- FORTH on the ti83+/ti84+/ti84+CSE
- 28 Oct 2014 07:47:21 pm
- Last edited by Unknownloner on 31 Oct 2014 08:16:38 pm; edited 1 time in total
I switched efforts for now from a C compiler to a much simpler FORTH compiler, and to test it out I made Snake (How original of me right?)
Anyways, here's a screenshot
Currently it (the compiler) isn't in a state that's really useable to people other than me, but I hope to be fixing that in the next 1-2 weeks by breaking it out into its own project, cleaning up the repo, adding documentation, making it controllable with command line arguments, maybe making some pre-compiled binaries.
I'm also planning to add more optimizations to it.
However in the mean time if you think you can get it to work on your own, head on over to https://github.com/unknownloner/calccomp/
run ./compile.sh to compile the code, and run ./calccomp to compile "SNAKE.forth" to "FSNAKE.8xp", edit Main.hs to change the input/output files.
Also here's the code. You may notice I changed the way word definitions are done from standard FORTH, as well I have 'RECURSE' which jumps to the top of the word, or to the 'RECURSEPOINT' in the word if it exists, but I don't have any other form of looping right now.
In understanding the ASM words, know that the only thing on the stack when they run is the program data, no return addresses.
And if you just want to test the program, download from
http://z80.unknownloner.com/FSNAKE.8xp
No DoorsCSE required.
( VX and VY are velocity )
VAR VX
VAR VY
VAR HEADX
VAR HEADY
VAR HEAD_OFF
VAR TAIL_OFF
VAR BSIZE
1 CPU_SPEED (15mhz)
0 0 0x0000 320 240 FILLRECT
0 0 0xFFFF 228 228 FILLRECT
RUNGAME
0 CPU_SPEED (6mhz)
( Runs the game loop multiple times, return val determines if it runs again )
WORD RUNGAME {
( Initialize variables )
4 HEADX ! 0 HEADY !
1 VX ! 0 VY !
4 HEAD_OFF ! 0 TAIL_OFF !
5 BSIZE !
2 2 0x0000 224 224 FILLRECT
CLEARBOARD
5 INITSNAKE
GENFOOD
GAMELOOP IF
RECURSE
THEN
( Actual loop for in the game )
( Return TRUE if game should restart, FALSE if it should exit )
WORD GAMELOOP {
(Remember, TRUE = -1, FALSE = 0)
GETCSC
DUP 15 = IF
DROP
FALSE RETURN
THEN
DUP 1- 4 U< IF (If key code is from 1-4...)
DUP DUP DUP (STACK: KEY KEY KEY KEY)
(Y axis)
4 = SWAP 1 = - (-1 if key up, 1 if key down, 0 if both) (STACK: KEY KEY VELY)
DUP VY @ AND 0= IF (Same as VX for VY)
VY !
ELSE DROP THEN
(X Axis)
2 = SWAP 3 = - (-1 if key left, 1 if key right, 0 if both) (STACK: VELX)
DUP VX @ AND 0= IF (If VX & NEWVX == 0, set VX to NEWVX, else DROP it)
VX !
ELSE DROP THEN
ELSE DROP THEN
(Increment head offset)
HEAD_OFF @ 1+ 1023 AND
HEAD_OFF !
(Move head)
HEADX @ VX @ + 31 AND
DUP HEADX !
HEAD_OFF @ BODY_X + c!
HEADY @ VY @ + 31 AND
DUP HEADY !
HEAD_OFF @ BODY_Y + c!
(Food/collision test)
HEADX @ HEADY @
CELLADDR c@ (Tile at new head loc)
DUP 1 = IF
DROP
TRUE RETURN (Restart game)
THEN
2 = IF
GENFOOD
ELSE
(Erase/move tail)
TAIL_OFF @ DUP DUP
BODY_X + c@ SWAP
BODY_Y + c@
2DUP 0 SETCELL
0x0000 FILLCELL
1+ 1023 AND
TAIL_OFF !
THEN
(Draw head)
HEADX @ HEADY @
2DUP 1 SETCELL
0x07E0 FILLCELL
245 SLEEP
RECURSE
Initializes the snake on LCD/board
Input: Length
WORD INITSNAKE {
1-
DUP DUP BODY_X + c! (Set X position in body data)
DUP BODY_Y + 0 SWAP c! (Set Y position in body data)
DUP 0 0x07E0 FILLCELL
DUP 0 1 SETCELL
DUP 0!= IF
RECURSE
THEN
DROP
(Generates a new food tile)
WORD GENFOOD {
RAND RAND (X and Y)
2DUP CELLADDR c@ IF
2DROP
RECURSE (Jump back to start until we find a blank tile)
THEN
(2DUP FOODY ! FOODX ! (Save food position))
2DUP 2 SETCELL (Set food position on board)
0xF800 FILLCELL (Draw food)
( Input: X Y TYPE )
WORD SETCELL {
-ROT CELLADDR c!
( Gets cell addr for cell X Y )
WORD CELLADDR {
32 * + ( Y * 32 + x)
BOARD + ( Add board address )
( Fills board with zeroes )
( Input: Addr Val Amount )
WORD CLEARBOARD {
BOARD >R (addr on R stack)
1024 (Amount of bytes to fill)
RECURSEPOINT
2- (We fill 2 at a time)
DUP R@ + 0 SWAP !
?DUP IF (If offset > 0, recurse)
RECURSE
THEN
R> DROP (Drop BOARD)
( Fills a board cell )
( Input: X Y COLOR )
WORD FILLCELL {
ROT
7 * 2+ (X = X * 7 + 2)
ROT
7 * 2+ (Y = Y * 7 + 2)
ROT 7 7 (Stack: X Y COLOR 7 7)
FILLRECT
( INPUT: X Y COLOR WIDTH HEIGHT )
WORD FILLRECT {
ROT >R (Color on R stack)
2SWAP (STACK: WIDTH HEIGHT X Y)
DUP DUP (W H X Y Y Y)
0x50 SETLCD (Win top)
0x20 SETLCD (Cursor y)
2 PICK + 1- 0x51 SETLCD (Win bottom, STACK: WIDTH HEIGHT X)
DUP DUP (W H X X X)
0x52 SETLCD (Win left)
0x21 SETLCD (Cursor x)
2 PICK + 1- 0x53 SETLCD (Win right, STACK: WIDTH HEIGHT)
R> (Color off R stack)
PIXELFILL
ASMWORD BODY_X {
.var 1024, snakeBodyX
ld hl,snakeBodyX
push hl
ASMWORD BODY_Y {
.var 1024, snakeBodyY
ld hl,snakeBodyY
push hl
ASMWORD BOARD {
.var 1024, board
ld hl, board
push hl
ASMWORD CPU_SPEED {
pop hl
ld a,l
out (20h),a
ASMWORD SLEEP {
pop hl
WasteTime:
djnz WasteTime
dec hl
ld a,h
or l
jr nz,WasteTime
ASMWORD GETCSC {
b_call(_GetCSC)
ld h,0
ld l,a
push hl
( Generate a random number from 0 - 31 )
ASMWORD RAND {
.var 2, randData
ld hl,(randData)
ld a,r
ld d,a
ld e,(hl)
add hl,de
add a,l
xor h
and 31
ld (randData),hl
ld h,0
ld l,a
push hl
( Sets an LCD register )
( INPUT: VAL REG )
ASMWORD SETLCD {
pop hl
ld a,l
out (10h),a
out (10h),a
pop hl
ld a,h
out (11h),a
ld a,l
out (11h),a
( Fills WIDTH * HEIGHT pixels with COLOR )
( INPUT: WIDTH HEIGHT COLOR )
ASMWORD PIXELFILL {
pop de ;Color
pop bc ;C = height
pop hl ;HL = width
ld a,22h
out (10h),a
out (10h),a
ld b,c ;height
ld c,11h ;Output reg
_pixelFillLpX:
push bc ;Save height
_pixelFillLpY:
out (c),d
out (c),e
djnz _pixelFillLpY
pop bc
dec hl
ld a,h
or l
jr nz, _pixelFillLpX
