I wanted to use keep using the 'drawSprite' routine, and call it 20 times. I am sure i can learn something from yoir code though Smile
Oh Sorry, I thought you were looking for a faster way Smile
In your version , you can replace "ld d,h / ld e,l" with ex de,hl
renderBkgd:
 ld b,20 ;render 20 times
 ld de,vRam
renderBkgdLoop:
   push bc
   ld hl,titleReapeat_sprite   ; The sprite
   push de
    call drawSprite
   pop de
   ld hl,16
   add hl,de
   ex de,hl           ; ld d,h
                          ;ld e,l ;de = de+16
   pop bc
   djnz renderBkgdLoop
How can i read (but not write) the data located in an archive program, without copying it to ram? I know i can do this in axe on the Ti84+.
I only know the program's name.
Archived things store the VAT entry at the start of the archived data. It's a simple matter to get around it though with a small bit of code. If HL points to the name of your program (including the object type at the start of the name, ie, 'db progobj,"TEST",0', then you can use the following code to ensure that 1) The variable is placed in the archive, and 2) that it exists, otherwise it returns the data pointer as 0. This routine will make hl->start of program data. Hope this helps! Smile
_finddata:
   call   _mov9toop1
   call   _chkfindsym
   jp   c,__notfound  ; routine to run if not found
   call   _chkinram
   ex   de,hl
   jp   nz,__inarc
   jr   __skipsize
__notfound:
   or   a,a
   sbc   hl,hl
   ret
__inarc:
   ld   de,9
   add   hl,de
   ld   e,(hl)
   add   hl,de
   inc   hl
__skipsize:
   inc   hl ; bypass size bytes
   inc   hl
So, to make sure, after this code is ran hl will point to data that is the same as in prgm test, regardless if prgm test is in ram or archive?
Yeah, it will archive program test to just make sures Smile
EDIT: Changed the above code so that HL points to either the data in ram or the data in the archive.
I have this piece of code:
   ld hl,folderName
   call _mov9toop1
   ld hl,0
   ld a,(inputLength)
   inc a
   ld l,a
   call _CreateProtProg
If i *dont* comment out "call _CreateProtProg", the Y= vars will be corrupted.
I have confirmed that (inputLength) is a normal value and is not at fault. Even if i do 'ld hl,5' right before the call, the Y= vars still get corrupted.
   ld hl,folderName
   call _mov9toop1
   ld hl,0
   ld a,(inputLength)
   inc a
   ld l,a
Are you in an edit buffer context? If so, you need to switch out of it. Smile
Yes i am. I am trying to switch contexts with:
      ld a,kExtApps
      call _NewContext
However it gives me "ERROR: VALIDATION".
Geekboy said to use some other context, but as i said it wasn't in the include file. A very similar named context *was* in the include file, but it was set EQU to kExtApps
I am trying to set up a parser hook.
This is my basic test program:
Asm(prgmINSTLAPI)
For(X,1,10
X:Disp sin(X
This is prgmINSTLAPI, which sets up the hook.
   ld hl,HookAppvar
   call   _mov9toop1
   call   _chkfindsym
   ex de,hl
   ld bc,0
   ld c,(hl)
   inc hl
   ld b,(hl)
   inc hl
   ld de,pixelShadow2
   ldir
   ld hl,pixelShadow2
   call _SetParserHook
   ret
And lastly this is the hook itself:
.nolist
#include "ti84pce.inc"
.list
   .org pixelShadow2
    .db $83
        or a                ; Which condition?
        ret z
        push hl
        ld hl,0C2C2h        ; Is it the 'sin(' token?
   ;ld hl,$00BBC2 ;t2ByteTok and tSin
        sbc hl,bc
        pop hl
        jr nz,ReturnZ
        dec hl
        call _DeallocFPS  ; free unused parameters
        call _RclAns
        or 1                ; set NZ
      ret
ReturnZ:
        cp a
        ret
@mateo: The reason i replaced 0C2C2h with $00BBC2 is becouse the include file lists t2ByteTok as $BB and tSin as C2.
So since this will mainly be for testing, it is generally easier to just use pixelshadow2 for this. There's no real point in trying to make it into an appvar unless that appvar is in ROM, where it can't be moved around as easily. Anywho, I don't see any reference to the hook appvar itself, so I have no way to use that code. But based on WikiTI, you are running a class 1 token. Here's some working example code that may be of some use to you, just to get an idea Smile
   .db   tExtTok,tAsm84CECmp
   .org   usermem
   ld   hl,hook_start
   ld   bc,hook_end-hook_start
   ld   de,pixelshadow2
   push   de
   ldir
   pop   hl
   jp   _SetParserHook   ; set the parser hook
hook_start:
   .db   $83
   or   a,a      ; which condition?
   ret   z
   call   _SetBCUTo0
   push   hl
   ld   hl,$C2C2   ; sin( token?
   sbc   hl,bc
   pop   hl
   jr   nz,+_
   dec   hl
   call   _RclAns
   or   a,1      ; set NZ
   ret
_:
   cp   a,a
   ret
hook_end:
I have trouble getting the amount of arguments passed to the parser hook. For a function like "Sin()", the amount of arguments i give it is correctly expressed by HL. However for a function like "Line()" (And [some(?)/all(?)] other drawing) commands, HL holds the value 032DBC and (numArguments)=1.
(This seems to be true for all drawing commands)
My hook code:
http://pastebin.com/4zdM5jTf
Did you read about the different classes of functions? http://wikiti.brandonw.net/index.php?title=83Plus:Hooks:9BAC
Indead Smile
"Line()" isnt class 2 becouse arguments *are* passed. It can't be class one because HL does not contain the # of args. According to wikiti, for class 3 functions, " the number of arguments is stored at 9661[numArguments]". However, the address $0D02320 (numArguments as defined in the latest CE include file) always holds the number one, instead of the correct amount of args.
Page 2 of 2
