I have a TI-84 Plus Silver Edition that I'm trying to get the ROM off of with TILP. I had TI Connect on my computer, so I downloaded TILP and the filter driver installer. I ran the installer and downloaded the filter driver for the "TI Educational Handheld Device," which I assumed was my calculator. I then installed TILP.
I started TILP, and in the command prompt that popped up, I got the messages:
"ticables-WARNING **: no devices found!
tilp-WARNING**: Attempting to communicate with calculator"none"!
libglade-WARNING **: unknown property "orientation" for class 'GtkUbox' (this one appears three times)"
I went to file, change device, and changed my cable from Null to DirectLink (I'm using the black cable that came with my calculator, which I bought in store), and my Calc to TI84+. I left my port at #1, my timeout at 15, and my delay at 10. I also checked the USB scan at startup box.
Sometimes, when I click "Ready" nothing happens. I am able to use the Dirlist function.
Other times, whenever I click "Ready" in TILP, I get the error message:
"Msg: faled to open the USB device.
Cause: Check that the USB cable is plugged in and that the calculator is turned ON! Also, check libusb and usbfs for valid permissions.
System: (1854698580) The I/O operation has been aborted because of either a thread exit or an application request."
I then hit "close," then this pops up:
"The cable cannot be used. Cause: the cable has not been initialized due to a previous/current error."
The calculator is on and plugged in when I try this, and the Dump ROM option under Tools has been grayed out the entire time. Any help is appreciated!
