So, fun fact: floating point numbers can be changed to a variable reference instead, kind of like a shortcut on your computer, and the OS doesn't verify it.
In assembly, when you are looking for a variable, you put a name in OP1 and use FindSym or ChkFindSym. Those names are 9 bytes, which is also the size of a float (not a coincidence-- it's part of why names are limited to 8 bytes).
You can actually change the contents of a Real variable to such a name, and when you try to read it's value, it will instead return the value of the variable it points to.
For example, change the bytes of the Real variable, A, from 008000000000000000 (the number 0) to 015D01000000000000 and when you read A, it will return the contents of L2.
Or, since lists are just stored as a bunch of Real (or Complex) numbers, you can modify elements of the list to be pointers. In this way, you could read Str1, Str2, Str3,..., Str0 by reading an element of L1, which could be useful, occasionally
Some things to note:
You can't modify the contents of the original variable in this way. If A points to Str2, then "33"+A→A does not modify Str2. However, "33"+A will work like "33"+Str2.
Storing the names of programs and appvars and whatnot isn't useful.
Here(download) is a program that turns L1 into a 4-element list {L2,[A],Str1,L1}. Here is the source. You need to delete L1 first, my code wasn't reliably deleting it.
#define bcall(x) rst 28h \ .dw x
rMOV9TOOP1 = 20h
_ChkFindSym = 42F1h
_CreateRList= 4315h
.db $BB,$6D
.org $9D95
ld hl,name
rst rMOV9TOOP1
bcall(_ChkFindSym)
ret c
ld hl,name
rst rMOV9TOOP1
ld hl,4
bcall(_CreateRList)
inc de
inc de
ld hl,data
ld bc,31
ldir
ret
data:
.db 1,$5D,1,0,0,0,0,0,0
.db 2,$5C,0,0,0,0,0,0,0
.db 4,$AA,0,0,0,0,0,0,0
name:
.db 1,$5D,0,0
