You can find an adapter on amazon for around $5. Any 2.5mm male to 3.5mm female adapter should work, I think
this is the one I have.
A thing to watch out for is the diameter of the plastic around the connector. Unlike on the 83+, the port on the 84+ is very deep and there is not much room around it. I thought i had a good one and still had to shave some plastic off with a knife.
If you can't insert it properly, you 1) won't get stereo, and 2) will cause a short inside the linkport (which it should be resistant to, but there have been cases of fried linkports at times).
Oh ok do you have one to recommend thanks though
