Does anyone with a TI-84+CE and a TI-84+CSE have a ruler and/or a scale handy? A comparison of the dimensions and weight with (and without) the slidecase would be greatly appreciated.
Weights in grams.
With slide case:
82 - 246
84+SE - 294
84+CSE - 261
84+CE - 201
Without slide case:
82 - 208
84+SE - 252
84+CSE - 221
84+CE - 163
With slide case:
82 - 246
84+SE - 294
84+CSE - 261
84+CE - 201
Without slide case:
82 - 208
84+SE - 252
84+CSE - 221
84+CE - 163
Okay, I've updated the WikiTI page with information about the keypad controller; but I appear to be having some issues with timings or somethings similar. Keep in mind if you run the following; you will need to use the reset button:
When it runs, it correctly registers the Arrow Keys, however, if I hold a key not in the arrow group, it causes it to register occasionally in the wrong group. Any ideas?
.nolist
#include ti84pce.inc
.list
.org userMem-2
.db tExtTok,tAsm84CeCmp
di
call _HomeUp
call RestoreKeyboard
Scan:
ld a,3
ld (0F50000h),a ; Resets Controller?
ld a,(0F5001Eh) ; Arrow Keys
ld c,a
call OutHex
jr Scan
ret
RestoreKeyboard:
ld bc,0F50000h
xor a ; Mode 0
ld (bc),a ; %00000000
inc c ; 0F50001h
ld a,15 ; Wait 15 APB cycles before scanning each row
ld (bc),a
inc c ; 0F50002h
xor a ; %00000000
ld (bc),a
inc c ; 0F50003h
ld a,15 ; Wait 15 APB cycles before each scan
ld (bc),a
inc c ; 0F50004h
ld a,8 ; Number of rows to scan
ld (bc),a
inc c ; 0F50005h
ld (bc),a ; Number of columns to scan
ret
OutHex:
ld a,c
rra
rra
rra
rra
call Convert
ld a,c
Convert:
and $0F
add a,$90
daa
adc a,$40
daa
call _PutC
retWhen it runs, it correctly registers the Arrow Keys, however, if I hold a key not in the arrow group, it causes it to register occasionally in the wrong group. Any ideas?
.nolist
.list
.org userMem-2
di
call _HomeUp
Scan:
ld a,3
ld c,a
call OutHex
jr Scan
ret
RestoreKeyboard:
ld bc,0F50000h
xor a ; Mode 0
inc c ; 0F50001h
ld (bc),a
inc c ; 0F50002h
xor a ; %00000000
ld (bc),a
inc c ; 0F50003h
ld (bc),a
inc c ; 0F50004h
ld (bc),a
inc c ; 0F50005h
ret
OutHex:
ld a,c
rra
rra
rra
rra
call Convert
ld a,c
Convert:
and $0F
add a,$90
daa
adc a,$40
daa
call _PutC
I believe this might be happening because _PutC can reenable interrupts (specifically when the screen scrolls). I don't get the problem happening until that point with my own program that prints only when the value changes.
Edit: I actually have a good explanation for this. TI leaves the keypad in different modes depending on the current state of the keypad. Here's basically what they do:
Set mode 1
Check if any keys are pressed using interrupt bit 2
If no keys are pressed, return
Set mode 3
Wait until the scan finishes using interrupt bit 0
Set mode 0
Check keypad data, returnThe problem this causes is that the keypad is left in mode 1 if no keys are pressed. That means the data registers are in an undefined state (I personally think that all rows are enabled and thus they read the OR of all keys in the column). So, if no keys are pressed, you end up with phantom keypresses if you read a data register after a key is pressed and before the next actual scan occurs.
Just to interject for a second, should we start coming up with some universally-recognized names for these memory-mapped port equates? I feel like that would simplify some of these discussions, and I'm a staunch hater of magic numbers in code. π
Ok so I managed to get some parser stuff running and made a small tilemap demo:
The entire map is redrawn each frame and the scrolling is 8-pixels at a time. The code an be optimised for more speed as well.
Very encouraging when compared to the CSE!
merthsoft wrote:
What resolution and color mode is this running at?
Looks to me like it is running in 8bpp mode. π
Anywho, looks like rst 20h is no longer _Mov9toOP1, so just use the call instead for now.
This may be pretty important, but it seems like register B no longer holds the archive status of a variable in the same way when using _ChkFindSym. Going to try and figure it out... π
EDIT: In addition, the accumulator no longer holds information about the variable.
Courtesey of Calc84 wrote:
The new call is "_ChkInRAM equ 021F98h", which returns Z if RAM, NZ if in ARCHIVE.
I just want to update that I've documented some more hardware.
The 6000 port range, which we thought was a general-purpose timer, is actually a watchdog timer. Not as useful as we were hoping, though it is good for resetting the calculator and/or triggering NMIs! (Or it can be used as a timer without triggering interrupts, I suppose.)
Thankfully, the 7000 range actually contains not one, but three general-purpose timers! These can be used to generate interrupts, and are a good bit more flexible than the timers we had previously.
Sure; what do you think of this list for keyboard equates:
kbdMODE equ 00h
kbdCNTRL equ 04h
kbdINT equ 08h
kbdINTMASK equ 0Ch
kbdG1 equ 0F50012h
kbdGRAPH equ 00000001b
kbdTRACE equ 00000010b
kbdZOOM equ 00000100b
kbdWINDOW equ 00001000b
kbdYEQU equ 00010000b
kbd2ND equ 00100000b
kbdMODE equ 01000000b
kbdDEL equ 10000000b
kbitGRAPH equ 00h
kbitTRACE equ 01h
kbitZOOM equ 02h
kbitWINDOW equ 03h
kbitYEQU equ 04h
kbit2ND equ 05h
kbitMODE equ 06h
kbitDEL equ 07h
kbdG2 equ 0F50014h
kbdSTO equ 00000010b
kbdLN equ 00000100b
kbdLOG equ 00001000b
kbdXSQURE equ 00010000b
kbdXINV equ 00100000b
kbdMATH equ 01000000b
kbdALPHA equ 10000000b
kbitSTO equ 01h
kbitLN equ 02h
kbitLOG equ 03h
kbitXSQURE equ 04h
kbitXINV equ 05h
kbitMATH equ 06h
kbitALPHA equ 07h
kbdG3 equ 0F50016h
kbd0 equ 00000001b
kbd1 equ 00000010b
kbd4 equ 00000100b
kbd7 equ 00001000b
kbdCOMMA equ 00010000b
kbdSIN equ 00100000b
kbdAPPS equ 01000000b
kbdXTON equ 10000000b
kbit0 equ 00h
kbit1 equ 01h
kbit4 equ 02h
kbit7 equ 03h
kbitCOMMA equ 04h
kbitSIN equ 05h
kbitAPPS equ 06h
kbitXTON equ 07h
kbdG4 equ 0F50018h
kbdDECIMAL equ 00000001b
kbd2 equ 00000010b
kbd5 equ 00000100b
kbd8 equ 00001000b
kbdOPENPAR equ 00010000b
kbdCOS equ 00100000b
kbdPGRM equ 01000000b
kbdSTAT equ 10000000b
kbitDECIMAL equ 00h
kbit2 equ 01h
kbit5 equ 02h
kbit8 equ 03h
kbitOPENPAR equ 04h
kbitCOS equ 05h
kbitPGRM equ 06h
kbitSTAT equ 07h
kbdG5 equ 0F5001Ah
kbdNEG equ 00000001b
kbd3 equ 00000010b
kbd6 equ 00000100b
kbd9 equ 00001000b
kbdCLOSEPAR equ 00010000b
kbdTAN equ 00100000b
kbdVARS equ 01000000b
kbitNEG equ 00h
kbit3 equ 01h
kbit6 equ 02h
kbit9 equ 03h
kbitCLOSEPAR equ 04h
kbitTAN equ 05h
kbitVARS equ 06h
kbdG6 equ 0F5001Ch
kbdENTER equ 00000001b
kbdPLUS equ 00000010b
kbdSUB equ 00000100b
kbdMULT equ 00001000b
kbdDIV equ 00010000b
kbdPOW equ 00100000b
kbdCLEAR equ 01000000b
kbitENTER equ 00h
kbitPLUS equ 01h
kbitSUB equ 02h
kbitMULT equ 03h
kbitDIV equ 04h
kbitPOW equ 05h
kbitCLEAR equ 06h
kbdG7 equ 0F5001Eh
kbdDOWN equ 00000001b
kbdLEFT equ 00000010b
kbdRIGHT equ 00000100b
kbdUP equ 00001000b
kbitDOWN equ 00h
kbitLEFT equ 01h
kbitRIGHT equ 02h
kbitUP equ 03hAlso, great find calc84! This is even more fantastic news; now interrupts can be even cooler! π
How do you figure all of this stuff out? I'd have no idea how to go about documenting the timers, for example.
Also, what is the purpose of the watchdog timer? I looked it up on Wikipedia and it appears they're used to keep a computer from permanently freezing by rebooting it if the timer doesn't get reset before reaching zero, but i can't really imagine what the use of something like that would be here, especially with a reset button available.
tr1p1ea: the tilemapping demo definitely looks promising.
The use would be the same here -- imagine the interrupt resetting that timer, but if you run an assembly program that disables interrupts and locks up, the watchdog timer can reset for you. That would be useful in situations where you can't press the RESET button (don't have anything that can press it, controlling it remotely, etc.).
Those keyboard equates don't follow convention. In code, the key names are not all capitalized, e.g. skMode and kMode.
The watchdog timer could be used to prevent us from running programs with interrupts disabled, by forcing an NMI at regular intervals. If the port range were protected, it would be extremely annoying.
calc84 IDed the watchdog timer, I think by just concluding that it was probably a watchdog timer, and then Googling for watchdog timer IP cores. He then noticed a resemblance to a general purpose timer from the same company, and an RTC. Then I checked if they had USB IP cores, and USB 2.0 OTG one matched. calc84 also found an interrupt controller.
Incidentally, the B0xx range (LCD backlight) looks similar to a port range on the Nspire. On the Nspire, there's also a 1-wire interface in that port range (used with the battery controller?). It looks like it might be there, but slightly different, and the OS never uses it.
We also may have found the testing LED, which also looks similar to the Nspire's. It seems to be write-protected, and yet memory mapped, so I'm totally confused about why IN and OUT are forbidden, and why the 00xx range doesn't appear to be memory mapped, if they still have a regular protected port system that could have protected the security registers without all this port access craziness.
Incidentally, the OS doesn't use memory-mapped I/O. It's weird, because it would get a slight speed boost from using it by not requiring all those double-checks on writes. (And the unmapped 00xx range can just use out0.) And of course, not needing those checks would make the code easier to write.
Actually, the way I found the watchdog timer was by Googling its default counter value (0x03EF1480) and a comment in a U-Boot driver showed up. It was quite a happy coincidence.
It certainly implies that the memory-mapped I/O is not intentional. Even if it was, they've screwed up the security on this thing pretty badly.
I've written up the results of some tests involving wait states. This is very useful to know for emulation or generally for optimization.
One very interesting thing is that the LCD controller has fewer wait states on read than RAM does, so its 1KB of cursor graphics memory could be quite useful for running critical code...
I believe the memory-mapped I/O is intentional.
Did you fix it and update Mateo's work? π
That sounds really exciting for a shell-type program. The author of Doors CSE is keeping his ears open. π
Do you have the name of the company, and the models of each of those IP components, so I can update our TI-84 Plus CE Information page? I probably should just look on WikiTI. π BrandonW wrote:
It's pretty hard to imagine an engineer doing that by accident. I think it's just the result of multiple parties writing requirements.
That sounds really exciting for a shell-type program. The author of Doors CSE is keeping his ears open. ;)
I probably should just look on WikiTI. ;)
Yes, you should. KermMartian wrote:
Did you fix it and update Mateo's work? πFixed and updated. π Case isn't parsed with equates; but there were a couple that were named incorrectly. Oh wells.
merthsoft wrote:
Weights in grams.
With slide case:
82 - 246
84+SE - 294
84+CSE - 261
84+CE - 201
Without slide case:
82 - 208
84+SE - 252
84+CSE - 221
84+CE - 163
Thank you so much for finding these! Would one of you mind updating our Tools pages with that information? I'll do it if no one else gets to it. With slide case:
82 - 246
84+SE - 294
84+CSE - 261
84+CE - 201
Without slide case:
82 - 208
84+SE - 252
84+CSE - 221
84+CE - 163
» Goto page Previous 1, 2, 3, 4, 5, 6, 7 Next
Page 2 of 7
