Hello, I was wondering if there is any command to get the current color palette, just like setPalette() but in reverse.
I could copy the data directly from RAM at 14877184 (hex: e30200) but i guess thats not safe for newer clibs versions.
I would be happy for any ideas.
Are you using ICE? If so you do know it isn't supported anymore?
Copying 0xE30200 is your only option.
So, I thought about how to implement this... Will the color pointer stay the same in newer clibs versions or should I implement an option to manually input the pointer if changes are needed?
That pointer shouldn't ever change as that's what the LCD controller relies on when in 8bpp mode.
Thats nice
Thank you
