Is there a way to get inverted characters on the TI84+CE? Like using the normal numbers, letters, etc. but they are inverted?
The only thing I can find is this excerpt from a tibasic program:
Code: Output(C,D,sub(" invertedequal",[A](C,D)+1,1))
If you use the string "invertedequal" in Sourcecoder 3 it will work, but is this the only character that can be inverted, or can any character be? 💡
Download Celtic CE! It includes a command that allows you to change the foreground and background colors of text displayed in a program. I installed it a while ago on my calculator and can confirm that it's a total game changer.
https://bit.ly/CelticCE
invertedequal is a different token from the regular equals sign.
I don't believe that it's possible to display inverted text in vanilla TI-BASIC (outside of like the header on the
Menu( command which is probably not all that useful). You can use the
TextLib library or the
DispText method of
Celtic CE to display text with different colors on the homescreen.
It is indeed the only character that can be inverted, at least with the default OS tokens.
