My father and I were writing programs to find numbers that are equal to the sum of the factorial of the digits. For example, 145 = 1! + 4! + 5!. We wrote three programs one in Python, one in Java and one in C++. The ones in Java and C++ ran in about 7.3 seconds while the one in Python ran in about 7 minutes. I was wondering why this is. I've posted the Python and C++ code, I will post the Java code if you desire.
("... " = tab)
# build a table of factorials 0! through 9!
lastfact = 1
fact = [1]
for k in range(1,10):
... lastfact *= k
... fact.append(lastfact)
# function to calculate the sum of the factorials of the digits
def factsum(n):
... if n==0:
... ... return 1
... ans = 0
... while n>0:
... ... u = n % 10
... ... ans += fact[u]
... ... n -= u
... ... n /= 10
... return ans
# check the numbers up to 100 million
for k in xrange(100*1000*1000):
... if k == factsum(k):
... ... print k
#include <iostream>
using namespace std;
/// Stopping point of our search
const long LAST = 100*1000*1000
/// Table of factorials
void init_ftable() {
... ftable = new long[10]
... ftable[0] = 1
... for(int k=1; k<=9; ++k) {
... ... ftable[k] = ftable[k-1] * k;
/// Compute sum of factorials of the digits
long fsum(long n) {
... if (n==0) return 1;
... long ans = 0;
... while (n>0) {
... ... int u = n % 10;
... ... ans += ftable[u];
... ... n -= u;
... ... n /= 10;
... return ans;
int main() {
... init_ftable();
... for(int n=1; n<=LAST; ++n) {
... ... if (fsum(n) == n) {
... ... ... cout << n << endl;
So far the numbers we have come up with are: 1, 2, 145, and 40585.
This is how the code looks on my calculator, it might not be optimal but it is 1:30 in the night.
It goes up to 1000 in 8 minutes, so I only found 1,2 and 145
For(X,1,E10
If X=sum(seq(int(10fPart(X10^(Z)))!,Z,-int(log(X))-1,-1
Pause X
For(X,1,E10
Pause X
I honestly have no idea how that helps the question at all >.>
Just ask Klrnohj Zaphod =P
There is no way that your C++ program ran in 7.3 seconds. My testing shows your C++ code taking about 40-60 seconds on an Athlon64 X2 @ 3ghz.
This just isn't a problem for python. What this problem needs is raw speed with no overhead, which C/C++ does beautifully.
That said, this is what I came up with in python, and is likely to be about as fast as it'll go:
import operator
try:
    import psyco
    psyco.full()
except:
    pass
def fact(x):
    return reduce(operator.mul, xrange(2, x+1), 1)
def findFSums(count):
    flist = []
    for i in xrange(10):
        flist += [fact(i),]
    for i in xrange(count):
        if i == reduce(lambda x,y: x+flist[int(y)], str(i), 0):
            print 'Found:', i
    return fsums
findFSums(100*1000*1000)
We ran the C++ with optimizations, did you do that? Otherwise I'm not sure because it definitely ran that fast. Unless of course I have a really distorted sense of time and my terminal lied to me.
Anyhoo, thanks for the python code! Although we'll probably just stick to C++/Java seeing as they are generally faster (at least in this case). Although I'm gonna ask my brother (a math major) see if he can prove that those are the only four. (My dad's a mathematician but doesn't feel like doing it. Razz ).
Isn't there a math.factorial operator or something, too..?
At any rate, this was awesome, in that it turned me on to psyco. *bookmarks*
It was compiled with Visual C++ 2008 with debugging symbols, but not in debugging mode. I highly doubt that optimizations would drop it to 7.3 seconds, but perhaps.
My pleasure, it was a fun problem to try and optimize. Stick to C/C++ for things like this, its much faster (hell, the JVM/JIT can take up to 15 seconds to start :/ ). Personally I think Java is terrible - try C# (either .NET or Mono, both are very solid)
There might be, but it doesn't matter since the factorial's are cached and looked up in an array. I also considered doing a dict lookup (which eliminates the int() conversion), but I didn't feel like doing a speed test of list+int vs. dict Very Happy
I honestly have nothing better to do right now, and I am interested in parallized python, so I paralized Kllr's code because I can =P
It basically scales linearly. It uses Parallel Python (which I discovered basically runs multiple instances and just communicates between them, so you could run this on a beowulf cluster if you wanted to Very Happy ) I just chop the work into however many cpu you have (so for 100 million, cpu 1 gets the first 50 and cpu 2 gets the second)
I took out Psyco because it does not really yield any speed improvements at all for this.
Change TTILL = ----- to whatever you want, I just have it at a lower number so I can test it
import time
import operator
import pp
print js.get_ncpus(), "cpus"
ncpu = input("Number to use:")
stime = time.time()
js = pp.Server()
TTILL = 1000000
#def fact(x):
#    return reduce(operator.mul, xrange(2, x+1), 1)
def findFSums(low,high):
    flist = []
    retlist = []
        flist += [reduce(operator.mul, xrange(2, i+1), 1) ,]
    for i in xrange(low,high):
            retlist.append(i)
            print 'Found:', i
    return retlist
x =  TTILL / ncpu
cur = 0
jobs = []
for temp in xrange(ncpu):
    jobs.append(js.submit(findFSums, (cur+1,cur + x),(),("operator",)))
    cur += x
    result = jobs[temp]()
    print result
#findFSums(100*1000*1000)
print "Time: ", time.time() - stime
results in:
2 cpus
Number to use:1
Found: 1
Found: 2
Found: 145
Found: 40585
[1, 2, 145, 40585]
Time:  7.9470000267
2 cpus
Number to use:2
Found: 1
Found: 2
Found: 145
Found: 40585
[1, 2, 145, 40585]
Time:  4.67499995232
2 cpus
Number to use:2
Found: 1
Found: 2
Found: 145
Found: 40585
[1, 2, 145, 40585]
Time:  45.9029998779
2 cpus
Number to use:1
Found: 1
Found: 2
Found: 145
Found: 40585
[1, 2, 145, 40585]
Time:  86.0750000477
