Gentlefox wrote:
The first time I tried to put the case on to protect the screen, I accidentally put the wrong end in. There are notches on both the case and the top of the calculator, so I figured that was an indication to line them up. Nothing really blocks you from doing this, so with only a slightly heavy amount of force I got it in before realizing it was on wrong.
I have to say that I and someone else both tried to do this with my TI-84 Plus CE, and neither of us could get it past the first notch without extreme force indeed; I don't think a lot of people would do it by accident.
Gentlefox wrote:
At that point it took a massive amount of effort to get the thing back out, which put (hopefully removable) scratches all over the face of my calc. Obviously I should have tried it the other way when I encountered an above average amount of resistance, but I find the thing horribly unintuitive from a design perspective.
Again, I found this a lot more intuitive than you. On the TI-84 Plus, TI-84 Plus Silver Edition, and TI-84 Plus C Silver Edition, the case is shaped similarly, with a closed end at the bottom and an open end at the top. For each model, you slide the case onto the bottom up. Getting the case on incorrectly felt extremely difficult, and holding the ridged parts in my fingers (at opposite ends of the calculator and case) also felt intuitive. With the TI-83 family cases, it was indeed easy to put the case on the wrong way, but starting with the TI-84 Plus, I don't think that's a very common mistake. Out of curiosity, what exactly scratched the face of your calculator? I couldn't find anything on the inside of the slidecase that would scratch the face of the calculator.
Gentlefox wrote:
So basically every time pressure is applied to the top of the case, it will bend and the plastic ridges will smack against your screen. To be fair, they press against the black part of the screen that doesn't have pixels, but it's still against the casing of the screen. What's the point of these?
I think it's so that if you press on the back of the case, it will bend inwards while applying pressure beyond the sides of the screen, instead of pressing directly on the LCD and potentially damaging or cracking it.
Gentlefox wrote:
As for the face of the calculator, I'm very disappointed. I have never seen a material that moreso emphasizes fingerprints, scratches, lint, etc. than this one. I have the black faceplate, and I'm not sure if that makes it better or worse, but it's incredibly on such an otherwise nice looking calculator.
I have the Radical Red one, but the glossy black plastic that surrounds the screen is absolutely a fingerprint magnet; I have repeatedly had to clean it, but I suppose that's the case with many modern electronics with glossy plastic.
