I'm working on my own version of stack in assembly, and everything seems ok, but when I press enter (to place the blocks) the blocks always move once before actually stopping. Here is a gif that shows that, in which I try to place the blocks exactly on the blocks below it:
I think it might be a problem with my code, so I'll post it here:
Also, I'm kind of new to assembly, so a lot of things might not be optimized, and I'm not sure that is the best program structure possible.
Any help would be appreciated
#include "..\include\ti84pce.inc"
.assume ADL=1
.db tExtTok,tAsm84CECmp
.org userMem
call _ClrScrnFull
;draw walls
ld a,4
call draw_wall
ld a,21
call draw_wall
jp wallend
draw_wall:
ld (curCol),a
ld b,10
wall_loop:
dec b
ld a,$3A
ld hl,curRow
ld (hl),b
call _PutMap
jp nz,wall_loop
ret
wallend:
;draw bottom stack
ld a,9
ld (curRow),a
ld a,11
ld (curCol),a
ld a,$30
call _PutC
call _PutC
call _PutC
call _PutC
ld a,8 ;initial height
loopa:
ld (curRow),a
ld a,(targetx)
inc a
ld (curCol),a
ld a,$30
ld hl, block_length
ld b,(hl)
loopb:
call _PutC
djnz loopb
ld hl,targetx
ld c,(hl)
inc c;increase c first so the player can't just hold down enter
loopc: ;while enter key not pressed
call _GetCSC
cp a,skEnter
jp z,enter_pressed
;d will be the one to draw when going right, the one to erase when going left
;e will be the one to erase when going right, the one to draw when going left
ld a,c
ld hl,block_length
add a,(hl)
ld d,a
ld e,c
smc1:
inc c ;inc c ($0C) when going right, dec c ($0D) when going left
smc2:
ld a,d ;ld a,d ($7A) when going right, ld a,e ($7B) when going left
ld (curCol),a
ld a,$30
call _PutMap
smc3:
ld a,e ;ld a,e ($7B) when going right, ld a,d ($7A) when going left
ld (curCol),a
ld a,$20
call _PutMap
;time for delay
ld hl,$0FFFFF
loopd:
dec hl
add hl,de
or a,a
sbc hl,de
jp nz,loopd
;see if bumped into wall
smc4: ;you won't modify ld a, only the value after that, so only modify smc4+1
ld a,17 ;bound left: 4, bound right: 21-block_length
cp a,c
jp z,reverse_dir
jp loopc
reverse_dir:
ld a,(direction)
cp a,0
jp z,turn_right
;turn left
ld a,0
ld (direction),a
ld a,$0D
ld (smc1),a
ld a,$7B
ld (smc2),a
ld a,$7A
ld (smc3),a
ld a,4
ld (smc4+1),a
dec c
jp loopc
turn_right:
ld a,1
ld (direction),a
ld a,$0C
ld (smc1),a
ld a,$7A
ld (smc2),a
ld a,$7B
ld (smc3),a
ld a,21
ld hl,block_length
sub a,(hl)
ld (smc4+1),a
inc c
jp loopc
enter_pressed:
ld a,(targetx)
cp a,c
jp z,rightpos
;wrong pos
rightpos:
ld a,(height)
cp 0
jp z,disp_gameover
dec a
ld (height),a
jp loopa
disp_gameover:
call _ClrScrnFull
smc6: ;modify youwin to youlose, not ld hl, so only do smc6+1
ld hl,youwin
ld a,0
ld (curRow),a
ld (curCol),a
call _PutS
ret
height:
.db 8
block_length:
.db 4
direction:
.db 1
targetx:
.db 11
youwin:
.db "You win!",0
youlose:
.db "You lose",0
