r2,time)" because I'm not sure if this is an equate or a macro.
From what my basic knowledge of assembly tells me I would think it's a macro if it has parenthesis.
Only on Mimas I don't think you need parenthesis, so if this is intended for a different assembler then it's probably a macro.
Equates are normally
or something like this.
Hopefully I could help
name EQU 5 ;can be whatever needed
That looks like a macro, and Mimas doesn't support macros. However, you can look at the macro definition and simply expand the macro code yourself. For example, a macro that looks like
and you want to use as
would be expanded manually as
#macro dataThingy(x, y, z)
.db 30h, x
.dw y
.db z, 0h
#endmacro
dataThingy(someConstant1, someConstant2, someConstant3)
.db 30h, someConstant1
.dw someConstant2
.db someConstant3, 0h
.db 30h, x
.dw y
.db z, 0h
#endmacro
.dw someConstant2
Oh, alright thanks, that makes sense, I'll try that.
