CALCCIV
FreeCiv for the TI 84+ CE Calculators- in full TI-Basic
CALCCIV special main menu
Regular main menu
In-Game
Logo, made and displayed in LINEDIT
CALCCIV is a still-in-alpha game, that, as one might have guessed, is a port of Civilization, specifically FreeCiv, into TI-Basic. It uses fairly primitive graphics, and attempts to be at a reasonable speed to play at. It is available at
GitHub and dev builds are available at
Google Drive.
I forgot to include a crucial library, haha oops, that most likely resulted in it just mysteriously crashing whenever opened, or messed up the graphics severely.
That's fixed now, just follow the instructions on GitHub and it should not throw an error. I'll try to NOT be stupid next time.
This sounds like an interesting project! Do you have any screenshots you can share?
Of course!
This is a dev build (ignore "public beta 1" on the last screenshots, I didn't update it yet), so far I have implemented black lines in case that tile doesn't exist (rollover to emulate a round earth will be added later) and simplified the textures so that they are faster to draw on the screen. TI-BASIC, every drop of performance matters here.
CALCCIV map viewing in real-time (It was actually done on CEmu, surprisingly CEmu is really inaccurate about the speed of the map viewing. Even on 150% emulation speed, the real hardware is still faster. Possible bug)
Still image of the map.
Map generation screen (its horrendously slow- sorry, it's still TI-BASIC here. Pick 30*30 size and it should be done in ~10 minutes)
Quick edit, the free space on the right will be used for the GUI wall that freeciv and civ II have.
Just so the, like 3, people following this project don't think I have abandoned it, this will a news post.
The next update is going to include the skeletons of a gui, the skeletons of the city management, proper new game creation, and (maybe) the units system, along with the rollover effect in the previous post.
The gui is about ~75% done, though quick note you will need to redo gdstand because the dimensions changed
The city management has not yet been started
The units system has not been started
and the new game creation screen is about ~25% done.
ALSO, very important!: If the anyone has ideas for a better map generation and/or how to implement proper ai players, please tell me. For the map generation, I am thinking of maybe a couple of pre-defined 5*5 map chunks, with the bulk of the generation happening in a 6*6/12*12 matrix. AI I have no clue where the begin yet. Ideas even if terrible are appreciated.
I like the art style. I'd like to see buildings in that color stick figure style.
This is a fantastic project, the graphics look very playable for BASIC
If you post your map generation code, I'd love to help you speed things up (and maybe others will help too?) Aha! There's a GitHub link in the first post! You should upload some of your other programs
to our program archives!
Are you ok with me moving this topic from the do-it-yourself subforum and into the Your Projects subforum, so it is eligible for our Projects of the Months news program?
A few things,
first, yes, I have 0 objections to this being moved to the your projects subforum instead.
Secondly, progress will be slowed down for an indeterminate amount of time (mostly likely 1-2 months) as my computer is broken and all the coding needs to be done on-calc, this also means no updates to the public or screenshots for that time period. Sorry. (At least it is still TI-BASIC and no ram resets can happen, eh?)
Thirdly, I am glad the artstyle is not horribly terrible, still needs a lot of speed up though.
Lastly, a note about how this is going to work, in order to not need to redraw the screen multiple times when only one element needs to be updated, this program will make heavy use of the storepic and recallpic functions. This means do not delete pic1 pic2 or pic3, unless you want your archive to degrade severely and gameplay to be interrupted by defragments. EDIT: This may change in the future by drawing white lines instead, but that would require immense amounts of fine tuning
Update post/Dev Diary/Thingamajig
The GUI is looking great, whereas before it felt really empty and bare, now it feels more cluttered and like you have to do so many things, which is really great for civ as no one likes just pressing next turn a hundred times.
For the city system, I have decided to store all the names in a modified version of numtext (from a different project, wont be exposed to the end user anyway) in a list, which will be able to support 76 cities with 13 characters for the name of each city. Similarly, cities information will be stored in a list as well, also 13 numbers in the list for each city just for convenience sake. Instead of storing each building as a boolean value, which would require massive lists, buildings will be stored as multiples of primes. AKA each building has a prime number attached to it and if the building number in the city is divisible by that prime, that building is present. Compression, its good. In the building layer, each city will be 100+its id, so the ids can be yoinked straight from the map.
Units will have sprites, which wont be a person but instead something that represents it, like a bow for an archer, a club for a warrior, a radiation symbol for the ultimate solution, etc etc. Each unit will have a pre-defined attack and defense value, which, once I figure out how it works in freeciv, will be identical to freeciv. Likewise, they will have a movement score, and each terrain tile will have a movement penalty score. And again, I need to see hiw freeciv does it, and implement it that way.
Still no screenshots for now, sorry, screenshot machine still broke.
Are you using textlib to draw the colored text? I would highly recommend using Celtic Ce, which is just a Ti BASIC hybrid library. It would allow you to draw actual sprites very quickly from a matrix and still use the full screen without any graphing borders
I know Celtic CE exists (and it is very convenient too!), its just that I am
1. More familiar with just pure TI-Basic
2. Want this to be able to run without messing with ASM stuff
3. Want this to be an actual challenge to get it to perform well
Anyone is welcome to port this to Celtic though, that would make it perform much faster!
ok, I feel the same that you do about asm. Thankfully Celtic ce is a way to get asm level functions while still staying with Basic but I understand that it would still be a jump. I'm sure that others including me would be willing to try and redo the sprite work using Celtic Ce. Other than the 8xp file on github, is there a way to obtain the source code for your project?
No, but the 8xp is pretty much all you would need. Its not obsfuscated in any way- it even includes comments!
EDIT: Disambiguation for what each .8xp does, CALCCIV.8xp is the front-end, which decides what to call in CACIDATA.8xp (CAlc CIv DATA) which contains the sprite files (in Line( command form), the extra large map support (and will contain) terrain, unit, ans building stats, etc etc. Both will need to be edited to make CALCCIV fullt utilize Celtic CE. GDSTAND.8xp literally just puts one graph in GDB9, no need for that to be edited.
One computer later, and now progress can resume!
Here is what the new game generation looks like, beginning to end:
(There is a sneak peek of the half-finished gui too)
Along with this, you can see a tiny piece of text that says "Retrieving city names" at the end, that's because as discussed previously, the names are stored in a list and then moved to a string for convenience. Update
might come out sometime next week.
PS 1: The world generation is sped up in the screenshot
PS 2: The rest runs at 200% on cemu, my physical calculator runs much much faster then cemu for some reason
nvm, cemu decided to record at normal speed, for some reason
Hello! I am, after some devving, back! I have added:
- World Topography Options (Topography itself is broken at the moment)
- A Console
- A Changelog
- An exit button in the main menu
- A click menu
- The only current option being "TERRAIN" which displays the name of the terrain that tile is
- A (very extensive!) debug mode
- QuickGen, which can generate 30*30 and 60*60 way WAY quicker than the previous method
- Nesting Options in the World Gen
Along with the regular load of performance improvements.
And here is an animated png showcasing all the new stuff!
nice! I was worried this had died
Happy 1 year and 1 week anniversary of the development of this project! I'll fix the main post tommorow, but in terms of dev, I added a spawn command in the console, and the ability to spawn cities and units. Cities can be opened through the click-menu to no functionality at all, and units just look pretty.
In celebration, I've uploaded all dev builds so far onto google drive so that anyone can play with it, which I'll periodically update.
Link Here!!
I’d love to port this to Celtic CE as a summer project
Whats the GDstand file for? I don't remember that from earlier.
