how about we have'mover' and a 'trigger'. bricks can hold mutiple movers and/or triggers and the movers hold the moving data. then make those switich bricks that tbm used for switches be in the inventory for placing.
Ultimate Dev'r wrote:
DShiznit wrote:
If I understand correctly, that's called "Maturity".
Or "Deceit"
Now to add some relevance so my post doesn't get baleeted again: I think it would be great if you could set 2 or more bricks to move/rotate to differend directions in one switch instead of using many switches.
So basically switch chaining. The code for that shouldn't be too hard. The UI might be a pain in the butt, but we'll figure it out
did I not just suggest a waypoint system?
