I have been working on a simple program that will allow programmers to easily align their text on the homescreen. Center and right aligning will center/right align the inputted text, and the custom aligning for text allows the user to move the text with the left and right arrows. Also, pressing 1, 2, and 3 are hotkeys for align left, align center, and align right, respectively.
The code works without flaws ... mostly. If I input a token like Str2 or angle(, because I use length(Str1) to determine how many characters are in the string, it does not work. This happens because length( counts the number of tokens in a string, not the amount of space they take up when displayed on the screen (for example, Str1 would be 4 and angle( would be 6). Is there a way for me to fix this problem, or should I just advise users in the readme not to input any tokens with more than one character or it will not work? Thanks!
ClrHome
Output(1,1,"Operation For Text
Output(3,2,"Center
Output(4,2,"Align Right
Output(5,2,"Align Custom
Output(6,2,"Quit
Output(3,1,">
3→Q
Repeat K=21 or K=105
getKey→K
If Ans=25 or Ans=34
Then
Output(Q,1," "
Q-(K=25)+(K=34)→Q
If Q=2:6→Q
If Q=7:3→Q
Output(Q,1,">
If Q=6
Then
ClrHome
Return
If Q=3:"Center Text→Str2
If Q=4:"Align Right→Str2
If Q=5:"Align Custom→Str2
Repeat L<27
ClrHome
Disp "--Align Home Screen Text--",""
Input "Your text:",Str1
length(Str1)→L
If L>26:Then
ClrHome
Disp "Less than 27 characters,","please!"
Pause
End:End
ClrHome
If Q=3:iPart(14-.5L)→A
If Q=4:27-L→A
If Q=5:1→A
For(X,1,26
Output(9,X,"-
Output(1,A,Str1
Output(4,1,"Use Output(…, ,Your text
Output(4,14,A
Output(6,1,"Your text is stored in Str1.
Output(10,iPart((14-length(Str2)/2)),Str2
If Q=5:Then
Output(8,7,"Press <CLEAR>
0→K
Repeat Ans=45
If K=92 or K=93 or K=94:Then
For(A,1,26
Output(1,A,"
(K=92)→A
If K=93:int(14-.5L)→A
If K=94:27-L→A
Output(1,A,Str1
Output(4,15,"
Output(4,14,A
A→V
A+(K=26)-(K=24)→A
If A>(27-L)
27-L→A
If A=0:1→A
If A≠V:Then
Output(1,V,"
Output(1,V+L-1,"
Output(1,A,Str1
Output(4,15,"
Output(4,14,A
getKey→K
End:End
Output(8,7,"Press <ENTER>
Pause
ClrHome
DelVar Str2DelVar ADelVar BDelVar KDelVar LDelVar QDelVar VDelVar XThe code works without flaws ... mostly. If I input a token like Str2 or angle(, because I use length(Str1) to determine how many characters are in the string, it does not work. This happens because length( counts the number of tokens in a string, not the amount of space they take up when displayed on the screen (for example, Str1 would be 4 and angle( would be 6). Is there a way for me to fix this problem, or should I just advise users in the readme not to input any tokens with more than one character or it will not work? Thanks!
