I need help animating in TI-Basic. I know you can animate using the text( command and the sub-string command but I really have no idea how. I need some help and someone who can really teach me how to do this. Can someone please help me here?? Thanks a-ton 🙂
this is for a Ti 84+SE
I am simply trying to make an animation for the opening game screen, and I have no idea how to do it.
NON C. VERSION OF CALC.
Which calculator, and what type of animation? I know the cse has some libraries that can help with animations, but it depends which kind.
If you are trying to slide text across the screen, you can do this:
For(A,1,260
Text(A,1,"text
; erasing code
But thats fairly cruel 😛
What I think you could do for some sliding text would be:
"[Your text]"->Str1
For(A,1,length(Str1)-[how many letters to display at once]
Text(~1,0,0,sub(Str1,A,A+[how many letters to display at once]
/ Maybe use Text(~1,0,0,"                                           " to erase the text
Take a look at this gif. The text is scrolling from right to left here:
Does that help?
Well, I did some testing, and this code should work for all lengths of words.
ClrDraw
Repeat getkey
For,A,1,94
Text(1,A,"Menu  // Your text goes here
Text(1,A-1,"_
randrandrand
randrandrand
randrandrand
You can decrease the rands to spead it up, and increase to slow down 🙂
However, it can easily be changed. I think it works pretty well. Here is the code:
"THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT THIS IS A BUNCH OF TEXT"->Str1
For(A,1,length(Str1)-10
Text(~1,0,0,sub(Str1,A,A+10
Pause
i could create a fairly complex(ish) one, but it depends on what you want. A simple text slide would work fine if you're not wanting anything too fancy, or you could get a bit more advanced (keeping it pure BASIC) and possibly lose a tiny bit of fps.
Here's an animation of mine, working on a 84+ SE, with MATHPRINT on.
ClrDraw
Repeat getkey
For(A,1,94
Text(1,A-1,"_
randrandrand
batman: Do you want the text to scroll across the screen the way Unicorn's is, or have it be all in a specific area with the text scrolling in the box? Also, if you use Text(~1,...,...,"Your Text"), you can make the text much larger and easier to read. I recommend doing this for the titles of menus, and not using the negative one for the options so that the title is a larger font size.
I second readroofs suggestion about larger text. You can probably add some Text( commands that make my code look a bit more seamless though.
thanks.
earthnite wrote:
Instead of randrandrandrand ....
You can use rand(4
save some space...
I think this wouldn't work since rand(4 would return 4 random numbers in a list, and randrandrandrand would return only 1, they don't do the same thing... (But I'd have to test it out to know for sure)
