hey, been a while but could you go into more detail by what you mean? some apps are embedded into the index.html, like the calculator, or the terminal, but some apps, are separate files in frames.
Well no I-frames could definitely be an option, it's just the files for the programs might not be accessed right. I see a "This file could not be accessed" Error. So maybe you are accessing it wrong. If you want to avoid this issue entirely you can just put the other html files for the text editor and others inside the main html file. But I would not really recommend that as obviously you need to make your code clean, but HTML in general isn't really clean so no one would really care if you did. It's up to you.
The other thing with the positioning bug might just be the css elements not having a position style of "absolute". Make sure they are all absolute including the elements in the other files that have popup's.
Hello!
I need beta testers since I don't have time to click every button in my code to make sure it works, but, Here It Is!!! N-CO OS Beta Patch V1.1
Many bug fixes, many more bugs made, less chatgpt code
https://drive.google.com/drive/folders/1-0--59pfX7QmUr1CzcEtcMVcsP2PSTrO
Link should work if you need permission to open it email me at
2027-noah.lebel@warwickschools.org
or text me at [redacted]
please feel free to give suggestions, code, and report bugs here
Use Index.html to open
Bye!
yep, I figured it out, gotta fix that later, its because those files are specific to my computer, and my file system so I have to fix the links or remove the iframes all together.
Hello Guys
I added SnesJS (rebranded as SnesN-CO but I'll change that later) I will give credit where do since I did not write the original code.
I will post the new versions of N-CO OS here later on maybe another day since I'm in the middle of final exams, yeah Im a sophomore so very busy.
See ya and please give suggestions, if you have any comments please don't hesitate to write them
See ya!
Hey everyone,
I kind of forgot about this project and honestly I wont update for awhile if ever, if someone would like to take over then let me know but see ya!
ill probably be back next week,
Noah L
Page 2 of 2
