Greetings everyone! My name is Roy and I live in Paraguay (South America) with my missionary parents. Recently I got a TI-84 Plus CE for my personal school work but when I visit the natives in the countryside I let them play games on my calculator. Their favorite game is portal but after about level 15 (when you really need the hint messages before each level) they can't pass the levels because they don't speak English. I would like to edit the text before each level into their native language of Guaraní so they can play too! If someone could make a how to list in the replies on how to edit the text in SourceCoder3 and then update the ASM program itself so it shows up when it is launched. Thanks to everyone in advance 🙂 Graphing Calculator
Well, the short answer is that you cannot. However, you actually can. 🙂 Here is the text for each level; I would be more than happy to reassemble the program using translated text. Line separations signify different levels. In addition, I can also change any text you would like me to in the game; just let me know. Thank you! 🙂
WELCOME, TEST SUBJECT.
HERE AT APERTURE LABS, WE
PROVIDE THE BEST IN TESTING.
TODAY YOU WILL BE TESTING OUR
CLASSIC PORTAL DEVICE. USE
THE KEYS 1-9 TO FIRE
INTERDIMENSIONAL PORTALS.
CAKE WILL BE SERVED.
WELL DONE!
AS YOU MAY HAVE OBSERVED,
PORTALS CONSERVE MOMENTUM.
IN LAYMAN'S TERMS, SPEEDY
THING GOES IN, SPEEDY THING
COMES OUT.
MOST IMPORTANTLY, REMEMBER...
WE LEARNED EARLY ON THAT
EASIER TESTING CHAMBERS
SHOULD GO BEFORE SOME OF OUR
MORE DIFFICULT ONES.
CONGRATULATIONS ON THAT LAST
ONE THOUGH. IT WAS NECESSARY
TO MAKE SURE YOUR COGNITIVE
ABILITIES STILL FUNCTION
AFTER WHAT HAPPENED.
I SHOULD PROBABLY TELL YOU
THAT THERE ARE SPIKES IN THIS
NEXT CHAMBER.
SOME OF OUR LESS ABLE
SUBJECTS DON'T DO SO WELL
WITH THEM.
DARN, YOU...LIVED?
GREAT, THAT MEANS TESTING CAN PROCEED AS USUAL.
IF YOU HAVEN'T FIGURED OUT YET, THE 5 KEY SWITCHES
THE NEXT PORTAL YOU FIRE.
LOOK AT THE LOWER RIGHT OF
EACH CHAMBER.
AFTER YEARS OF TESTING,
POSITIVE REINFORCEMENT HAS
SHOWN POSITIVE RESULTS.
SO GOOD JOB. THIS NEXT ONE REQUIRES
PRECISION TIMING.
DID YOU BRING A STOPWATCH
I'VE BEEN HERE MANY, MANY
YEARS, BUT THAT WAS THE
LONGEST I'VE SEEN SOMEONE
TAKE.
HOW DO THEY EXPECT ME TO
PROVIDE TIMELY DATA
NO CAKE UNLESS YOU MOVE A
LITTLE QUICKER.
I'M GOING TO GO CLEAN UP SOME THINGS WHILE
I WAIT FOR YOU TO FINISH THIS ONE. OH,
LET ME READ YOU THIS PRE-PROGRAMMED SCRIPT:
DOORS KEEP THINGS IN.
BUT THEY CAN ALSO BE USED TO
KEEP THINGS OUT.
WELL, NOW ALL THAT OLD TEST SUBJECT'S JUNK HAS
BEEN INCINERATED.
DOORS AREN'T TOO USEFUL WITHOUT
WEIGHTED COMPANION CUBES.
PRESS 2ND TO PICK THEM UP. THEY CAN BE USED TO OPEN DOORS. THEORETICALLY.
DO YOU REMEMBER WHY YOU ARE HERE?
IT'S ON FILE SOMEWHERE.
BUT AFTER EVERYONE EVACUATED, IT WAS PROBABLY LOST.
NO ONE IS REALLY SURE WHAT
THOSE CUBES ARE MADE OF.
LEAD, PROBABLY.
THIS NEXT TEST IS A QUIZ. DON'T FAIL.
SAY HELLO TO OUR APERTURE
SCIENCE MATERIAL EMANCIPATION GRID.
IT MIGHT CAUSE SOME INDIGESTION, AND IN SOME
SEMI-RARE CASES, CAUSE YOUR TEETH
TO FALL OUT. BUT IT ALSO RESETS YOUR
PORTAL DEVICE. THE LAST GUY NEVER FIGURED IT OUT.
WE HERE AT APERERTURE LABS WOULD
LIKE TO TELL YOU THE WEIGHTED
COMPANION CUBE WILL
NEVER THREATEN TO KILL YOU.
AS A MATTER OF FACT, THEY CAN'T TALK AT ALL.
THANK YOU FOR YOU INVALUED TIME.
SOME OF OUR APERTURE SCIENCE DEVELOPMENT
TEAM GOT LAZY WITH TESTING.
THEY BECAME A PART OF OUR SUBJECT PROGRAM,
AND AS EXPECTED, FAILED.
UNFORTUNATELY, THEIR WORK IS STILL HERE.
I USED TO HAVE THOUSANDS OF TESTS SUBJECTS.
BUT NOW IT IS JUST YOU AND ME. THIS NEXT ONE IS PRETTY HARD.
IF WE DON'T MEET AGAIN, GOODBYE.
PLEASE NOTE THAT THERE IS A NEW CONSEQUENCE FOR
FAILURE. ANY CONTACT WITH A SHARP
OBJECT WILL RESULT IN AN UNSATISFACTORY MARK ON YOUR
OFFICIAL RECORD, FOLLOWED BY DEATH.
I HAD AN ORIGINAL THOUGHT ONCE. THEN MY PROGRAMMING
KICKED IN. THIS NEXT CHAMBER CONTAINS A
HIGH ENERGY PELLET. IT IS QUITE EXPENSIVE TO
CREATE, SO WE WOULD APPRECIATE IF YOU DIDN'T GO NEAR IT.
WE USED TO SPEND SO MUCH TIME TOGETHER...
AND NOW WE CAN. THIS NEXT CHAMBER REQUIRES THOUGHT. I THINK.
AH, HISTORY. SOMETIMES
I WISH I COULD FORGET CERTAIN THINGS.
THAT PLASMA FIELD WILL KILL YOU.
WHICH MEANS THAT TESTING WILL CEASE.
WE CAN'T HAVE THAT, NOW CAN WE?
THAT PERSON WHO CREATED THOSE FIELDS
DID SO BY ACCIDENT. A BLOODY ONE.
NATIONAL REGULATIONS REQUIRE THE USE OF
A COMPANION CUBE IN THIS NEXT TEST.
THERE ARE SOME THINGS BETTER
LEFT UNSAID. THIS ISN'T ONE
OF THEM. FUN FACT: GLASS
WAS CREATED TO ALLOW PORTAL BEAMS TO GO THROUGH WALLS.
I WONDER HOW LONG YOU WILL
LAST IN THIS NEXT TEST. SOME
CHAMBERS HAVE AN EASY ROUTE. THIS IS ONE OF THEM.
TAKE THE HARD WAY IF YOU WANT...
APERTURE SCIENCE LABS WOULD
LIKE TO INFORM YOU THAT
CHAMBER MONITORING HAS BEEN DISABLED.
WOULD WE LIE TO YOU?
DO YOU WANT YOUR CAKE?
WE HAD A SUBJECT WHO WAS
A LITTLE SMARTER THAN THE
REST. HE DIDN'T DO SO WELL IN OUR TESTING ENVIRONMENTS.
WE HAD ONE GUY HERE WHO WENT CRAZY. ACTUALLY,
THAT'S NORMAL. PLEASE MAKE
YOUR WAY TO THE APERTURE SCIENCE
GRIEF AND COUNSELING CENTER IF YOU HAVE
A SUDDEN MENTAL BREAKDOWN.
FIZZZ....
WHAT WAS THAT?
DARN, LOOKS LIKE OUR ENHANCED
GRAVITY DEVICE HAS MALFUNCTIONED.
PLEASE CONTIUE AT MOON LEVELS OF
GRAVITY.
WELL, I WAS UNABLE TO FIX
THE MACHINE CORRECTLY.
NOW YOU ARE STUCK ON BLACK-HOLE LEVELS OF
GRAVITATIONAL FORCE.
OH WELL.
THERE'S A SURPRISE HAPPENING IN:
3..............
2........
1...
ERROR: ERROR CODE: 0
I HAVE TO GO ERADICATE SOME
CHAMBERS. WITH NEUROTOXINS.
BY THE WAY, DID WE MENTION
THAT PORTALS CONTAIN HIGH
LEVELS OF GAMMA RADIATION
I HAVE A PROCESSING POWER OF 112 EXAFLOPS.
MY AI HAS SURPASSED ALL KNOWN STANDARDS.
YOUR BRAIN COULD BARELY POWER A LIGHTBULB.
WELL, THAT WAS INTERESTING.
APERTURE LABS WOULD LIKE TO REMIND
YOU THAT COMPANION CUBES CAN'T SPEAK.
IF THEY DID THOUGH, THEIR ADVICE SHOULD BE
IGNORED.
THE ENRICHMENT CENTER REGRETS
TO INFORM YOU THAT THIS NEXT
TEST IS IMPOSSIBLE. MAKE NO ATTEMT TO SOLVE IT.
APERTURE SCIENCE REGRETS TO INFORM YOU
THAT THIS IS THE FINAL CHAMBER. HAVE A NICE DAY!
SOME CHAMBERS INSPIRE HAPPINESS.
THIS IDEA WAS CREATED AROUND THE
SAME TIME AS THE DISCONTINUATION OF
OUR APERTURE SCIENCE LAUGHING GAS.
OF COURSE, CAKE IS JUST AS INSPIRING.
PROMISES TO ALWAYS PROVIDE A
SAFE TESTING ENVIRONMENT.
IN DANGEROUS TESTING
CHAMBERS, THE ENRICHMENT
CENTER PROMISES TO PROVIDE
USEFUL ADVICE.
AVOID THE KILLY THINGYS.
QUIT NOW AND CAKE WILL BE SERVED IMMEDIATELY.
WE CAN'T LIE.
SOME SAY YOU CAN'T HAVE
YOUR CAKE AND EAT IT TOO.
FINISH THIS TEST AND YOU CAN
HAVE BOTH.
DO REMEMBER ANYTHING ABOUT A POTATO?
DID YOU REALLY THINK IT WOULD BE THAT EASY
TO LEAVE OUR TESTING FACILITIES?
DO NOT ATTEMT TO ESCAPE!
YOU WILL BE BAKED. AND CAKE WILL BE SERVED.
YUM.
HELLO?
ARE YOU STILL THERE?
WHERE ARE YOU?
I GUESS YOU MADE IT THROUGH.
FINE, IF YOU WANT TO LEAVE,
I GUESS I GET ALL THIS
CAKE TO MYSELF.
GOODBYE.
PRESS Y= TO FLY
Thanks Mathew! I wasn't able to mass translate the text into Guaraní (this process would be torturous) but I was able to translate it into Spanish (which ahould be sufficient). I was wondering if you could maybe teach me how to do this though so I could change other game's instruction into Spanish or Guaraní instead of asking you every time I need the program edited. Thanks a lot 🙂
BIENVENIDOS, sujeto de prueba.
Aquí en Aperture Science, WE
Proporcionar el mejor en las pruebas.
Hoy estarás PRUEBA NUESTRA
DISPOSITIVO PORTAL CLÁSICO. USAR
LAS CLAVES 1-9 AL FUEGO
PORTALES interdimensional.
TORTA SE SIRVE.
¡BIEN HECHO!
Como usted pudo haber observado,
PORTALES conservar el momento.
En términos sencillos, SPEEDY
COSA VA EN, COSA SPEEDY
SALE.
LO MÁS IMPORTANTE, RECUERDE ...
APRENDIMOS desde el principio que
MÁS FÁCILES CÁMARAS DE PRUEBAS
DEBE IR ANTES DE ALGUNOS DE NUESTROS
Las más difíciles.
FELICITACIONES POR QUE PASADA
AUNQUE UNO. ERA NECESARIO
Para asegurar que su COGNITIVO
HABILIDADES siguen funcionando
Después de lo ocurrido.
Probablemente debería DECIRLE
QUE HAY PUNTOS EN ESTA
CÁMARA NEXT.
ALGUNOS DE NUESTROS menos capaces
Sujetos no hacemos tan bien
CON ELLOS.
DARN, USTED ... vivió?
Grande, que los medios de prueba puede proceder como de costumbre.
SI no han descubierto embargo, el 5 de llave
EL FUEGO SIGUIENTE PORTAL USTED.
MIRE LA INFERIOR DERECHO DE
Cada cámara.
DESPUÉS años de pruebas,
REFUERZO POSITIVO TIENE
RESULTADOS POSITIVOS muestra.
TAN BUEN TRABAJO. Esta próxima REQUIERE
TIEMPO DE PRECISIÓN.
¿Trajiste un cronómetro
He estado aquí muchas, muchas
AÑOS, PERO QUE FUE EL
ALGUIEN MÁS LARGO HE VISTO
LLEVAR.
¿Cómo esperan ME
Ofrecer datos a tiempo
NO LA TORTA DE MENOS QUE SE MUDA A
Poco más rápido.
Yo voy a ir a limpiar algunas cosas mientras
Te espero terminar este ONE. OH,
Permítanme leerles este script pre-programados:
PUERTAS mantener las cosas en.
Pero también pueden ser utilizados para
MANTENER LAS COSAS FUERA.
Pues bien, ahora todo eso DEL SUJETO DE PRUEBA VIEJO TIENE
Sido incinerados.
PUERTAS NO SON MUY ÚTIL SIN
CUBOS DE COMPAÑÍA ponderado.
Pulse 2nd para recogerlos. Pueden ser utilizados para abrir las puertas. Teóricamente.
USTED RECUERDA POR QUÉ USTED ESTÁ AQUÍ?
ES EN ARCHIVO EN ALGUNA PARTE.
PERO DESPUÉS DE TODOS evacuado, probablemente era PERDIDO.
Nadie está realmente seguro de lo
LOS CUBOS SE HACEN DE.
LEAD, probablemente.
ESTA PRUEBA SIGUIENTE ES UNA PRUEBA. Nunca faltan.
Da la bienvenida a NUESTRA APERTURA
CIENCIA DE MATERIALES EMANCIPACIÓN RED.
TI podría producir cierta indigestión, y en algunos
CASOS SEMI-RARE, causar que los dientes
A caerse. Pero también Restablece
DISPOSITIVO PORTAL. EL INDIVIDUO ÚLTIMA NUNCA lo descubrió.
Estamos aquí, en APERERTURE LABS HARÍA
GUSTARIA DECIRLE LA PONDERADO
VOLUNTAD CUBE COMPAÑERO
NUNCA amenazan con matarte.
AS DE HECHO, QUE NO PUEDEN HABLAR EN TODO.
¡GRACIAS POR USTED invaluados TIEMPO.
ALGUNOS DE NUESTRO DESARROLLO CIENCIA DE APERTURA
EQUIPO CONSEGUIDO PEREZOSO CON PRUEBAS.
Se convirtieron en una parte de nuestro programa TEMA,
Y como era de esperar, FALLADO.
Desafortunadamente, su trabajo está todavía aquí.
Tenía miles de pruebas TEMAS.
Pero ahora es sólo tú y yo. ESTE LADO UNO ES BASTANTE DURO.
SI NO Meet Again, ADIÓS.
TENGA EN CUENTA QUE HAY UN NUEVO CONSECUENCIA DE
FALLO. CUALQUIER CONTACTO CON UN SHARP
OBJETO DARÁ LUGAR A UNA MARCA INSATISFACTORIO EN SU
REGISTRO OFICIAL, seguida de muerte.
TENÍA UN PENSAMIENTO ORIGINAL UNA VEZ. ENTONCES MI PROGRAMACIÓN
PATADA EN. ESTE PRÓXIMO cámara contiene una
PELLET DE ENERGÍA DE ALTA. Es bastante caro A
CREAMOS, por lo que agradecería si usted no fue CERCA DE TI.
Solíamos pasar TIEMPO muchas cosas juntos ...
Y ahora podemos. ESTE LADO DE CÁMARA REQUIERE PENSAMIENTO. YO CREO QUE.
AH, HISTORIA. A VECES
Me gustaría poder olvidar ciertas cosas.
QUE CAMPO DE PLASMA te matará.
QUE SIGNIFICA QUE PRUEBAS cesará.
NO PODEMOS TENER QUE, AHORA PODEMOS?
ESA PERSONA QUE CREARON LOS CAMPOS
Lo hizo por accidente. A UN SANGRIENTO.
REGLAMENTOS NACIONALES requieren el uso de
UN CUBO COMPAÑERO EN ESTA PRUEBA SIGUIENTE.
Hay algunas cosas MEJORES
Dejado sin decir. ESTO NO ES UNA
DE ELLOS. DATO CURIOSO: VIDRIO
Fue creado para permitir PORTAL HACES PARA IR A TRAVÉS DE LAS PAREDES.
Me pregunto cuánto tiempo va a
ÚLTIMO EN ESTA PRUEBA SIGUIENTE. ALGUNOS
CAMARAS tener un fácil RUTA. ESTE ES UNO DE ELLOS.
TOMAR EL CAMINO DURO SI QUIERES ...
Aperture Science LABS HARÍA
Les informamos QUE
MONITOREO DE CÁMARA ha sido desactivado.
¿Nos mienten a usted?
¿Quieres que tu pastel?
Tuvimos una SUJETO QUE ERA
UN POCO MÁS INTELIGENTE QUE LA
DESCANSO. Él no lo hizo tan bien en nuestros entornos de prueba.
Tuvimos un tipo aquí que se volvió loco. EN REALIDAD,
ESO ES NORMAL. POR FAVOR HAZ
SU CAMINO A LA CIENCIA DE APERTURA
DUELO Y CONSEJERÍA CENTRO SI TIENE
Un colapso mental SÚBITA.
FIZZZ ....
¿QUÉ FUE ESO?
DARN, parece que nuestro MEJORADA
DISPOSITIVO DE GRAVEDAD ha funcionado mal.
POR FAVOR contiue EN LA LUNA NIVELES DE
La gravedad.
Bueno, yo era incapaz de fijar
LA MÁQUINA CORRECTAMENTE.
Ahora usted está atascado en NIVELES DE NEGRO-AGUJERO DE
FUERZA GRAVITACIONAL.
OH BIEN.
HAY UNA SORPRESA sucediendo en:
3 ..............
2 ........
1 ...
TENGO QUE IR ERRADICAR ALGUNAS
CAMARAS. CON neurotoxinas.
POR CIERTO, ¿Mencionamos
Que los portales contienen altos
NIVELES DE RADIACIÓN GAMMA
TENGO UNA POTENCIA DE PROCESAMIENTO DE 112 EXAFLOPS.
MI AI ha superado NORMAS todos conocidos.
SU CEREBRO apenas podía PODER Una bombilla.
Bueno, eso era interesante.
Aperture Science gustaría recordar
USTED QUE LOS CUBOS DE COMPAÑÍA NO PUEDE HABLAR.
Si lo hicieron, sin embargo, su consejo DEBE SER
Ignorados.
Lamenta Centro de Enrequecimiento
A informarle que esta SIGUIENTE
PRUEBA ES IMPOSIBLE. HAZ QUE NO attemt para resolverlo.
Aperture Science lamenta informar USTED
QUE ESTA ES LA CÁMARA DE FINAL. ¡QUE TENGAS UN BUEN DÍA!
Algunas cámaras INSPIRE FELICIDAD.
Esta idea fue creada alrededor del
Mismo tiempo que el INTERRUPCIÓN DE
NUESTRA Aperture Science gas de la risa.
POR SUPUESTO, LA TORTA ES SOLO COMO INSPIRACIÓN.
EL CENTRO DE ENRIQUECIMIENTO
Promete proporcionar SIEMPRE A
MEDIO AMBIENTE PRUEBAS DE SEGURO.
EN PRUEBA DE PELIGROSO
CAMARAS, EL ENRIQUECIMIENTO
CENTRO promete proporcionar
CONSEJOS ÚTILES.
EVITAR LA KILLY thingys.
SALIR AHORA Y TORTA SE SERVIRÁ DE INMEDIATO.
NO PODEMOS MENTIR.
Algunos dicen USTED NO PUEDE TENER
Su pastel y comérselo también.
TERMINAR ESTA PRUEBA Y USTED PUEDE
Tener ambas cosas.
RECUERDA NADA SOBRE UNA PATATA?
¿De verdad crees que sería ASÍ DE SENCILLO
DEJAR NUESTRAS INSTALACIONES DE PRUEBA?
NO attemt ESCAPAR!
USTED SERÁ AL HORNO. Y TORTA SE SIRVE.
MMM.
¿HOLA?
¿SIGUES AHÍ?
¿DÓNDE ESTÁS?
Supongo que lo hizo a través.
Bien, si quieres dejar,
Supongo que conseguir todo esto
PASTEL DE MÍ MISMO.
ADIÓS.
PRENSA Y = A VOLAR 👍 👍 Graphing Calculator
