I believe
this is the newest version but I could be wrong. I don't think it was officially released on any downloads section. Also as
this post says, archives generated by this standalone PicArc program are not compatible with the ones from Celtic III.
Thanks for finding that, DJ_Omnimaga! I was looking around to no avail.
I do however recommend you just use Doors CS. There's so much you can take advantage of:
https://dcs.cemetech.net/SDK/Mono/BASIC/
I realized that I might have been wrong. I actually wanted the command PutSprite - identity (5, "HEXSTRING", x, y, w, h, logic, flip, update_lcd) in DCS7. I just wanted to display a hexstring formatted image in basic, but space limitations prevented me from installing the entire DCS4 (110+KB). I thought picarc lib was an 8xk file similar to xlib, and then I used the ”identity(“ command to write it into the basic program. Thank you very much for your help.
