How do I use the input token? It says it's used like in BASIC but I tried to do it like that and it just says "INVALID TOKEN".
The documentation lies. You just use input, no arguments, and it returns a pointer to the created temporary OS string variable. Like other variable-sized OS variables, the data is preceded by a two-byte length value. Note that this measures bytes, not tokens.
sirdudeman wrote:
How do I change the length of a list?
If you're referring to Axe's definitions of L₁-L₆ (https://axe.eeems.ca/Commands.html#dataAndStorageCommands), they're not really lists, they're simple fixed-size data storage areas.
If you're referring to OS list variables... that's complicated, so I hope you're not.
- DragonScholar71
- Member (Posts: 135)
- 11 Jan 2023 02:39:24 pm
- Last edited by DragonScholar71 on 30 Aug 2023 11:30:27 am; edited 1 time in total
Anyone here know how to add characters to the end of a string? I originally store the entire string space before and then replace the characters from the beginning to end. Is there any way to better do this?
EDIT: Already figured this out!
Can somebody give a little more insight as to how custom interrupts work? I want to utilize them but I don't know more than creating them. More specifically I do not know exactly what the subroutine label does.
» Goto page Previous 1, 2, 3 ... 10, 11, 12
Page 12 of 12
