Uh, is this still being worked on?
» Forum
> Your Projects
xXEllesarXx wrote:
Can I be a tester?
Sorry, I've finished the game. I didn't see this because I was busy in real life, and didn't have time to check here.
Excelseo wrote:
M. I. Wright wrote:
If I'm not mistaken, I believe those commands require you to be in hasf-res mode, and if I used real(8,2,... it might look a little silly to see the screen zoom in and then shake a little bit back and forth. I'll see if it would look better.
solarsoftware wrote:
This looks awesome! How did you manage to get the screen to shake like that? Is it real(0,1,1 and real(0,1,0,1?
Looks like it, although a better screen shake could be achieved using real(8,2,<value>)
Don't you mean- "if you're not misshaken?"
(Bad puns courtesy of Excelseo (c)2015)
I'm a little shaken up by your pun there.
I've uploaded Solius to the Cemetech Archives, so once it's in I'll put the download in the OP.
Unicorn wrote:
Coolio! Sorry I couldn't really test it, things happened.
No problem, you tested as much as I needed.
I've added a color toggle per request of DJ_O. You can play in black and white or full color! I've also tweaked a few things. The update has been submitted to the Archives.
» Goto page Previous 1, 2
Page 2 of 2
