Heads up for anyone using a TI-84 Plus CE with Windows 11: since around April 2026, some Windows 11 systems may no longer be able to connect to the calculator through TI Connect CE because Windows blocks the TI driver.
The error I’m seeing in Device Manager is:
This is not the usual “bad cable” or “TI Connect can’t find my calculator” issue. In this case, Windows detects that there is a driver involved, but refuses to load it because of Application Control policy enforcement.
What this means in practice:
I tried the usual troubleshooting path: different connection attempts, checking Device Manager, and confirming that the calculator program itself works in the emulator. The blocker appears to be Windows refusing the TI driver, not the calculator or the transfer file.
Until TI releases an updated Windows driver that complies with current Windows security requirements, affected Windows 11 users may be stuck. Possible workarounds are using a Mac/Linux machine, another computer that still allows the driver, or emulator-only testing.
If anyone else is seeing the same Code 39 / Application Control policy has blocked this file error, please post your Windows version, TI Connect CE version, and calculator model/OS version. It would be useful to know how widespread this is.
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
An Application Control policy has blocked this file.
- TI Connect CE cannot see the calculator.
- Replugging the calculator does not fix it.
- The calculator itself may be fine.
- The .8xp files may be fine.
- The same program can work in CEmu/emulator.
- The failure is between Windows 11 and the TI-84 CE USB driver.
