BASIC Code wrote:
:ClrDraw
:1
W:14
A:1
B:1
C:3
D
:Text(14,35,"1-PLAYER
:Text(26,35,"2-PLAYER
:Text(38,35,"DIFFICULTY
:Text(50,35,"HIGH SCORES
:Text(56,35,"QUIT
:While W=1
:If B=1:Text(20,41,"4-WAY
:If B=2:Text(20,41,"8-WAY
:If C=1:Text(32,41,"JOINT
:If C=2:Text(32,41,"4-WAY
:If D=1:Text(44,50,"
:If D=2:Text(44,48,"
:If D=3:Text(44,45,"
:If D=4:Text(44,43,"
:If D=5:Text(44,41,"
:Text(A,30,"
:getKey
K
:If K:Text(A,30,"
:A-(((6(K=25)(A>14))+(6(K=25)(A>50))-((6(K=34)(A
50))+(6(K=34)(A<56)))
A
Generated by
SourceCoder, © 2005
Cemetech
It has to jump by twelve for the first 3 options, then by 6 for the other two... I know the code for up doesn't work yet, and the code for down causes a domain error, because it keeps jumping by 12...
you didn't post the rest of the loop so I cant see when W,A,B,C, or D change.
So far it just has an End at the end of the program, right after the algorithim. Nothing else is being dealt with yet.
well, it makes it confusing to have all them If statements relating to varaibles that never change....
Well, I plan on integrating left and right key presses when the cursor is on that line, to change the options. It won't do any good if the cursor movement doesn't work... That is why I haven't even worked on it...
Oh that's why it doesn't do anything.
It is jumping by 12 all the time, instead of the times it should be jumping by 6! The rest of the stuff has no bearing on why that problem exists. The cursor needs to be able to go up and down before you can select stuff...
the cursor never displays itself for one thing.
Is the While loop supposed to be devoid of an end? And can you please be more detailed. Just saying it should move by 6 or 12 at certain locations leaves a lot to the imagination.
Hmm, It didn't post it... It does, at Text(A,30,"
It is the filled in version of >...
Filled in version? Where do you find it?
i'm not getting any domain errors, nor cursor movement at all
you mean the Frac>Dec type arrow?
let me actually read the getkey part now 😁
:Text(56,35,"QUIT
Those are the lines that it needs to move about on.
I'm not getting any domain errors, nor cursor movement at all
That is odd, cause the cursor is moving on my calc right now... and I have not done anything with the code
Source coder has a problem with removing the last command, remember?
Yes I see what you are trying to do now. Just to make sure, you need it to move on specified lines, and you need it to print specified text if user presses left or right?
Code: A-(((6(K=25)(A>14))+(6(K=25)(A>50))-((6(K=34)(A50))+(6(K=34)(A<56)))A
is missing a parentheses - adding one after (6(k=25)(a>50)) gave me cursor movement w/ the domain error
Ok, then you are seeing what I am then... I am hoping that by posting it here a fresh mind might see the error...
And the selections will be similar to the movement code, but will be less complex...
you have to stop it from going off the screen and causing a domain error.
[edit]
nvm, just realised how you were doing that.
I'll see what I can conjure up. I'll be right back.
[edit]
Yes, I am trying to restrict it, but it doesn't seem to work... I wonder if Weregoose is on... 😄 I would bet money he could solve the problem in 5 minutes or less... 😄
