Quite a few, but all of them are used by zero currently-released programs except for MOS GUIs:
[/code]
Update_Scrollbar: jp mj_NotImplemented ;not used
Initial_Scrollbar: jp mj_NotImplemented ;not used
sortallfolds: jp mj_NotImplemented ;not used
dofoldsort: jp mj_NotImplemented ;not used
getfoldsort: jp mj_NotImplemented ;not used
setfoldsort: jp mj_NotImplemented ;not used
Increase_Cur_Element: jp mj_NotImplemented ;not used
Decrease_Cur_Element: jp mj_NotImplemented ;not used
Increase_Max_Elements: jp mj_NotImplemented ;not used
Decrease_Max_Elements: jp mj_NotImplemented ;not used
Add_A_To_Cur_Element: jp mj_NotImplemented ;not used
Sub_A_From_Cur_Element: jp mj_NotImplemented ;not used
Add_A_To_Max_Elements: jp mj_NotImplemented ;not used
Sub_A_From_Max_Elements: jp mj_NotImplemented ;not used
Skip_Forward_B_From_Top: jp mj_NotImplemented ;not used
Get_Curgoodprog_Ptr: jp mj_NotImplemented ;not used
getchecksum: jp mj_NotImplemented ;not used
freearc: jp mj_NotImplemented ;not used
swapram: jp mj_NotImplemented ;not used
hideall: jp mj_NotImplemented ;not used
renameprog: jp mj_NotImplemented ;not used
renamefolder: jp mj_NotImplemented ;not used
sysmain: jp mj_NotImplemented ;not used
folder_menu_start: jp mj_NotImplemented ;not used
options_screen: jp mj_NotImplemented ;not used
put_folder_name_top: jp mj_NotImplemented ;not used
general_key_routine: jp mj_NotImplemented ;not used
find_num_good_progs: jp mj_NotImplemented ;not used
put_scrollbar: jp mj_NotImplemented ;not used
invert_lines: jp mj_NotImplemented ;not used
invert_1_line: jp mj_NotImplemented ;not used
right_align_value: jp mj_NotImplemented ;not used
put_mirageos_header: jp mj_NotImplemented ;not used
put_size_graphic: jp mj_NotImplemented ;not used
sendprog: jp mj_NotImplemented ;not used
hideprog: jp mj_NotImplemented ;not used
arcprog: jp mj_NotImplemented ;not used
nextfolder: jp mj_NotImplemented ;not used
delfolder: jp mj_NotImplemented ;not used
moveall: jp mj_NotImplemented ;not used
curFoldName: jp mj_NotImplemented ;not used
curfoldnamea: jp mj_NotImplemented ;not used
createfolder: jp mj_NotImplemented ;not used
