There is a small bug with rectangles: If the rectangle width is 320 pixels it won't show up, so the max width currently seems to be 319 pixels.
» Forum
> Your Projects
Yes, the issue occurs anytime Celtic thinks the width of a rectangle needs to be clipped, so basically anytime the starting x value plus the width is equal to or greater than 320. Celtic just ends up exiting early instead of drawing the rectangle by mistake. I've made a patch for this already and hopefully plan to release it soon along with some other optimizations I've made for Celtic
I know it's been a few months now since I made an update here, but version 1.0.1 of Celtic CE is now out! It's a relatively small update that mostly fixes a couple of bugs (like the one mentioned above) and adds stability to several commands (and I got it out just in time for the holidays
) As usual, you can download it from Cemetech (once it's approved), or if you can't wait, you can get it from Github. I hope you all enjoy the update and happy holidays, everyone!
This library sounds absolutely amazing. When I get the time, I definitely want to see what cool things I can make with it!
Something I think that would be good for the documentation would just be a list/cheat sheet for what all the det( commands do in a short version, with the syntax, maybe a "see page XX for more details". Otherwise, got it downloaded and will be playing around with it when I can!
Just out of curiosity, are there ASM limitations that CEltic can't match? I know very little about ASM in general but what capabilities are still exclusively locked in coding on a computer/ what features could be added to repair that? I ask as someone who doesn't really have access to ASM coding and would love to be able to do everything from the TI84+CE itself.
Edit: ALSO, how well does it integrate with Python programs and Appvars?
Edit #2: ALSO ALSO, amazing job, this library gives more access than I ever thought possible to people like me who want to learn to code but don't love the idea of doing it on a computer, CEltic is awesome and I'm super excited to explore it's capabilities once I learn some more!
Note from administrator: Please edit your post instead of double- or triple-posting.
try not to double post(or triple post) in the same day, you could just edit the posts to chain them all together, and there are somethings that Celtic Misses, but they are mostly obscure things that have more to do with pushing the hardware to the full extent, typically, Anything ASM related and Python don't really work, you may be able to interact with the files and such but I highly doubt anything worthwhile would come of it, but APPVAR usage is one of the most important features of ASM/CELTIC
Are there any other online resources as far as actually using Celtic CE?
I know that the answer is to read the documentation and just work on doing ASM and BASIC stuff until I get it, but any very helpful YouTube videos would be much appreciated
I have no idea what I’m doing wrong. I am attempting to use the ShiftScreen( command but it’s doing next to nothing. My sample code is very basic, I’m just drawing a rectangle and attempting to move it down, but nothing happens:
I have also tried it to shift the screen containing OS drawn graphics, like Line( or Text( but still nothing happens.
EDIT: shifting the entire screen does seem to work, by eliminating the last 4 arguments, although it’s more like it pastes a copy of the screen to the new location rather than “shifting” but I suppose I can make up for this by erasing the old location…
det(15,96,5,50,50,50,50
det(58,1,100,50,50,50,50
Pause
Pause
I've had the same experience. I still have the original version of Celtic; not sure if the latest version changes anything, but I plan to install it
EDIT: Dang. I'm going to be the 1112th downloader. My apologies to the obsessive compulsive.
Download Mastermind CE!
Rocco helped me realize my error - I was selecting a region that I wanted to shift, but you actually have to select the region size that includes what you’re shifting plus the destination it’s going to end up, since anything outside of the selected region will never be changed.
» Goto page Previous 1, 2
Page 2 of 2
