Will this cable work on a TI-82?
Issah45 wrote:
PC-03
FTDI Programming Cable
Chirp: TTL CP2102
Pin Diameter: 3.5mm Jack Stereo (Mic pin), and 2.5mm Jack Stero (Ear pin)
Chirp: TTL CP2102
No.
Tari wrote:
Issah45 wrote:
PC-03
Chirp: TTL CP2102
Chirp: TTL CP2102
No.
To be more precise, the only cable that will work with a TI-82 is the regular Graph-Link cable, which uses a serial connection. There exists a "silver link" cable (TI Connectivity Cable USB) that is able to communicate with the TI-83 Plus and later calculators (assuming they use the same type of port,) but won't work with anything earlier (at least through TI's official software. Haven't tested it with anything else yet.)
HydrideGS wrote:
Tari wrote:
Issah45 wrote:
PC-03
Chirp: TTL CP2102
Chirp: TTL CP2102
No.
ok
