Coder_2917 wrote:
I updated my os from 5.8 to 5.8.2, and it worked perfectly on all OS's in that range.
Thanks! I'll give it a try.
Are you all talking about VYSION 1 or the pre-release for 2?
I believe I downloaded the pre-release for VYSION 1. It's a really good shell. Until now, I have not seen any sort of bug in it.
I updated the OS, and while it works better, it still causes crashes.
VYSION 1. I posted it here because I couldn't find a topic specifically for it
epsilon5 wrote:
Dereo_Habibi1233 wrote:
Is there a way to make Vysion 1 or Vysion 2 an application or is it only possible to access it from another shell
That will be done before release, I pretty much have to now as both CEaShell and Cesium do.
For a bit I was like what, when did they crack the application signing key? But it looks like Cesium just makes a shortcut in the apps menu, to the program, for your convenience, it's not technically an app.
Will xLibCE ever get added?
