Well, I have been looking around and it seems as though Puzzle Frenzy has yet to be ported to the CSE calculators. I have never tried to write an assembly program for the CSE, but I feel that this would be a fun project to work on. Any ideas and help would be much appreciated!
Download:
Puzzle Frenzy
Latest Screenshot:
Awesome idea! You are also in the right place should you need any help with coding along the way
Well, work is coming along quite nicely now that I took a look at this link:
http://en.wikipedia.org/wiki/Binary-coded_decimal
Wow. What a great method to store both color and data into a single byte.
Here's a screenshot of the current progress -- all it is is a little menu that doesn't do anything.
This looks pretty nice so far. I liked that game a lot so it's nice to see it ported to the color 84+ model. So far there are only 84+ and Nspire versions.
That looks great so far! Are you using z80 ASM or hybrid BASIC, as that looks like it could have been created by either one? If ASM, are you using the DCSE routines to display that and the DCSE header to set half-resolution mode, or am I getting carried away with myself?
Thanks! (It will hopefully look better once I get more accustomed to the C edition) This is just z80, and for now I am just using pure z80 in order to get a grasp of the differences in the LCD.
Does anyone have any great ideas on how to check if the surrounding blocks matched? I was thinking along the lines of a table, which is set up some thing like this:
Table:
Line One Data
Line Two Data
Line Three Data
and then shift each one over after the new one appears. That way it won't have to become to complicated... Are there any other ways?
Just googled it, so is it like a candy crush type of game? One where you move pieces around to match pairs?
APotato: Kind of. Yeah.
Mateo: Awesome work! I saw this earlier and decided it had been a while since I've played it, so guess what I did in math? And by table, is that the same as an array?
Table:
Line One Data
Line Two Data
Line Three Data
Yes, you essentially want an array of items, with a value representing each block. If the array starts at memory address M, then if each item is one byte, the item at row Y, column X would be at M+(Y*row_length)+X. You can than scan (from the current item in the array) +1 and -1 position for the items on each side, and +(row_length) and -(row_length) for the items above and below. Does that makes sense?
Of course! The table is probably going to be the easiest; can't wait to get to the tile clearing routine.
Well, here's a screen shot of the latest progress; it is shifting at 1 pixel each iteration, so it is going to be fast enough for what I have in mind. Don't worry about the flicker, that is just it being updated super fast.
Original:
Wow looking great! And yay, I love puzzles
Okay, quick question for anyone who can do this the fastest...
So, take this data:
Code: .db 2,3,4,5,6,1,1,1,1,1
And shift it into this!
Code: .db 1,2,3,4,5,6,1,1,1,1
You can chop off the last digit in the first one, and place a one in the front of the second. Thanks!
EDIT:
I think this is the fastest: (Thanks Kerm!)
Code: ld hl,Table + 8
ld e,l
ld d,h
inc de
ld bc,9
lddr
ld (hl),1
Faster and smaller: exploiting the little-used lddr:
ld e,l
ld d,h
inc de
ld bc,9
lddr
ld (hl),1
Oh, of course! Thank you -- totally blanked on that.
EDIT:
Well, here's another update of the progress -- Right now it is moving at exactly 1/16 of its fastest speed, and can only check if it should move empty blocks back. Once I figure out a good method to horizontally clip packed sprites, the blocks will slide in rather than jump in.
This is looking great! Are you using the DCSE sprite routines, out of curiosity? Regardless, keep up the excellent work.
Unfortunately, no. This is because I am considering making it an app because storing 60 levels might take some room.
Update: Now all block clearing routines are written, along with the score. I will probably change the layout to make it look fancier , but for now it is purely in the testing phase.
Edit: Considering how I set up the colors, it might be possible to allow the user to change the colors of blocks...
Hmm kind of reminds me of Dino puzzle. Does puzzle mode work yet?
Yes and no. Since it is basically the same thing, just without movement, puzzle mode is not too far off. Have you tried the original to compare it with?
No, I haven't been able to persuade my sister to let me borrow her calc. But I don't need to see it to know that this version is looking way better already!
Don't compile the 60 levels in. Load them externally.
