This code does not work. Here is a better better explanation of the problem.I have two lists
{3 4 9 10}→⌊JONL1
and
{3 4 7}→⌊JONL5
I want to create a third variable
{3 4 7 9 10}→⌊OVER
That combine the two lists and remove the duplicates. I was surprised to find that the code below does not work
augment(⌊JONL1,⌊JONL5→⌊OVER
john massey wrote:
To augment something, you make it greater. This would (probably) work if both lists had the same number of elements, except elements one of ⌊JONL1 &⌊JONL5 would be added together to form element one of ⌊OVER, and same for every other element.
Page 2 of 2
