Can someone explain to me how to get breakpoints and debugging of a basic ASM hello world application to work with CEmu?
This is a sample .lst file
    1 00:0000 -  -  -  -  #include "ti84pce.inc"
Listing for file "src/includes/ti84pce.inc"
Listing for file "src/string.asm"
    2 00:0000 -  -  -  -
    3 00:0000 -  -  -  -  .assume ADL=1
    4 00:0000 -  -  -  -  .org userMem-2
    5 D1:A87F EF 7B -  -  .db tExtTok,tAsm84CeCmp
    6 D1:A881 CD 28 08 02     call _homeup
    7 D1:A885 CD 10 08 02     call _ClrScrnFull
    8 D1:A889 -  -  -  -
    9 D1:A889 21 96 A8 D1     ld hl,MyText
   10 D1:A88D CD C0 07 02     call _PutS
   11 D1:A891 -  -  -  -
   12 D1:A891 FD CB 00 AE     res donePrgm,(iy+doneFlags)
   13 D1:A895 C9 -  -  -      ret;
   14 D1:A896 -  -  -  -
   15 D1:A896 -  -  -  -  MyText:
   16 D1:A896 54 68 69 73
              20 69 73 20
              61 6E 20 65
              78 61 6D 70
              6C 65 20 6F
              66 20 73 6F
              6D 65 20 74
              65 78 74 00     .db "This is an example of some text",0
I have a tried adding a breakpoint for address D1A881 and nothing seems to `break`, am I missing something?
Is there a way for me to see the assembly code that is running when my application is running?
I assume that after adding the breakpoint, you actually ran the program? If so, maybe check that you haven't accidentally enabled the "disable breakpoints" button:
Also, if you're using spasm as an assembler, I suggest using the -L flag. It should create a .lab file that you can load into CEmu's debugger via the load equates button (the folder button to the right of "Equates:"), allowing you to see label names and go to them by name rather than by address.
Thanks Runer, let me try that out.
