So I'm working on AoCE, and I came to the stage where I have to convert isometric tile coordinates to screen coordinates. This itself is not very difficult, just something like
var isoToScreen = function(x, y) {
    var posX = (x - y) * tileW;
    var posY = (x + y) * tileH / 2;
    return [posX, posY];
would work. However; this formula assumes that the topleft corner (coordinates (0,0)) is at a fixed position, and eventually visible. Sadly, my field doesn't fit in the entire screen, so I have to work with offsets. This didn't turn out well ☹️ Can someone *maybe* check what's wrong with my code/formulas?
; Check if we need to draw the puppet:
; X_tile - Y_tile in [X_1-Y_1,X_1-Y_1+9]
; X_tile - Y_tile - (X-1 - Y_1) in [0,9]
; X_tile - Y_tile - (iy+0) in [0,9]
; X_tile + Y_tile in [X_1+Y_1,X_1+Y_1+23]
; X_tile + Y_tile - (X_1+Y_1) in [0,23]
; X_tile + Y_tile - (iy+3) in [0,23]
; Check if X is in the range
    ld a, (ix+puppetX)
    sub a, (ix+puppetY)
    sbc hl, hl
    ld l, a
    ld de, (iy+TopLeftXTile)
    or a, a
    sbc hl, de
    ld (iy+6), l
    ld de, -10
    add hl, de
    jr c, DontDrawPuppet
; Check if Y is in the range
    sbc hl, hl
    ld a, (ix+puppetX)
    add a, (ix+puppetY)
    ld l, a
    jr nc, +_
    inc h
_:  ld de, (iy+TopLeftYTile)
    or a, a
    sbc hl, de
    ld (iy+7), l
    ld de, -24
    add hl, de
DrawPuppet:
    ld a, (iy+6)
    add a, (iy+7)
    add a, a
    add a, a
    add a, a
    add a, 31
    ld hl, variables+OFFSET_Y ; just the offset from the screen, since the field is shifted with 4 pixels each time
    add a, (hl)
    ld l, a
    ld h, 160
    mlt hl
    add hl, hl
    ld e, (iy+6)
    ld d, 16
    mlt de
    add hl, de
    ld a, (variables+OFFSET_X)
    ld d, 0
    ld e, a
    add hl, de
    ld de, (currDrawingBuffer)
    add hl, de
The output is HL=pointer to topleft corner of the right tile.
