well i am having a problem with my ms-dos again the error is as follows
C:\WINDOWS\_DEFAULT.PIF
Invalid program name, please check your pif file. Choose 'close' to terminate the application.
*note this happens when i go into local disk then windows then click on ms-dos shortcut.
Try using "Command Prompt" from the accessories in the start menu.
Or start-->run, then type cmd and press enter. That usually works.
it worked thanks
