SOOOO...
i have a ti-30xIIS scientific calc at home and was bored
so i looked inside of it after dismantling it
i noticed how it was connected to a battery and thought what a waste of battery if this thing is solar powered
so i now removed the battery i would have had to replace and now mah scientific calc is SOLER POWERED AND ENERGY EFFICIENT
tell me is this is new or if you have heard of and done this before
The battery is there so that you can keep using it when you don't have enough light to power it.
You're an idiot.
not really it is really sunny where i am and also i has a light in ma room that somehow duplicates sunlight or summthing so i really am NOT an ididot
i am just tryin to say that this si a way to get a free battery and still have a workin calc
and scince the light as my main light my calc will only NOT work when i am in my room at night with all lights off
i feel so great
If you are taking over the world and your doom laser needs a battery, and you positively cannot find one for the life of you then maybe, but even then...
...well, it wouldn't be advisable.
It presumably also allows the memory function to work too.
meh i feel this is the way because i am an environment freak
also i think the mem function is annoying cause i never use it
also please do not spill my plan of world domination cause you will be first if you do
This thread is more awesome than the abortion thread. Because op is prime evidence for the pro-choice case.
also tell me weather you would do this now that i has enlightened you
one momre thing it would only work in daytime or if you put it near a light at night time so yeah it is kinda disabled at night but hey
so tell me if you have heard of anyone doin this too
ALSO after some experimenting in this envir-mode i found oout that cutting battery supply has no effect whatsoever on how the calc works except that well it turns offf at night
anotherthing is that if one wire iS connected and if you connect it completely and the other is connected to a different part of the circut board, not where it is supposed to, a bright LED light goes on and that light is BRIGHT
The above is.. I am not even going there. <<;
No, I am enlightened to stick with my ever so amazing TI graphing calculator collection with RECHARGEABLE BATTERIES.
This thread is not overly helpful or productive to the internet. Commence lock down of silly topic?
I suppose it could be helpful, but it is presented poorly. Perhaps edit it to decent english and not ALL CAPS?
Can't we just ban the underage member?
Can we just ban the underage member AND lock the topic already? Waste of database space 😛
I do hope you are joking.
No, only an idiot would do this. Why do you think removing the battery is somehow an "envir-mode"? Because it hasn't done jack shit to help the environment in any way.
If you think it's done something for the environment by removing the battery, you've simply either prematurely turned the battery into waste, or put it to another use. Both of which have done nothing at all to help the environment.
You know, they make Graphing Calculator that are already just solar powered.
There's no need to lock the topic, or troll the newbie, although his spelling is a bit appalling. Solar powered calculators are an interesting topic, and someone could at least explain to him short-term/long-term power requirements.
well sorry to seem like an idiot i just thought what would happen if i opened it up and when i saw the battery i thought "geez what a waste of battery i can use this to power my watch or my pokewalker or something"
plus i have 2 scientific calcs AND i never use them
i thought i was on to something......
HEY!!! I'm 13 i believe i meet the minimum age requirement
😠 ah well never mind i guess it was kinda a silly idea.. but you need not to be so hurtful â˜šī¸
back to the serious matters of Graphing Calculator
Offtopic video converted to link ~elf
Offtopic link converted to video ~ultdev
Hey, I think what he did isn't half bad, considering his age. Sure it helped the environment a total of NONE, but it's a step in the right direction! Good job, but shouldn't your calc have the battery AND the solar panel so it will work anywhere?
Page 1 of 2
