I have ported Frogger He's Back (PlayStation 1, 1997) to the Ti Nspire CX II.
It is currently in a playable state, although it's not quite as fast as on a real PSX.
Download: here
Screenshots:
How?
The main answer is a project called PsyCross. To my knowledge, all official PS1 games were compiled with a set of runtime libraries called Psy-Q. These libraries were the main way of interfacing with the PSX hardware. So PsyCross replaces the Psy-Q implementation with a roughly cross-platform implementation.
All I did was hack up a software renderer/triangle rasterizer, chop out audio, replace memory card integration, and optimize like heck.
What's next?
I plan to port a few more games, depending on which ones end up working well.
Frogger 2: Swampy's Revenge is a pretty obvious choice, but any PSX game which has had its source code made available online or decompiled could in theory be ported.
Impressive 😁
Great! Soon we will able to write our own kernels...
Alrighty, took a little while for ticalc.org, but now here's Frogger 2: Swampy's Revenge!
Also, an update to Frogger 1 containing major FPS improvements has been posted too.
Download: here
Screenshots:
What's next?
I have a few more ideas, some more ambitious than others. I remember when I was in middle school and playing GBA games on my Ti-Nspire CX. My goal is to do things which I'd either have put on my calculator back then, or would have impressed me the most back then.
how about just making a ps1 emulator? for multiple games that's not ported?
One small request... grand Turismo 2 on calc... Tekken on calc.., crash bandicoot on calc.... all of this would be so peak. How difficult is it to port games?
A PSX emulator is difficult for a few reasons:
#1) The games require specific optimizations for each game to run well under software rendering (eg: the calculator has no GPU).
#2) PSX game discs are on average much larger than what a Ti-Nspire can hold. The Ti-Nspire CX has around 100MB of storage, but PSX games are far larger than that, even compressed. Frogger works because the large files (eg: audio, pre-rendered videos, etc) have already been stripped out. So each individual game would need to have tons of files removed, AND have a patch written to modify the game to not rely upon those files.
#3) An emulator would also be significantly slower, and take significant work to build a dynamic recompiler to translate MIPS (PSX CPU instructions) into ARM (Ti-Nspire CX CPU). These ports avoid this because they are built directly into ARM instructions from source code.
I don't see any decompilations/source code available for these games. It'd probably be possible via static recompilation, but I'm not sure if that's a route I'd like to go down right now.
Ok, and I forgot to mention all of ts is Epic. like great job
