Coder_2917 wrote:
I updated my os from 5.8 to 5.8.2, and it worked perfectly on all OS's in that range.
Thanks! I'll give it a try.
Are you all talking about VYSION 1 or the pre-release for 2?
I believe I downloaded the pre-release for VYSION 1. It's a really good shell. Until now, I have not seen any sort of bug in it.
I updated the OS, and while it works better, it still causes crashes.
VYSION 1. I posted it here because I couldn't find a topic specifically for it
epsilon5 wrote:
Dereo_Habibi1233 wrote:
Is there a way to make Vysion 1 or Vysion 2 an application or is it only possible to access it from another shell
That will be done before release, I pretty much have to now as both CEaShell and Cesium do.
For a bit I was like what, when did they crack the application signing key? But it looks like Cesium just makes a shortcut in the apps menu, to the program, for your convenience, it's not technically an app.
Will xLibCE ever get added?
what keys do you need t use like to e.g edit a file. i cant find it Very Happy
Probably not, the scope of the project is big enough already.
Should be in the README, but just press [mode] with the selection box over a file and the context menu will appear allowing you to take actions related to that file. Works for both VYSION 1 and 2.
As for the application signing key, that hasn't been figured out. But, people have figured out how to install apps on the calculator given an installation program, which allows app-specific tricks like fancy hooks. Cesium is the first one that I know of to use this, and CEaShell and Celtic CE are a couple of others to take advantage of it. There are even some neat app tools in the toolchain now to make this easy to do, which is what I plan on using to make VYSION 2 an app eventually.
» Goto page Previous  1, 2, 3 ... 11, 12, 13
Page 13 of 13
