If it was at the very top of the program, there wouldn't be a noticeable size difference at all, but yes, the loop would still marginally be the faster of the two methods.
OK, its been a while now, but here's a nice size optimization I came across the other day while optimizing a friends code.
Topic
I was optimizing curious onlooker's newer version of AntiNibblz (before he releases it) and I found a great optimization for size and a slight speed improvement (by slight, the only difference is that there are fewer lines to read through, thus it is faster).
The code is good for things that require something to be done every set number of loops, say 10, but it isn't in a For( loop (it still works in for loops).
:IS>(B,1+10int(B/10
:Pxl-On(RandInt(1,61),RandInt(1,92
It of course can be modified for other use, and B is the variable that is going through (the example is for every 10thTopic
Convert A to a string
It's probably not as optimized as it could be, but I feel it's quite clever.
:0->C
:While iPart(A
:C+1->C
:A/10->A
:End
:"0123456789->Str0
:" ->Str9
:If A<0
:Then
:Str9+"-->Str9
:-A->A
:End
:While fPart(A
:If not(C
:Str9+".->Str9
:10A->A
:Str9+sub(Str0,iPart(A)+1,1->Str9
:A-iPart(A->A
:C-1->C
:End
:If Str9="
:" 0->Str9
:sub(Str9,2,length(Str9)-1->Str9
Convert A to a String [optimized]
Only a few optimizations made. No longer uses Str0.
:DelVar CWhile iPart(A
:C+1->C
:.1A->A
:End
:" ->Str9
:If A<0
:Then
:Str9+"-->Str9
:-A->A
:End
:While fPart(A
:If not(C
:Str9+".->Str9
:10A->A
:Str9+sub("0123456789",iPart(A)+1,1->Str9
:A-iPart(A->A
:C-1->C
:End
:If Str9="
:" 0->Str9
--Code by Weregoose
{A,A->L2
{0,1->L1
LinReg(a+bx) Y1
Equ>String(Y1,Str1
sub(Str1,1,length(Str1)-3->Str1
--Code by Weregoose
--Code by Weregoose
Once I see that, it seems so obvious. Code:
{A,A->L2
{0,1->L1
LinReg(a+bx) Y1
Equ>String(Y1,Str1
--Code by Weregoose
O_O And that's why I prefer to work in assembly. Much easier to know
all of the commands and what ya can do with them.
Chop off first element of list
Input: Ans
Output: Ans
Input and output variables can be changed to whatever.
Input: Ans
Output: Ans
ΔList(cumSum(Ans- haveacalc
- Power User (Posts: 358)
- 06 Mar 2007 10:24:09 pm
- Last edited by haveacalc on 26 Jan 2008 12:02:02 am; edited 1 time in total
Rotate a 3x3 matrix 90°
Who wants to make Tetris?
rowSwap(Ans<superscript T thing>,1,3Who wants to make Tetris?
- rthprog
- Expert (Posts: 726)
- 12 Oct 2007 11:02:30 pm
- Last edited by rthprog on 12 Oct 2007 11:28:57 pm; edited 1 time in total
--Code by Weregoose
Once I see that, it seems so obvious.Code:
{A,A->L2
{0,1->L1
LinReg(a+bx) Y1
Equ>String(Y1,Str1
--Code by Weregoose
oops... I was thinking {0,A} & {A,0}.. sorry
What happens because it works for me.
@rthprog: What are you talking about? This part:
is algebraically equivalent to 0AX+1A = A.
{A,A->L2
{0,1->L1
Wrongo Kerm linreg(a+bx) outputs the linear equation containing the points from [xlistname] and [ylistname]using the syntax [xlistname],[ylistname],[freqlist],[equation] it uses L1 and L2 as a default so all we need it the equation(which can even be omitted if we don't want to store our results). In the case of this routine it does this. It finds the line containing the points (0,A) (1,A) which is Y1=A+0X and we remove the "=0X with the substring.
That's precisely what I said, except I didn't go into the mechanics of how it works. Suffice it to say that using the LinReg/EquToString trick, precisely A with no other characters can be put into a string.
OK the I misunderstood what you said then because It looks like you are saying that imputing {A,A and {2,3 would output 3A+2AX which is not the case.
Ah, I see where you're confused. No, that wouldn't happen at all; instead, you'd still get A.
I know that this was mentioned earlier (more like two years ago i guess)..
Mode of List1
Input data into List1 first, then run the program
Outputs mode number
It's a bit longer than the previous posted one, but if in speed, this one would be much faster (by 6 seconds). If anyone out there is willing to optimize this more please do. =()
Mode of List1
Outputs mode number
0->dim(LIST2
For(Z,1,dim(LIST1
sum(LIST1=LIST1(Z->LIST2(Z
max(LIST2->A
For(Z,1,dim(LIST2
If A=LIST2(Z:Goto 0
Lbl 0:LIST1(Z
Scrambles LIST1
Input data into LIST1 before running the program
Outputs LIST1
This may still need optimizing, which is fine... But right now, i just can't think of anything...
Outputs LIST1
0->A
dim(LIST1->dim(LIST2:Ans->dim(LIST3
For(Z,1,dim(LIST1
Lbl 0
randInt(1,dim(LIST1->X
X->LIST3(Z
If X=A:Goto 0
If 1<sum(X=LIST3:Goto 0
LIST1(Z->LIST2(X
X->A
LIST2->LIST1
Pause LIST1
QuinnZhao wrote:
Scrambles LIST1
Outputs LIST1
Outputs LIST1
0->A
For(Z,1,dim(LIST1
Lbl 0
X->LIST3(Z
If X=A:Goto 0
LIST1(Z->LIST2(X
X->A
LIST2->LIST1
Pause LIST1
rand(dim(L1→L2
SortA(L2,L1
I've given up trying to sync all of my sigs at once.
Go look at my UTI Profile and make my life easier. Thnx.
» Goto page Previous 1, 2, 3, 4 ... 13, 14, 15 Next
Page 3 of 15
